Yu-Ping Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49196 )
Change subject: ec/google/chromeec: Update ec_commands.h ......................................................................
This change copies ec_commands.h directly from the Chromium OS EC repo at SHA afffc28f2, with the exception of changing the copyright header to SPDX format.
Change-Id: Ie02e0295312050e803a7d701ec4eed1dadfa6c9a Signed-off-by: Yu-Ping Wu yupingso@chromium.org --- M src/ec/google/chromeec/ec_commands.h 1 file changed, 342 insertions(+), 43 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/49196/1
diff --git a/src/ec/google/chromeec/ec_commands.h b/src/ec/google/chromeec/ec_commands.h index fb83d60..39e1cec 100644 --- a/src/ec/google/chromeec/ec_commands.h +++ b/src/ec/google/chromeec/ec_commands.h @@ -29,7 +29,10 @@ #include "compile_time_macros.h"
#else +/* If BUILD_ASSERT isn't already defined, make it a no-op */ +#ifndef BUILD_ASSERT #define BUILD_ASSERT(_cond) +#endif /* !BUILD_ASSERT */ #endif /* CHROMIUM_EC */
#ifdef __KERNEL__ @@ -50,6 +53,21 @@ #define BIT_ULL(nr) (1ULL << (nr)) #endif
+/* + * When building Zephyr, this file ends up being included before Zephyr's + * include/sys/util.h so causes a warning there. We don't want to add an #ifdef + * in that file since it won't be accepted upstream. So work around it here. + */ +#ifndef CONFIG_ZEPHYR +#ifndef GENMASK +#define GENMASK(h, l) (((BIT(h) << 1) - 1) ^ (BIT(l) - 1)) +#endif + +#ifndef GENMASK_ULL +#define GENMASK_ULL(h, l) (((BIT_ULL(h) << 1) - 1) ^ (BIT_ULL(l) - 1)) +#endif +#endif + #endif /* __KERNEL__ */
/* @@ -1388,7 +1406,7 @@ */ EC_FEATURE_REFINED_TABLET_MODE_HYSTERESIS = 37, /* - * Early Firmware Selection ver.2. Enabled by VBOOT_EFS2 config option. + * Early Firmware Selection ver.2. Enabled by CONFIG_VBOOT_EFS2. * Note this is a RO feature. So, a query (EC_CMD_GET_FEATURES) should * be sent to RO to be precise. */ @@ -1397,6 +1415,18 @@ EC_FEATURE_SCP = 39, /* The MCU is an Integrated Sensor Hub */ EC_FEATURE_ISH = 40, + /* New TCPMv2 TYPEC_ prefaced commands supported */ + EC_FEATURE_TYPEC_CMD = 41, + /* + * The EC will wait for direction from the AP to enter Type-C alternate + * modes or USB4. + */ + EC_FEATURE_TYPEC_REQUIRE_AP_MODE_ENTRY = 42, + /* + * The EC will wait for an acknowledge from the AP after setting the + * mux. + */ + EC_FEATURE_TYPEC_MUX_REQUIRE_AP_ACK = 43, };
#define EC_FEATURE_MASK_0(event_code) BIT(event_code % 32) @@ -2599,6 +2629,11 @@ MOTIONSENSE_ORIENTATION_UNKNOWN = 4, };
+struct ec_response_activity_data { + uint8_t activity; /* motionsensor_activity */ + uint8_t state; +} __ec_todo_packed; + struct ec_response_motion_sensor_data { /* Flags for each sensor. */ uint8_t flags; @@ -2606,17 +2641,16 @@ uint8_t sensor_num; /* Each sensor is up to 3-axis. */ union { - int16_t data[3]; + int16_t data[3]; /* for sensors using unsigned data */ - uint16_t udata[3]; + uint16_t udata[3]; struct __ec_todo_packed { - uint16_t reserved; - uint32_t timestamp; + uint16_t reserved; + uint32_t timestamp; }; struct __ec_todo_unpacked { - uint8_t activity; /* motionsensor_activity */ - uint8_t state; - int16_t add_info[2]; + struct ec_response_activity_data activity_data; + int16_t add_info[2]; }; }; } __ec_todo_packed; @@ -2864,8 +2898,19 @@ /* Ignored, used for alignment. */ uint8_t reserved;
- /* Individual component values to spoof. */ - int16_t components[3]; + union { + /* Individual component values to spoof. */ + int16_t components[3]; + + /* Used when spoofing an activity */ + struct { + /* enum motionsensor_activity */ + uint8_t activity_num; + + /* spoof activity state */ + uint8_t activity_state; + }; + }; } spoof;
/* Used for MOTIONSENSE_CMD_TABLET_MODE_LID_ANGLE. */ @@ -3768,6 +3813,7 @@ #define EC_MKBP_LID_OPEN 0 #define EC_MKBP_TABLET_MODE 1 #define EC_MKBP_BASE_ATTACHED 2 +#define EC_MKBP_FRONT_PROXIMITY 3
/* Run keyboard factory test scanning */ #define EC_CMD_KEYBOARD_FACTORY_TEST 0x0068 @@ -4637,6 +4683,7 @@ EC_DEVICE_EVENT_TRACKPAD, EC_DEVICE_EVENT_DSP, EC_DEVICE_EVENT_WIFI, + EC_DEVICE_EVENT_WLC, };
enum ec_device_event_param { @@ -5183,6 +5230,7 @@ EC_REBOOT_DISABLE_JUMP = 5, /* Disable jump until next reboot */ EC_REBOOT_HIBERNATE = 6, /* Hibernate EC */ EC_REBOOT_HIBERNATE_CLEAR_AP_OFF = 7, /* and clears AP_IDLE flag */ + EC_REBOOT_COLD_AP_OFF = 8, /* Cold-reboot and don't boot AP */ };
/* Flags for ec_params_reboot_ec.reboot_flags */ @@ -5395,10 +5443,6 @@ /* Active Link Uni-Direction */ #define USB_PD_CTRL_ACTIVE_LINK_UNIDIR BIT(3)
-/* - * Underdevelopement : - * Please remove this tag if using _v2 outside platform/ec - */ struct ec_response_usb_pd_control_v2 { uint8_t enabled; uint8_t role; @@ -5408,8 +5452,7 @@ uint8_t dp_mode; /* Current DP pin mode (MODE_DP_PIN_[A-E]) */ uint8_t reserved; /* Reserved for future use */ uint8_t control_flags; /* USB_PD_CTRL_*flags */ - /* TODO: b:158234949 Add definitions for cable speed */ - uint8_t cable_speed; /* USB_R30_SS/TBT_SS_* cable speed */ + uint8_t cable_speed; /* TBT_SS_* cable speed */ uint8_t cable_gen; /* TBT_GEN3_* cable rounded support */ } __ec_align1;
@@ -5833,7 +5876,7 @@ */ #define EC_CMD_GET_UPTIME_INFO 0x0121
-/* Reset causes */ +/* EC reset causes */ #define EC_RESET_FLAG_OTHER BIT(0) /* Other known reason */ #define EC_RESET_FLAG_RESET_PIN BIT(1) /* Reset pin asserted */ #define EC_RESET_FLAG_BROWNOUT BIT(2) /* Brownout */ @@ -5862,6 +5905,72 @@ #define EC_RESET_FLAG_AP_IDLE BIT(21) /* Leave alone AP */ #define EC_RESET_FLAG_INITIAL_PWR BIT(22) /* EC had power, then was reset */
+/* + * Reason codes used by the AP after a shutdown to figure out why it was reset + * by the EC. These are sent in EC commands. Therefore, to maintain protocol + * compatibility: + * - New entries must be inserted prior to the _COUNT field + * - If an existing entry is no longer in service, it must be replaced with a + * RESERVED entry instead. + * - The semantic meaning of an entry should not change. + * - Do not exceed 2^15 - 1 for reset reasons or 2^16 - 1 for shutdown reasons. + */ +enum chipset_reset_reason { + CHIPSET_RESET_BEGIN = 0, + CHIPSET_RESET_UNKNOWN = CHIPSET_RESET_BEGIN, + /* Custom reason defined by a board.c or baseboard.c file */ + CHIPSET_RESET_BOARD_CUSTOM, + /* Believe that the AP has hung */ + CHIPSET_RESET_HANG_REBOOT, + /* Reset by EC console command */ + CHIPSET_RESET_CONSOLE_CMD, + /* Reset by EC host command */ + CHIPSET_RESET_HOST_CMD, + /* Keyboard module reset key combination */ + CHIPSET_RESET_KB_SYSRESET, + /* Keyboard module warm reboot */ + CHIPSET_RESET_KB_WARM_REBOOT, + /* Debug module warm reboot */ + CHIPSET_RESET_DBG_WARM_REBOOT, + /* I cannot self-terminate. You must lower me into the steel. */ + CHIPSET_RESET_AP_REQ, + /* Reset as side-effect of startup sequence */ + CHIPSET_RESET_INIT, + /* EC detected an AP watchdog event. */ + CHIPSET_RESET_AP_WATCHDOG, + + CHIPSET_RESET_COUNT, +}; + +/* + * AP hard shutdowns are logged on the same path as resets. + */ +enum chipset_shutdown_reason { + CHIPSET_SHUTDOWN_BEGIN = BIT(15), + CHIPSET_SHUTDOWN_POWERFAIL = CHIPSET_SHUTDOWN_BEGIN, + /* Forcing a shutdown as part of EC initialization */ + CHIPSET_SHUTDOWN_INIT, + /* Custom reason on a per-board basis. */ + CHIPSET_SHUTDOWN_BOARD_CUSTOM, + /* This is a reason to inhibit startup, not cause shut down. */ + CHIPSET_SHUTDOWN_BATTERY_INHIBIT, + /* A power_wait_signal is being asserted */ + CHIPSET_SHUTDOWN_WAIT, + /* Critical battery level. */ + CHIPSET_SHUTDOWN_BATTERY_CRIT, + /* Because you told me to. */ + CHIPSET_SHUTDOWN_CONSOLE_CMD, + /* Forcing a shutdown to effect entry to G3. */ + CHIPSET_SHUTDOWN_G3, + /* Force shutdown due to over-temperature. */ + CHIPSET_SHUTDOWN_THERMAL, + /* Force a chipset shutdown from the power button through EC */ + CHIPSET_SHUTDOWN_BUTTON, + + CHIPSET_SHUTDOWN_COUNT, +}; + + struct ec_response_uptime_info { /* * Number of milliseconds since the last EC boot. Sysjump resets @@ -5889,10 +5998,7 @@
/* Empty log entries have both the cause and timestamp set to zero. */ struct ap_reset_log_entry { - /* - * See include/chipset.h: enum chipset_{reset,shutdown}_reason - * for details. - */ + /* See enum chipset_{reset,shutdown}_reason for details. */ uint16_t reset_cause;
/* Reserved for protocol growth. */ @@ -6012,13 +6118,21 @@ * * This command is used for validation purpose, where the AP needs to be * returned back to S0 state from G3 state without using the servo to trigger - * wake events.For this,there is no request or response struct. - * - * Order of command usage: - * ectool reboot_ap_on_g3 && shutdown -h now + * wake events. + * - With command version 0: + * AP reboots immediately from G3 + * command usage: ectool reboot_ap_on_g3 && shutdown -h now + * - With command version 1: + * AP reboots after the user specified delay + * command usage: ectool reboot_ap_on_g3 [<delay>] && shutdown -h now */ #define EC_CMD_REBOOT_AP_ON_G3 0x0127
+struct ec_params_reboot_ap_on_g3_v1 { + /* configurable delay in seconds in G3 state */ + uint32_t reboot_ap_at_g3_delay; +} __ec_align4; + /*****************************************************************************/ /* Get PD port capabilities * @@ -6366,6 +6480,14 @@ enum typec_control_command { TYPEC_CONTROL_COMMAND_EXIT_MODES, TYPEC_CONTROL_COMMAND_CLEAR_EVENTS, + TYPEC_CONTROL_COMMAND_ENTER_MODE, +}; + +/* Modes (USB or alternate) that a type-C port may enter. */ +enum typec_mode { + TYPEC_MODE_DP, + TYPEC_MODE_TBT, + TYPEC_MODE_USB4, };
struct ec_params_typec_control { @@ -6380,6 +6502,7 @@ */ union { uint32_t clear_events_mask; + uint8_t mode_to_enter; /* enum typec_mode */ uint8_t placeholder[128]; }; } __ec_align1; @@ -6393,9 +6516,6 @@ * EC_CMD_USB_PD_CONTROL command. * * This also combines in the EC_CMD_USB_PD_MUX_INFO flags. - * - * Version 0 of command is under development - * TODO(b/167700356): Remove this statement when version 0 is finalized */ #define EC_CMD_TYPEC_STATUS 0x0133
@@ -6469,33 +6589,183 @@ #define PD_STATUS_EVENT_SOP_DISC_DONE BIT(0) #define PD_STATUS_EVENT_SOP_PRIME_DISC_DONE BIT(1)
+/* + * Encode and decode for BCD revision response + * + * Note: the major revision set is written assuming that the value given is the + * Specification Revision from the PD header, which currently only maps to PD + * 1.0-3.0 with the major revision being one greater than the binary value. + */ +#define PD_STATUS_REV_SET_MAJOR(r) ((r + 1) << 12) +#define PD_STATUS_REV_GET_MAJOR(r) ((r >> 12) & 0xF) +#define PD_STATUS_REV_GET_MINOR(r) ((r >> 8) & 0xF) + +/* + * Decode helpers for Source and Sink Capability PDOs + * + * Note: The Power Delivery Specification should be considered the ultimate + * source of truth on the decoding of these PDOs + */ +#define PDO_TYPE_FIXED (0 << 30) +#define PDO_TYPE_BATTERY (1 << 30) +#define PDO_TYPE_VARIABLE (2 << 30) +#define PDO_TYPE_AUGMENTED (3 << 30) +#define PDO_TYPE_MASK (3 << 30) + +/* + * From Table 6-9 and Table 6-14 PD Rev 3.0 Ver 2.0 + * + * <31:30> : Fixed Supply + * <29> : Dual-Role Power + * <28> : SNK/SRC dependent + * <27> : Unconstrained Power + * <26> : USB Communications Capable + * <25> : Dual-Role Data + * <24:20> : SNK/SRC dependent + * <19:10> : Voltage in 50mV Units + * <9:0> : Maximum Current in 10mA units + */ +#define PDO_FIXED_DUAL_ROLE BIT(29) +#define PDO_FIXED_UNCONSTRAINED BIT(27) +#define PDO_FIXED_COMM_CAP BIT(26) +#define PDO_FIXED_DATA_SWAP BIT(25) +#define PDO_FIXED_FRS_CURR_MASK GENMASK(24, 23) /* Sink Cap only */ +#define PDO_FIXED_VOLTAGE(p) ((p >> 10 & 0x3FF) * 50) +#define PDO_FIXED_CURRENT(p) ((p & 0x3FF) * 10) + +/* + * From Table 6-12 and Table 6-16 PD Rev 3.0 Ver 2.0 + * + * <31:30> : Battery + * <29:20> : Maximum Voltage in 50mV units + * <19:10> : Minimum Voltage in 50mV units + * <9:0> : Maximum Allowable Power in 250mW units + */ +#define PDO_BATT_MAX_VOLTAGE(p) ((p >> 20 & 0x3FF) * 50) +#define PDO_BATT_MIN_VOLTAGE(p) ((p >> 10 & 0x3FF) * 50) +#define PDO_BATT_MAX_POWER(p) ((p & 0x3FF) * 250) + +/* + * From Table 6-11 and Table 6-15 PD Rev 3.0 Ver 2.0 + * + * <31:30> : Variable Supply (non-Battery) + * <29:20> : Maximum Voltage in 50mV units + * <19:10> : Minimum Voltage in 50mV units + * <9:0> : Operational Current in 10mA units + */ +#define PDO_VAR_MAX_VOLTAGE(p) ((p >> 20 & 0x3FF) * 50) +#define PDO_VAR_MIN_VOLTAGE(p) ((p >> 10 & 0x3FF) * 50) +#define PDO_VAR_MAX_CURRENT(p) ((p & 0x3FF) * 10) + +/* + * From Table 6-13 and Table 6-17 PD Rev 3.0 Ver 2.0 + * + * Note this type is reserved in PD 2.0, and only one type of APDO is + * supported as of the cited version. + * + * <31:30> : Augmented Power Data Object + * <29:28> : Programmable Power Supply + * <27> : PPS Power Limited + * <26:25> : Reserved + * <24:17> : Maximum Voltage in 100mV increments + * <16> : Reserved + * <15:8> : Minimum Voltage in 100mV increments + * <7> : Reserved + * <6:0> : Maximum Current in 50mA increments + */ +#define PDO_AUG_MAX_VOLTAGE(p) ((p >> 17 & 0xFF) * 100) +#define PDO_AUG_MIN_VOLTAGE(p) ((p >> 8 & 0xFF) * 100) +#define PDO_AUG_MAX_CURRENT(p) ((p & 0x7F) * 50) + struct ec_params_typec_status { uint8_t port; } __ec_align1;
struct ec_response_typec_status { - uint8_t pd_enabled; /* PD communication enabled - bool */ - uint8_t dev_connected; /* Device connected - bool */ - uint8_t sop_connected; /* Device is SOP PD capable - bool */ - uint8_t reserved1; /* Reserved for future use */ + uint8_t pd_enabled; /* PD communication enabled - bool */ + uint8_t dev_connected; /* Device connected - bool */ + uint8_t sop_connected; /* Device is SOP PD capable - bool */ + uint8_t source_cap_count; /* Number of Source Cap PDOs */
- uint8_t power_role; /* enum pd_power_role */ - uint8_t data_role; /* enum pd_data_role */ - uint8_t vconn_role; /* enum pd_vconn_role */ - uint8_t reserved2; /* Reserved for future use */ + uint8_t power_role; /* enum pd_power_role */ + uint8_t data_role; /* enum pd_data_role */ + uint8_t vconn_role; /* enum pd_vconn_role */ + uint8_t sink_cap_count; /* Number of Sink Cap PDOs */
- uint8_t polarity; /* enum tcpc_cc_polarity */ - uint8_t cc_state; /* enum pd_cc_states */ - uint8_t dp_pin; /* DP pin mode (MODE_DP_IN_[A-E]) */ - uint8_t mux_state; /* USB_PD_MUX* - encoded USB mux state */ + uint8_t polarity; /* enum tcpc_cc_polarity */ + uint8_t cc_state; /* enum pd_cc_states */ + uint8_t dp_pin; /* DP pin mode (MODE_DP_IN_[A-E]) */ + uint8_t mux_state; /* USB_PD_MUX* - encoded mux state */
- char tc_state[32]; /* TC state name */ + char tc_state[32]; /* TC state name */
- uint32_t events; /* PD_STATUS_EVENT bitmask */ + uint32_t events; /* PD_STATUS_EVENT bitmask */
- /* TODO(b/167700356): Add revisions and source cap PDOs */ + /* + * BCD PD revisions for partners + * + * The format has the PD major reversion in the upper nibble, and PD + * minor version in the next nibble. Following two nibbles are + * currently 0. + * ex. PD 3.2 would map to 0x3200 + * + * PD major/minor will be 0 if no PD device is connected. + */ + uint16_t sop_revision; + uint16_t sop_prime_revision; + + uint32_t source_cap_pdos[7]; /* Max 7 PDOs can be present */ + + uint32_t sink_cap_pdos[7]; /* Max 7 PDOs can be present */ } __ec_align1;
+/** + * Get the number of peripheral charge ports + */ +#define EC_CMD_PCHG_COUNT 0x0134 + +#define EC_PCHG_MAX_PORTS 8 + +struct ec_response_pchg_count { + uint8_t port_count; +} __ec_align1; + +/** + * Get the status of a peripheral charge port + */ +#define EC_CMD_PCHG 0x0135 + +struct ec_params_pchg { + uint8_t port; +} __ec_align1; + +struct ec_response_pchg { + uint32_t error; /* enum pchg_error */ + uint8_t state; /* enum pchg_state state */ + uint8_t battery_percentage; +} __ec_align2; + +enum pchg_state { + /* Charger is reset and not initialized. */ + PCHG_STATE_RESET = 0, + /* Charger is initialized or disabled. */ + PCHG_STATE_INITIALIZED, + /* Charger is enabled and ready to detect a device. */ + PCHG_STATE_ENABLED, + /* Device is detected in proximity. */ + PCHG_STATE_DETECTED, + /* Device is being charged. */ + PCHG_STATE_CHARGING, +}; + +#define EC_PCHG_STATE_TEXT { \ + [PCHG_STATE_RESET] = "RESET", \ + [PCHG_STATE_INITIALIZED] = "INITIALIZED", \ + [PCHG_STATE_ENABLED] = "ENABLED", \ + [PCHG_STATE_DETECTED] = "DETECTED", \ + [PCHG_STATE_CHARGING] = "CHARGING", \ + } + /*****************************************************************************/ /* The command range 0x200-0x2FF is reserved for Rotor. */
@@ -6841,6 +7111,28 @@ uint32_t cycle_count; } __ec_align4;
+/** + * struct ec_response_battery_static_info_v1 - hostcmd v1 battery static info + * Equivalent to struct ec_response_battery_static_info, but with longer + * strings. + * @design_capacity: battery design capacity (in mAh) + * @design_voltage: battery design voltage (in mV) + * @cycle_count: battery cycle count + * @manufacturer_ext: battery manufacturer string + * @model_ext: battery model string + * @serial_ext: battery serial number string + * @type_ext: battery type string + */ +struct ec_response_battery_static_info_v1 { + uint16_t design_capacity; + uint16_t design_voltage; + uint32_t cycle_count; + char manufacturer_ext[12]; + char model_ext[12]; + char serial_ext[12]; + char type_ext[12]; +} __ec_align4; + /* * Get battery dynamic information, i.e. information that is likely to change * every time it is read. @@ -6896,6 +7188,13 @@ uint8_t allow_charging; } __ec_align_size1;
+/* Get ACK from the USB-C SS muxes */ +#define EC_CMD_USB_PD_MUX_ACK 0x0603 + +struct ec_params_usb_pd_mux_ack { + uint8_t port; /* USB-C port number */ +} __ec_align1; + /*****************************************************************************/ /* * Reserve a range of host commands for board-specific, experimental, or
Attention is currently required from: Yu-Ping Wu. Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49196 )
Patch Set 1: Code-Review+2
Attention is currently required from: Yu-Ping Wu. Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49196 )
Patch Set 1:
Patchset:
PS1: food for thought: should we move the ec_commands.h file into src/vendorcode/* so we can copy it verbatim, and only add a forwarding header here (#include "vendorcode/...")?
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/49196 )
Change-Id: Ie02e0295312050e803a7d701ec4eed1dadfa6c9a Signed-off-by: Yu-Ping Wu yupingso@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/49196 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/ec/google/chromeec/ec_commands.h 1 file changed, 342 insertions(+), 43 deletions(-)
Yu-Ping Wu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49196 )
Patch Set 2:
Patchset:
PS1:
food for thought: should we move the ec_commands. […]
Or we can put a script in platform/dev/contrib/ to do the job for us, since even with your proposal we still need to manually copy the file. What do you think?
Patch Set 2:
Patchset:
PS1:
Or we can put a script in platform/dev/contrib/ to do the job for us, since even with your proposal […]
I think Patrick's point is that in vendorcode/, we don't need to change the license header to SPDX style; since this isn't something we do a lot, it doesn't matter to me too much how this is done
