Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6465
commit eeb8e813fdf0d9a7cbe69ca9446c85a284e062d2 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Sat Aug 2 20:45:13 2014 +1000
superio/smsc/sio1036: Clean up RAMstage superio.c component
Remove spurious includes, unused variables and some wasted new lines. Re-organise things to be consistent with other superio's.
Change-Id: I959bab2f7a83a1b9160d7f010a0de9638b30cf07 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/superio/smsc/sio1036/superio.c | 37 +++++++++++-------------------------- 1 file changed, 11 insertions(+), 26 deletions(-)
diff --git a/src/superio/smsc/sio1036/superio.c b/src/superio/smsc/sio1036/superio.c index d2bfd8d..208bc85 100644 --- a/src/superio/smsc/sio1036/superio.c +++ b/src/superio/smsc/sio1036/superio.c @@ -24,20 +24,16 @@ #include <device/pnp.h> #include <superio/conf_mode.h> #include <console/console.h> -#include <device/smbus.h> -#include <string.h> -#include <pc80/keyboard.h> #include <stdlib.h> -#include "sio1036.h"
-/* Forward declarations */ -static void enable_dev(device_t dev); -static void sio1036_init(device_t dev); +#include "sio1036.h"
-struct chip_operations superio_smsc_sio1036_ops = { - CHIP_NAME("SMSC SIO1036 Super I/O") - .enable_dev = enable_dev -}; +static void sio1036_init(device_t dev) +{ + if (!dev->enabled) { + return; + } +}
static struct device_operations ops = { .read_resources = pnp_read_resources, @@ -57,19 +53,8 @@ static void enable_dev(device_t dev) pnp_enable_devices(dev, &pnp_ops, ARRAY_SIZE(pnp_dev_info), pnp_dev_info); }
-static void sio1036_init(device_t dev) -{ - struct resource *res0, *res1; - - - - if (!dev->enabled) { - return; - } - - switch(dev->path.pnp.device) { +struct chip_operations superio_smsc_sio1036_ops = { + CHIP_NAME("SMSC SIO1036 Super I/O") + .enable_dev = enable_dev +};
- default: - break; - } -}
