Marc Jones (marc.jones@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8224
commit 34bc587e37d27d06735db5f74f09d0d21ee076c1 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Wed Jan 14 19:51:47 2015 +0100
vboot2: add verstage
This reverts the revert commit 5780d6f3876723b94fbe3653c9d87dad6330862e and fixes the build issue that cuased it to be reverted.
Verstage will host vboot2 for firmware verification. It's a stage in the sense that it has its own set of toolchains, compiler flags, and includes. This allows us to easily add object files as needed. But it's directly linked to bootblock. This allows us to avoid code duplication for stage loading and jumping (e.g. cbfs driver) for the boards where bootblock has to run in a different architecture (e.g. Tegra124). To avoid name space conflict, verstage symbols are prefixed with verstage_.
TEST=Built with VBOOT2_VERIFY_FIRMWARE on/off. Booted Nyan Blaze. BUG=None BRANCH=none
Original-Signed-off-by: Daisuke Nojiri dnojiri@chromium.org Original-Change-Id: Iad57741157ec70426c676e46c5855e6797ac1dac Original-Reviewed-on: https://chromium-review.googlesource.com/204376 Original-Reviewed-by: Randall Spangler rspangler@chromium.org
(cherry picked from commit 27940f891678dae975b68f2fc729ad7348192af3) Signed-off-by: Marc Jones marc.jones@se-eng.com Change-Id: I2a83b87c29d98d97ae316091cf3ed7b024e21daf --- Makefile.inc | 9 ++++++++- src/arch/arm/Kconfig | 4 ++++ src/arch/arm/Makefile.inc | 2 +- src/arch/arm/armv7/Kconfig | 4 ++++ src/arch/arm64/Kconfig | 4 ++++ src/arch/arm64/armv8/Kconfig | 3 +++ src/arch/riscv/Kconfig | 4 ++++ src/arch/x86/Kconfig | 4 ++++ src/cpu/allwinner/a10/Kconfig | 1 + src/cpu/amd/agesa/Kconfig | 1 + src/cpu/amd/geode_gx2/Kconfig | 1 + src/cpu/amd/geode_lx/Kconfig | 1 + src/cpu/amd/model_10xxx/Kconfig | 1 + src/cpu/amd/model_fxx/Kconfig | 1 + src/cpu/amd/pi/Kconfig | 1 + src/cpu/armltd/cortex-a9/Kconfig | 1 + src/cpu/dmp/vortex86ex/Kconfig | 1 + src/cpu/intel/ep80579/Kconfig | 1 + src/cpu/intel/fsp_model_206ax/Kconfig | 1 + src/cpu/intel/fsp_model_406dx/Kconfig | 1 + src/cpu/intel/haswell/Kconfig | 1 + src/cpu/intel/model_1067x/Kconfig | 1 + src/cpu/intel/model_106cx/Kconfig | 1 + src/cpu/intel/model_2065x/Kconfig | 1 + src/cpu/intel/model_206ax/Kconfig | 1 + src/cpu/intel/model_65x/Kconfig | 1 + src/cpu/intel/model_67x/Kconfig | 1 + src/cpu/intel/model_68x/Kconfig | 1 + src/cpu/intel/model_69x/Kconfig | 1 + src/cpu/intel/model_6bx/Kconfig | 1 + src/cpu/intel/model_6dx/Kconfig | 1 + src/cpu/intel/model_6ex/Kconfig | 1 + src/cpu/intel/model_6fx/Kconfig | 1 + src/cpu/intel/model_6xx/Kconfig | 1 + src/cpu/intel/model_f0x/Kconfig | 1 + src/cpu/intel/model_f1x/Kconfig | 1 + src/cpu/intel/model_f2x/Kconfig | 1 + src/cpu/intel/model_f3x/Kconfig | 1 + src/cpu/intel/model_f4x/Kconfig | 1 + src/cpu/qemu-x86/Kconfig | 1 + src/cpu/ti/am335x/Kconfig | 1 + src/cpu/via/c3/Kconfig | 1 + src/cpu/via/c7/Kconfig | 1 + src/cpu/via/nano/Kconfig | 1 + src/mainboard/bifferos/bifferboard/Kconfig | 1 + src/soc/intel/baytrail/Kconfig | 1 + src/soc/intel/broadwell/Kconfig | 1 + src/soc/intel/fsp_baytrail/Kconfig | 1 + src/soc/nvidia/tegra124/Kconfig | 1 + src/soc/nvidia/tegra124/Makefile.inc | 2 ++ src/soc/nvidia/tegra124/bootblock.c | 7 +++++-- src/soc/nvidia/tegra124/verstage.c | 9 +++++++++ src/soc/nvidia/tegra124/verstage.h | 2 ++ src/vendorcode/google/chromeos/Kconfig | 8 ++++++++ src/vendorcode/google/chromeos/Makefile.inc | 9 +++++++++ toolchain.inc | 2 +- 56 files changed, 109 insertions(+), 5 deletions(-)
diff --git a/Makefile.inc b/Makefile.inc index b0289c0..0c6aafa 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -75,7 +75,7 @@ subdirs-y += site-local
####################################################################### # Add source classes and their build options -classes-y := ramstage romstage bootblock smm smmstub cpu_microcode +classes-y := ramstage romstage bootblock smm smmstub cpu_microcode verstage
# Add dynamic classes for rmodules $(foreach supported_arch,$(ARCH_SUPPORTED), \ @@ -128,6 +128,8 @@ ramstage-postprocess=$(foreach d,$(sort $(dir $(1))), \ $(eval $(d)ramstage.o: $(call files-in-dir,$(d),$(1)); $$(LD_ramstage) -o $$@ -r $$^ ) \ $(eval ramstage-objs:=$(d)ramstage.o $(filter-out $(call files-in-dir,$(d),$(1)),$(ramstage-objs))))
+verstage-c-ccopts:=-D__PRE_RAM__ -D__VER_STAGE__ +verstage-S-ccopts:=-D__PRE_RAM__ -D__VER_STAGE__ romstage-c-ccopts:=-D__PRE_RAM__ romstage-S-ccopts:=-D__PRE_RAM__ ifeq ($(CONFIG_TRACE),y) @@ -162,6 +164,7 @@ endif
ramstage-c-deps:=$$(OPTION_TABLE_H) romstage-c-deps:=$$(OPTION_TABLE_H) +verstage-c-deps:=$$(OPTION_TABLE_H) bootblock-c-deps:=$$(OPTION_TABLE_H) smm-c-deps:=$$(OPTION_TABLE_H)
@@ -374,6 +377,10 @@ $(obj)/%.romstage.o $(abspath $(obj))/%.romstage.o: $(obj)/%.c $(obj)/config.h $ @printf " CC $(subst $(obj)/,,$(@))\n" $(CC_romstage) -MMD $(CFLAGS_romstage) $(CPPFLAGS_romstage) $(romstage-c-ccopts) -c -o $@ $<
+$(obj)/%.verstage.o $(abspath $(obj))/%.verstage.o: $(obj)/%.c $(obj)/config.h $(OPTION_TABLE_H) + @printf " CC $(subst $(obj)/,,$(@))\n" + $(CC_verstage) -MMD $(CFLAGS_verstage) $(verstage-c-ccopts) -c -o $@ $< + $(obj)/%.bootblock.o $(abspath $(obj))/%.bootblock.o: $(obj)/%.c $(obj)/config.h $(OPTION_TABLE_H) @printf " CC $(subst $(obj)/,,$(@))\n" $(CC_bootblock) -MMD $(CFLAGS_bootblock) $(CPPFLAGS_bootblock) $(bootblock-c-ccopts) -c -o $@ $< diff --git a/src/arch/arm/Kconfig b/src/arch/arm/Kconfig index 156c8c2..1c3a339 100644 --- a/src/arch/arm/Kconfig +++ b/src/arch/arm/Kconfig @@ -3,6 +3,10 @@ config ARCH_BOOTBLOCK_ARM default n select ARCH_ARM
+config ARCH_VERSTAGE_ARM + bool + default n + config ARCH_ROMSTAGE_ARM bool default n diff --git a/src/arch/arm/Makefile.inc b/src/arch/arm/Makefile.inc index 5698f38..6f65a71 100644 --- a/src/arch/arm/Makefile.inc +++ b/src/arch/arm/Makefile.inc @@ -61,7 +61,7 @@ bootblock-y += memcpy.S bootblock-y += memmove.S bootblock-y += div0.c
-$(objcbfs)/bootblock.debug: $(src)/arch/arm/bootblock.ld $(obj)/ldoptions $$(bootblock-objs) +$(objcbfs)/bootblock.debug: $(src)/arch/arm/bootblock.ld $(obj)/ldoptions $$(bootblock-objs) $$(VERSTAGE_LIB) @printf " LINK $(subst $(obj)/,,$(@))\n" $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) --start-group $(bootblock-objs) --end-group -T $(src)/arch/arm/bootblock.ld
diff --git a/src/arch/arm/armv7/Kconfig b/src/arch/arm/armv7/Kconfig index f8e0205..aa188e2 100644 --- a/src/arch/arm/armv7/Kconfig +++ b/src/arch/arm/armv7/Kconfig @@ -2,6 +2,10 @@ config ARCH_BOOTBLOCK_ARMV7 def_bool n select ARCH_BOOTBLOCK_ARM
+config ARCH_VERSTAGE_ARMV7 + def_bool n + select ARCH_VERSTAGE_ARM + config ARCH_ROMSTAGE_ARMV7 def_bool n select ARCH_ROMSTAGE_ARM diff --git a/src/arch/arm64/Kconfig b/src/arch/arm64/Kconfig index dc0e332..186dd44 100644 --- a/src/arch/arm64/Kconfig +++ b/src/arch/arm64/Kconfig @@ -3,6 +3,10 @@ config ARCH_BOOTBLOCK_ARM64 default n select ARCH_ARM64
+config ARCH_VERSTAGE_ARM64 + bool + default n + config ARCH_ROMSTAGE_ARM64 bool default n diff --git a/src/arch/arm64/armv8/Kconfig b/src/arch/arm64/armv8/Kconfig index fc2e668..5840e81 100644 --- a/src/arch/arm64/armv8/Kconfig +++ b/src/arch/arm64/armv8/Kconfig @@ -1,6 +1,9 @@ config ARCH_BOOTBLOCK_ARM_V8_64 def_bool n select ARCH_BOOTBLOCK_ARM64 +config ARCH_VERSTAGE_ARM_V8_64 + def_bool n + select ARCH_VERSTAGE_ARM64 config ARCH_ROMSTAGE_ARM_V8_64 def_bool n select ARCH_ROMSTAGE_ARM64 diff --git a/src/arch/riscv/Kconfig b/src/arch/riscv/Kconfig index 120203d..f2dc41e 100644 --- a/src/arch/riscv/Kconfig +++ b/src/arch/riscv/Kconfig @@ -3,6 +3,10 @@ config ARCH_BOOTBLOCK_RISCV default n select ARCH_RISCV
+config ARCH_VERSTAGE_RISCV + bool + default n + config ARCH_ROMSTAGE_RISCV bool default n diff --git a/src/arch/x86/Kconfig b/src/arch/x86/Kconfig index 56d8f88..edbc67a 100644 --- a/src/arch/x86/Kconfig +++ b/src/arch/x86/Kconfig @@ -3,6 +3,10 @@ config ARCH_BOOTBLOCK_X86_32 default n select ARCH_X86
+config ARCH_VERSTAGE_X86_32 + bool + default n + config ARCH_ROMSTAGE_X86_32 bool default n diff --git a/src/cpu/allwinner/a10/Kconfig b/src/cpu/allwinner/a10/Kconfig index b7b435f..58bf20d 100644 --- a/src/cpu/allwinner/a10/Kconfig +++ b/src/cpu/allwinner/a10/Kconfig @@ -7,6 +7,7 @@ if CPU_ALLWINNER_A10 config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_ARMV7 + select ARCH_VERSTAGE_ARMV7 select ARCH_ROMSTAGE_ARMV7 select ARCH_RAMSTAGE_ARMV7 select HAVE_MONOTONIC_TIMER diff --git a/src/cpu/amd/agesa/Kconfig b/src/cpu/amd/agesa/Kconfig index d539e19..2aeb8d7 100644 --- a/src/cpu/amd/agesa/Kconfig +++ b/src/cpu/amd/agesa/Kconfig @@ -28,6 +28,7 @@ config CPU_AMD_AGESA default y if CPU_AMD_AGESA_FAMILY16_KB default n select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select TSC_SYNC_LFENCE diff --git a/src/cpu/amd/geode_gx2/Kconfig b/src/cpu/amd/geode_gx2/Kconfig index 88fdc8f..1e4f435 100644 --- a/src/cpu/amd/geode_gx2/Kconfig +++ b/src/cpu/amd/geode_gx2/Kconfig @@ -20,6 +20,7 @@ config CPU_AMD_GEODE_GX2 bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32
diff --git a/src/cpu/amd/geode_lx/Kconfig b/src/cpu/amd/geode_lx/Kconfig index b700e0c..e3e2d2e 100644 --- a/src/cpu/amd/geode_lx/Kconfig +++ b/src/cpu/amd/geode_lx/Kconfig @@ -1,6 +1,7 @@ config CPU_AMD_GEODE_LX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32
diff --git a/src/cpu/amd/model_10xxx/Kconfig b/src/cpu/amd/model_10xxx/Kconfig index 5e45b0d..cf5748c 100644 --- a/src/cpu/amd/model_10xxx/Kconfig +++ b/src/cpu/amd/model_10xxx/Kconfig @@ -1,6 +1,7 @@ config CPU_AMD_MODEL_10XXX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SSE diff --git a/src/cpu/amd/model_fxx/Kconfig b/src/cpu/amd/model_fxx/Kconfig index f577b55..bdcf5bb 100644 --- a/src/cpu/amd/model_fxx/Kconfig +++ b/src/cpu/amd/model_fxx/Kconfig @@ -1,6 +1,7 @@ config CPU_AMD_MODEL_FXX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select MMX diff --git a/src/cpu/amd/pi/Kconfig b/src/cpu/amd/pi/Kconfig index 366beb4..88c4745 100644 --- a/src/cpu/amd/pi/Kconfig +++ b/src/cpu/amd/pi/Kconfig @@ -22,6 +22,7 @@ config CPU_AMD_PI default y if CPU_AMD_PI_00730F01 default n select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select TSC_SYNC_LFENCE diff --git a/src/cpu/armltd/cortex-a9/Kconfig b/src/cpu/armltd/cortex-a9/Kconfig index fb6cd0f..7ab3f55 100644 --- a/src/cpu/armltd/cortex-a9/Kconfig +++ b/src/cpu/armltd/cortex-a9/Kconfig @@ -1,6 +1,7 @@ config CPU_ARMLTD_CORTEX_A9 bool select ARCH_BOOTBLOCK_ARMV7 + select ARCH_VERSTAGE_ARMV7 select ARCH_ROMSTAGE_ARMV7 select ARCH_RAMSTAGE_ARMV7 default n diff --git a/src/cpu/dmp/vortex86ex/Kconfig b/src/cpu/dmp/vortex86ex/Kconfig index a7253e5..080bb64 100644 --- a/src/cpu/dmp/vortex86ex/Kconfig +++ b/src/cpu/dmp/vortex86ex/Kconfig @@ -20,6 +20,7 @@ config CPU_DMP_VORTEX86EX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select UDELAY_TSC diff --git a/src/cpu/intel/ep80579/Kconfig b/src/cpu/intel/ep80579/Kconfig index ec58428..5d90611 100644 --- a/src/cpu/intel/ep80579/Kconfig +++ b/src/cpu/intel/ep80579/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_EP80579 bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SSE diff --git a/src/cpu/intel/fsp_model_206ax/Kconfig b/src/cpu/intel/fsp_model_206ax/Kconfig index 9b0edfc..76b870e 100644 --- a/src/cpu/intel/fsp_model_206ax/Kconfig +++ b/src/cpu/intel/fsp_model_206ax/Kconfig @@ -30,6 +30,7 @@ config CPU_SPECIFIC_OPTIONS def_bool y select PLATFORM_USES_FSP select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/fsp_model_406dx/Kconfig b/src/cpu/intel/fsp_model_406dx/Kconfig index 2f891ad..7169c7e 100644 --- a/src/cpu/intel/fsp_model_406dx/Kconfig +++ b/src/cpu/intel/fsp_model_406dx/Kconfig @@ -26,6 +26,7 @@ config CPU_SPECIFIC_OPTIONS def_bool y select PLATFORM_USES_FSP select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/haswell/Kconfig b/src/cpu/intel/haswell/Kconfig index 0597363..e911b17 100644 --- a/src/cpu/intel/haswell/Kconfig +++ b/src/cpu/intel/haswell/Kconfig @@ -7,6 +7,7 @@ if CPU_INTEL_HASWELL config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select BACKUP_DEFAULT_SMM_REGION diff --git a/src/cpu/intel/model_1067x/Kconfig b/src/cpu/intel/model_1067x/Kconfig index 794c205..da8ddc5 100644 --- a/src/cpu/intel/model_1067x/Kconfig +++ b/src/cpu/intel/model_1067x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_1067X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_106cx/Kconfig b/src/cpu/intel/model_106cx/Kconfig index 3b690cf..09acfd9 100644 --- a/src/cpu/intel/model_106cx/Kconfig +++ b/src/cpu/intel/model_106cx/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_106CX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_2065x/Kconfig b/src/cpu/intel/model_2065x/Kconfig index 8185d3a..4a85f09 100644 --- a/src/cpu/intel/model_2065x/Kconfig +++ b/src/cpu/intel/model_2065x/Kconfig @@ -6,6 +6,7 @@ if CPU_INTEL_MODEL_2065X config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_206ax/Kconfig b/src/cpu/intel/model_206ax/Kconfig index afd155a..490849b 100644 --- a/src/cpu/intel/model_206ax/Kconfig +++ b/src/cpu/intel/model_206ax/Kconfig @@ -9,6 +9,7 @@ if CPU_INTEL_MODEL_206AX || CPU_INTEL_MODEL_306AX config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_65x/Kconfig b/src/cpu/intel/model_65x/Kconfig index 7af4ec9..4af7145 100644 --- a/src/cpu/intel/model_65x/Kconfig +++ b/src/cpu/intel/model_65x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_65X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_67x/Kconfig b/src/cpu/intel/model_67x/Kconfig index 1fd514b..2da200e 100644 --- a/src/cpu/intel/model_67x/Kconfig +++ b/src/cpu/intel/model_67x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_67X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_68x/Kconfig b/src/cpu/intel/model_68x/Kconfig index 8a8de0d..d77c9c9 100644 --- a/src/cpu/intel/model_68x/Kconfig +++ b/src/cpu/intel/model_68x/Kconfig @@ -21,6 +21,7 @@ config CPU_INTEL_MODEL_68X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_69x/Kconfig b/src/cpu/intel/model_69x/Kconfig index e1cd658..ff1d5e2 100644 --- a/src/cpu/intel/model_69x/Kconfig +++ b/src/cpu/intel/model_69x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_69X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_6bx/Kconfig b/src/cpu/intel/model_6bx/Kconfig index 46fbf1f..64f193a 100644 --- a/src/cpu/intel/model_6bx/Kconfig +++ b/src/cpu/intel/model_6bx/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_6BX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_6dx/Kconfig b/src/cpu/intel/model_6dx/Kconfig index b1a4c38..edbeac8 100644 --- a/src/cpu/intel/model_6dx/Kconfig +++ b/src/cpu/intel/model_6dx/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_6DX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_6ex/Kconfig b/src/cpu/intel/model_6ex/Kconfig index 5c1b8de..08a5775 100644 --- a/src/cpu/intel/model_6ex/Kconfig +++ b/src/cpu/intel/model_6ex/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_6EX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_6fx/Kconfig b/src/cpu/intel/model_6fx/Kconfig index 0250397..baae196 100644 --- a/src/cpu/intel/model_6fx/Kconfig +++ b/src/cpu/intel/model_6fx/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_6FX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_6xx/Kconfig b/src/cpu/intel/model_6xx/Kconfig index 546ac91..7cafb81 100644 --- a/src/cpu/intel/model_6xx/Kconfig +++ b/src/cpu/intel/model_6xx/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_6XX bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_f0x/Kconfig b/src/cpu/intel/model_f0x/Kconfig index bae4b0e..bfd8d3a 100644 --- a/src/cpu/intel/model_f0x/Kconfig +++ b/src/cpu/intel/model_f0x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_F0X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_f1x/Kconfig b/src/cpu/intel/model_f1x/Kconfig index 85bf5ad..cd4cdcf 100644 --- a/src/cpu/intel/model_f1x/Kconfig +++ b/src/cpu/intel/model_f1x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_F1X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_f2x/Kconfig b/src/cpu/intel/model_f2x/Kconfig index 2871231..5ef1539 100644 --- a/src/cpu/intel/model_f2x/Kconfig +++ b/src/cpu/intel/model_f2x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_F2X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_f3x/Kconfig b/src/cpu/intel/model_f3x/Kconfig index cd3aa5b..7eaa820 100644 --- a/src/cpu/intel/model_f3x/Kconfig +++ b/src/cpu/intel/model_f3x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_F3X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/intel/model_f4x/Kconfig b/src/cpu/intel/model_f4x/Kconfig index cc23f04..4ef60b5 100644 --- a/src/cpu/intel/model_f4x/Kconfig +++ b/src/cpu/intel/model_f4x/Kconfig @@ -1,6 +1,7 @@ config CPU_INTEL_MODEL_F4X bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select SMP diff --git a/src/cpu/qemu-x86/Kconfig b/src/cpu/qemu-x86/Kconfig index ada6e23..46b0e00 100644 --- a/src/cpu/qemu-x86/Kconfig +++ b/src/cpu/qemu-x86/Kconfig @@ -20,5 +20,6 @@ config CPU_QEMU_X86 bool select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 diff --git a/src/cpu/ti/am335x/Kconfig b/src/cpu/ti/am335x/Kconfig index eb60ad1..5ac629d 100644 --- a/src/cpu/ti/am335x/Kconfig +++ b/src/cpu/ti/am335x/Kconfig @@ -1,5 +1,6 @@ config CPU_TI_AM335X select ARCH_BOOTBLOCK_ARMV7 + select ARCH_VERSTAGE_ARMV7 select ARCH_ROMSTAGE_ARMV7 select ARCH_RAMSTAGE_ARMV7 select HAVE_MONOTONIC_TIMER diff --git a/src/cpu/via/c3/Kconfig b/src/cpu/via/c3/Kconfig index 2e4d177..2a54603 100644 --- a/src/cpu/via/c3/Kconfig +++ b/src/cpu/via/c3/Kconfig @@ -6,6 +6,7 @@ if CPU_VIA_C3 config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select UDELAY_TSC diff --git a/src/cpu/via/c7/Kconfig b/src/cpu/via/c7/Kconfig index 10b52bb..3507713 100644 --- a/src/cpu/via/c7/Kconfig +++ b/src/cpu/via/c7/Kconfig @@ -6,6 +6,7 @@ if CPU_VIA_C7 config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select UDELAY_TSC diff --git a/src/cpu/via/nano/Kconfig b/src/cpu/via/nano/Kconfig index 4242dd6..087f9f8 100644 --- a/src/cpu/via/nano/Kconfig +++ b/src/cpu/via/nano/Kconfig @@ -25,6 +25,7 @@ if CPU_VIA_NANO config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select UDELAY_TSC diff --git a/src/mainboard/bifferos/bifferboard/Kconfig b/src/mainboard/bifferos/bifferboard/Kconfig index 9d00f5e..cf08ac8 100644 --- a/src/mainboard/bifferos/bifferboard/Kconfig +++ b/src/mainboard/bifferos/bifferboard/Kconfig @@ -3,6 +3,7 @@ if BOARD_BIFFEROS_BIFFERBOARD config BOARD_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select ROMCC diff --git a/src/soc/intel/baytrail/Kconfig b/src/soc/intel/baytrail/Kconfig index bcaa1ff..e7acbe3 100644 --- a/src/soc/intel/baytrail/Kconfig +++ b/src/soc/intel/baytrail/Kconfig @@ -8,6 +8,7 @@ if SOC_INTEL_BAYTRAIL config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select BACKUP_DEFAULT_SMM_REGION diff --git a/src/soc/intel/broadwell/Kconfig b/src/soc/intel/broadwell/Kconfig index b93216e..1b073ea 100644 --- a/src/soc/intel/broadwell/Kconfig +++ b/src/soc/intel/broadwell/Kconfig @@ -8,6 +8,7 @@ if SOC_INTEL_BROADWELL config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select ALT_CBFS_LOAD_PAYLOAD diff --git a/src/soc/intel/fsp_baytrail/Kconfig b/src/soc/intel/fsp_baytrail/Kconfig index b61fac3..760bc72 100644 --- a/src/soc/intel/fsp_baytrail/Kconfig +++ b/src/soc/intel/fsp_baytrail/Kconfig @@ -28,6 +28,7 @@ if SOC_INTEL_FSP_BAYTRAIL config CPU_SPECIFIC_OPTIONS def_bool y select ARCH_BOOTBLOCK_X86_32 + select ARCH_VERSTAGE_X86_32 select ARCH_ROMSTAGE_X86_32 select ARCH_RAMSTAGE_X86_32 select DYNAMIC_CBMEM diff --git a/src/soc/nvidia/tegra124/Kconfig b/src/soc/nvidia/tegra124/Kconfig index 195261e..ea946e6 100644 --- a/src/soc/nvidia/tegra124/Kconfig +++ b/src/soc/nvidia/tegra124/Kconfig @@ -2,6 +2,7 @@ config SOC_NVIDIA_TEGRA124 bool default n select ARCH_BOOTBLOCK_ARMV4 + select ARCH_VERSTAGE_ARMV7 select ARCH_ROMSTAGE_ARMV7 select ARCH_RAMSTAGE_ARMV7 select HAVE_UART_SPECIAL diff --git a/src/soc/nvidia/tegra124/Makefile.inc b/src/soc/nvidia/tegra124/Makefile.inc index 792bb99..b306412 100644 --- a/src/soc/nvidia/tegra124/Makefile.inc +++ b/src/soc/nvidia/tegra124/Makefile.inc @@ -20,6 +20,8 @@ ifeq ($(CONFIG_BOOTBLOCK_CONSOLE),y) bootblock-$(CONFIG_CONSOLE_SERIAL) += uart.c endif
+verstage-y += verstage.c + romstage-y += cbfs.c romstage-y += cbmem.c romstage-y += clock.c diff --git a/src/soc/nvidia/tegra124/bootblock.c b/src/soc/nvidia/tegra124/bootblock.c index 2857a90..5f1e850 100644 --- a/src/soc/nvidia/tegra124/bootblock.c +++ b/src/soc/nvidia/tegra124/bootblock.c @@ -23,9 +23,9 @@ #include <console/console.h> #include <soc/clock.h> #include <soc/nvidia/tegra/apbmisc.h> - #include "pinmux.h" #include "power.h" +#include "verstage.h"
void main(void) { @@ -72,7 +72,10 @@ void main(void) power_enable_cpu_rail(); power_ungate_cpu();
- entry = cbfs_load_stage(CBFS_DEFAULT_MEDIA, "fallback/romstage"); + if (IS_ENABLED(CONFIG_VBOOT2_VERIFY_FIRMWARE)) + entry = (void *)verstage_vboot_main; + else + entry = cbfs_load_stage(CBFS_DEFAULT_MEDIA, "fallback/romstage");
if (entry) clock_cpu0_config_and_reset(entry); diff --git a/src/soc/nvidia/tegra124/verstage.c b/src/soc/nvidia/tegra124/verstage.c new file mode 100644 index 0000000..234a89d --- /dev/null +++ b/src/soc/nvidia/tegra124/verstage.c @@ -0,0 +1,9 @@ +#include "verstage.h" + +/** + * Stage entry point + */ +void vboot_main(void) +{ + for(;;); +} diff --git a/src/soc/nvidia/tegra124/verstage.h b/src/soc/nvidia/tegra124/verstage.h new file mode 100644 index 0000000..a0bac34 --- /dev/null +++ b/src/soc/nvidia/tegra124/verstage.h @@ -0,0 +1,2 @@ +void vboot_main(void); +void verstage_vboot_main(void); diff --git a/src/vendorcode/google/chromeos/Kconfig b/src/vendorcode/google/chromeos/Kconfig index 8156758..62d991b 100644 --- a/src/vendorcode/google/chromeos/Kconfig +++ b/src/vendorcode/google/chromeos/Kconfig @@ -85,6 +85,14 @@ config VBOOT_VERIFY_FIRMWARE Enabling VBOOT_VERIFY_FIRMWARE will use vboot to verify the ramstage and boot loader.
+config VBOOT2_VERIFY_FIRMWARE + bool "Firmware Verification with vboot2" + default n + depends on CHROMEOS + help + Enabling VBOOT2_VERIFY_FIRMWARE will use vboot2 to verify the romstage + and boot loader. + config EC_SOFTWARE_SYNC bool "Enable EC software sync" default n diff --git a/src/vendorcode/google/chromeos/Makefile.inc b/src/vendorcode/google/chromeos/Makefile.inc index e17f50c..12d35b6 100644 --- a/src/vendorcode/google/chromeos/Makefile.inc +++ b/src/vendorcode/google/chromeos/Makefile.inc @@ -93,3 +93,12 @@ $(VB_LIB): fwlib
endif + +ifeq ($(CONFIG_VBOOT2_VERIFY_FIRMWARE),y) +VERSTAGE_LIB = $(obj)/vendorcode/google/chromeos/verstage.a +$(VERSTAGE_LIB): $$(verstage-objs) + @printf " AR $(subst $(obj)/,,$(@))\n" + $(AR_verstage) rc $@.tmp $(verstage-objs) + @printf " OBJCOPY $(subst $(obj)/,,$(@))\n" + $(OBJCOPY_verstage) --prefix-symbols=verstage_ $@.tmp $@ +endif diff --git a/toolchain.inc b/toolchain.inc index 73f0832..f8c7ea4 100644 --- a/toolchain.inc +++ b/toolchain.inc @@ -51,7 +51,7 @@ HOSTCXX:=CCC_CXX="$(HOSTCXX)" $(CXX) ROMCC=CCC_CC="$(ROMCC_BIN)" $(CC) endif
-COREBOOT_STANDARD_STAGES := bootblock romstage ramstage +COREBOOT_STANDARD_STAGES := bootblock verstage romstage ramstage
ARCHDIR-i386 := x86 ARCHDIR-x86_32 := x86
