Hello Patrick Rudolph, Philippe Mathieu-Daudé, Paul Menzel, build bot (Jenkins), Nico Huber,
https://review.coreboot.org/18504
to look at the new patch set (#18).
Change subject: nb/x4x: Add ramstage IGD disable function ......................................................................
This disables VGA cycles on IGD when an external VGA device is found. This allows PCI or PCIe devices to be the 'main' VGA device if found, while the IGD is still available.
TESTED on ga-g41m-es2l: SeaBIOS shows payload on external GPU while linux (4.10) can use both as a framebuffer simultaneously without any extra configuration.
Change-Id: I74890918feb0f1ff6b971c4aaa96f1f7b75266ac Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/northbridge/intel/x4x/gma.c 1 file changed, 11 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/04/18504/18
