Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/23519
Change subject: amd/stoneyridge: Put stage cache into TSEG ......................................................................
Add a function to allow an external region to be located in TSEG. Select the option to use memory outside of cbmem. Increase the size reserved in TSEG.
Change-Id: Ic1073af04475d862753136c9e14e2b2dde31fe66 Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/stoneyridge/Kconfig M src/soc/amd/stoneyridge/ramtop.c 2 files changed, 12 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/23519/1
diff --git a/src/soc/amd/stoneyridge/Kconfig b/src/soc/amd/stoneyridge/Kconfig index 148ca3f..7975523 100644 --- a/src/soc/amd/stoneyridge/Kconfig +++ b/src/soc/amd/stoneyridge/Kconfig @@ -55,6 +55,7 @@ select BOOTBLOCK_CONSOLE select BOOT_DEVICE_SUPPORTS_WRITES if BOOT_DEVICE_SPI_FLASH select RELOCATABLE_MODULES + select CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM select PARALLEL_MP select PARALLEL_MP_AP_WORK select HAVE_SMI_HANDLER @@ -295,7 +296,7 @@
config SMM_RESERVED_SIZE hex - default 0x100000 + default 0x140000
config ACPI_CPU_STRING string diff --git a/src/soc/amd/stoneyridge/ramtop.c b/src/soc/amd/stoneyridge/ramtop.c index e676465..ca7511b 100644 --- a/src/soc/amd/stoneyridge/ramtop.c +++ b/src/soc/amd/stoneyridge/ramtop.c @@ -21,6 +21,7 @@ #include <cpu/x86/msr.h> #include <cpu/amd/mtrr.h> #include <cbmem.h> +#include <stage_cache.h> #include <soc/northbridge.h> #include <soc/southbridge.h>
@@ -56,6 +57,15 @@ return CONFIG_SMM_TSEG_SIZE; }
+void stage_cache_external_region(void **base, size_t *size) +{ + if (smm_subregion(SMM_SUBREGION_CACHE, base, size)) { + printk(BIOS_ERR, "ERROR: No cache SMM subregion.\n"); + *base = NULL; + *size = 0; + } +} + void smm_region_info(void **start, size_t *size) { *start = (void *)smm_region_start();
