Attention is currently required from: Jason Glenesk, Marshall Dawson, Paul Menzel. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson,
https://review.coreboot.org/c/coreboot/+/58224
Change subject: soc/amd/common/block/include/psp_efs: use unsigned type for bitfield ......................................................................
For 1 bit long bit fields an unsigned type should be used. In this case uint32_t is used instead of a generic unsigned int for both consistency reasons with the rest of the file and to clarify that the bits will be packed into a 32 bit memory location.
TEST=Resulting image of a timeless build for google/guybrush results in identical binary.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ic630d1709174d90336746bc37da504437c12643c --- M src/soc/amd/common/block/include/amdblocks/psp_efs.h 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/58224/2
