Attention is currently required from: Hung-Te Lin, Kiwi Liu, Paul Menzel, Yu-Ping Wu.
Mengqi Zhang has uploaded a new patch set (#12) to the change originally created by Kiwi Liu. ( https://review.coreboot.org/c/coreboot/+/84298?usp=email )
Change subject: soc/mediatek/common: Reduce eMMC clock frequency to 400 kHz ......................................................................
Mediatek SoCs start operating at eMMC clock around 2 MHz right after power-on. In JEDEC spec, eMMC clock needs under 400 kHz. When we need to set a clock output frequency, we actually set a frequency division value. Originally, we set the source clock frequency to 50MHz, the target frequency to 400KHz, and the frequency division value to 125. However, the actual source clock frequency is 400MHz, so the final actual output is 400MHz/125=3.2MHz. When we set the source clock frequency correctly, we can get the correct frequency division value, and then get the correct clock output.
BUG=b:356578805 TEST=test boot ok; measure eMMC clock ok
Change-Id: I9c8836b23fb21e9b0bdc80fbe85142ea0fa5e381 Signed-off-by: Mengqi Zhang mengqi.zhang@mediatek.corp-partner.google.com Signed-off-by: Kiwi Liu kiwi.liu@mediatek.corp-partner.google.com --- M src/soc/mediatek/common/msdc.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/84298/12
