Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61423 )
Change subject: lib/spd_cache.c: Drop comparison to {true, false} ......................................................................
Change-Id: I0ef8c0159c99606aad537fd5e14d3c74e32651d8 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/61423 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/lib/spd_cache.c 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/src/lib/spd_cache.c b/src/lib/spd_cache.c index be36141..44830a8 100644 --- a/src/lib/spd_cache.c +++ b/src/lib/spd_cache.c @@ -154,21 +154,21 @@ bool dimm_present_in_cache; bool dimm_changed = false; /* Check if the dimm is the same with last system boot. */ - for (i = 0; i < SC_SPD_NUMS && dimm_changed == false; i++) { + for (i = 0; i < SC_SPD_NUMS && !dimm_changed; i++) { /* Return true if any error happened here. */ if (get_spd_sn(blk->addr_map[i], &sn) == CB_ERR) return true; dimm_present_in_cache = get_cached_dimm_present(spd_cache, i); /* Dimm is not present now. */ if (sn == 0xffffffff) { - if (dimm_present_in_cache == false) + if (!dimm_present_in_cache) printk(BIOS_NOTICE, "SPD_CACHE: DIMM%d is not present\n", i); else { printk(BIOS_NOTICE, "SPD_CACHE: DIMM%d lost\n", i); dimm_changed = true; } } else { /* Dimm is present now. */ - if (dimm_present_in_cache == true) { + if (dimm_present_in_cache) { if (memcmp(&sn, spd_cache + SC_SPD_OFFSET(i) + DDR4_SPD_SN_OFF, SPD_SN_LEN) == 0) printk(BIOS_NOTICE, "SPD_CACHE: DIMM%d is the same\n", @@ -195,7 +195,7 @@
/* Find the first present SPD */ for (i = 0; i < SC_SPD_NUMS; i++) - if (get_cached_dimm_present(spd_cache, i) == true) + if (get_cached_dimm_present(spd_cache, i)) break;
if (i == SC_SPD_NUMS) { @@ -211,7 +211,7 @@ blk->len = SPD_PAGE_LEN;
for (i = 0; i < SC_SPD_NUMS; i++) - if (get_cached_dimm_present(spd_cache, i) == true) + if (get_cached_dimm_present(spd_cache, i)) blk->spd_array[i] = spd_cache + SC_SPD_OFFSET(i); else blk->spd_array[i] = NULL;
