Attention is currently required from: Arthur Heymans, Felix Singer, Subrata Banik, Tim Wawrzynczak, Sridhar Siricilla, Angel Pons, Lean Sheng Tan, Werner Zeh, Patrick Rudolph, EricR Lai.
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/60405 )
Change subject: soc/intel/common/cse: Add `finalize` operation for CSE
Patch Set 25:
File src/soc/intel/common/block/cse/cse.c:
https://review.coreboot.org/c/coreboot/+/60405/comment/e8383f03_92a534d1
PS24, Line 1195: static void cse_final(struct device *dev)
: if (CONFIG(SKIP_FSP_NOTIFY_PHASE_READY_TO_BOOT)) {
: cse_send_end_of_post();
: cse_control_global_reset_lock();
: if (CONFIG(DISABLE_HECI1_AT_PRE_BOOT)) {
: cse_set_to_d0i3();
: heci1_disable();
: if (CONFIG(SKIP_FSP_NOTIFY_PHASE_END_OF_FIRMWARE))
: heci_set_to_d0i3();
Yeah agreed with Subrata here - current naming conventions are aligned to FSP API calls, just simple […]
CB_INTEL_SOC_RUN_OPS_BEFORE_PAYLOAD_LAUNCH?? seriously?! A Kconfig option that says coreboot runs its own code before launching a payload?? Sorry but that is just ridiculous. Coreboot integrates FSP and not the other way around so there should be no flags to indicate that coreboot runs it's own code rather than FSP.
I would even argue to reverse the current flags: let the FSP code conditionally run with CONFIG_USE_FSP_NOTIFY_PHASE_END_OF_FIRMWARE & CONFIG_USE_FSP_NOTIFY_READY_TO_BOOT and skip the native code when those are selected. This is consistent with CONFIG_USE_INTEL_FSP_MP_INIT, where using coreboot MP init is also default.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I70bde33f77026e8be165ff082defe3cab6686ec7
Gerrit-Change-Number: 60405
Gerrit-PatchSet: 25
Gerrit-Owner: Subrata Banik
subratabanik@google.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: EricR Lai
ericr_lai@compal.corp-partner.google.com
Gerrit-Reviewer: Felix Singer
felixsinger@posteo.net
Gerrit-Reviewer: Lean Sheng Tan
sheng.tan@9elements.com
Gerrit-Reviewer: Patrick Rudolph
siro@das-labor.org
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Werner Zeh
werner.zeh@siemens.com
no-reply@coreboot.org
Gerrit-CC: Arthur Heymans
arthur.heymans@9elements.com
arthur@aheymans.xyz
Gerrit-CC: Paul Menzel
paulepanter@mailbox.org
Gerrit-CC: Rizwan Qureshi
rizwan.qureshi@intel.com
Gerrit-CC: Sridhar Siricilla
sridhar.siricilla@intel.com
Gerrit-Attention: Arthur Heymans
Gerrit-Attention: Felix Singer
Gerrit-Attention: Subrata Banik
Gerrit-Attention: Tim Wawrzynczak
Gerrit-Attention: Sridhar Siricilla
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
Gerrit-Attention: Lean Sheng Tan
Gerrit-Attention: Werner Zeh
Gerrit-Attention: Patrick Rudolph
siro@das-labor.org
Gerrit-Attention: EricR Lai
Gerrit-Comment-Date: Tue, 08 Feb 2022 18:50:54 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Subrata Banik
Comment-In-Reply-To: Sridhar Siricilla
Comment-In-Reply-To: Lean Sheng Tan
Gerrit-MessageType: comment
