HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39907 )
Change subject: superio/winbond/{w83627hf,w83977tf}: Use macro ......................................................................
Change-Id: I3ac8dd2ba089970a18b460769dfc3fabf9395709 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/superio/winbond/w83627hf/acpi/superio.asl M src/superio/winbond/w83977tf/acpi/superio.asl 2 files changed, 135 insertions(+), 133 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/39907/1
diff --git a/src/superio/winbond/w83627hf/acpi/superio.asl b/src/superio/winbond/w83627hf/acpi/superio.asl index d5c5ec9..e31d685 100644 --- a/src/superio/winbond/w83627hf/acpi/superio.asl +++ b/src/superio/winbond/w83627hf/acpi/superio.asl @@ -43,6 +43,8 @@ * http://www.itox.com/pages/support/wdt/W83627HF.pdf */
+#include <superio/acpi/pnp.asl> + Device(SIO) { Name (_HID, EisaId("PNP0A05")) Name (_STR, Unicode("Winbond W83627HF SuperIO")) @@ -147,7 +149,7 @@ Parameter is the LDN which should be accessed. Values >= 0xFF mean no LDN switch should be done. */ - Method (ENCM, 1) + Method (ENTER_CONFIG_MODE, 1) { Acquire (CRMX, 0xFFFF) Store (0x87, ADDR) @@ -160,7 +162,7 @@ /* Exit configuration mode (and release mutex) Method must be run after accessing the configuration region. */ - Method (EXCM) + Method (EXIT_CONFIG_MODE) { Store (0xAA, ADDR) Release (CRMX) @@ -168,25 +170,25 @@
/* PM: indicate IPD (Immediate Power Down) bit state as D0/D3 */ Method (_PSC) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (IPD, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } }
/* PM: Switch to D0 by setting IPD low */ Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, IPD) - EXCM () + EXIT_CONFIG_MODE () }
/* PM: Switch to D3 by setting IPD high */ Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, IPD) - EXCM () + EXIT_CONFIG_MODE () }
#ifndef NO_W83627HF_FDC @@ -199,7 +201,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (0) + ENTER_CONFIG_MODE (0) If (ACTR) { Store (0x0F, Local0) } @@ -207,7 +209,7 @@ { Store (0x0D, Local0) } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
@@ -217,30 +219,30 @@ Method (_PSC) { Store(^^_PSC (), Local0) If (Local0) { Return (Local0) } - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (FDPW, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } } /* Disable power saving mode */ Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, FDPW) - EXCM () + EXIT_CONFIG_MODE () } /* Enable power saving mode */ Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, FDPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_DIS) { - ENCM (0) + ENTER_CONFIG_MODE (0) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS) @@ -252,10 +254,10 @@ })
/* Get IO port info */ - ENCM (0) + ENTER_CONFIG_MODE (0) Store(IO1L, Local0) Store(IO1H, Local1) - EXCM () + EXIT_CONFIG_MODE ()
/* Calculate full IO port address */ Or(ShiftLeft(Local1, 8), Local0, Local0) @@ -298,11 +300,11 @@ CreateByteField (FDE, 12, FD4)
// Get resources from logical device - ENCM (0) + ENTER_CONFIG_MODE (0) Store (ACTR, Local0) Store (IO1H, Local1) Store (IO1L, Local2) - EXCM () + EXIT_CONFIG_MODE () ShiftLeft(Local1, 8, Local1) Or(Local1, Local2, Local1) If (LNot(Local0)) { @@ -380,11 +382,11 @@
Divide(IOA0, 256, Local0, Local1)
- ENCM (0) + ENTER_CONFIG_MODE (0) Store (Local0, IO1L) Store (Local1, IO1H) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -399,10 +401,10 @@
Method (MODE, 1) { And(Arg0, 0x07, Local0) - ENCM (1) + ENTER_CONFIG_MODE (1) And(OPT1, 0x3, Local1) Or(Local1, Local0, OPT1) - EXCM() + EXIT_CONFIG_MODE() }
Method (_INI) @@ -410,15 +412,15 @@ /* Deactivate DMA, even if set by BIOS. We don't announce it through _CRS and it's only useful in ECP mode which we don't support at the moment. */ - ENCM (1) + ENTER_CONFIG_MODE (1) Store (0x04, DMA0) - EXCM () + EXIT_CONFIG_MODE () }
Method (_STA) { Store (0x00, Local0) - ENCM (1) + ENTER_CONFIG_MODE (1) And(OPT1, 0x3, Local1) If (ACTR) { If (LNotEqual(Local1, 2)) { @@ -431,34 +433,34 @@ { Store (0x0D, Local0) } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_PSC) { Store(^^_PSC (), Local0) If (Local0) { Return (Local0) } - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (PRPW, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } } Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, PRPW) - EXCM () + EXIT_CONFIG_MODE () } Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, PRPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_DIS) { - ENCM (1) + ENTER_CONFIG_MODE (1) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS) @@ -475,12 +477,12 @@ CreateWordField (CRS, IRQX._INT, IRQW)
/* Get device settings */ - ENCM (1) + ENTER_CONFIG_MODE (1) Store (IO1L, Local0) Store (IO1H, Local1) Store (OPT1, Local2) Store (IRQ0, Local5) - EXCM () + EXIT_CONFIG_MODE () /* Calculate IO port and modify template */ Or(ShiftLeft(Local1, 8), Local0, Local0) Store(Local1, IOP0) @@ -571,7 +573,7 @@
- ENCM (1) + ENTER_CONFIG_MODE (1) /* IO port */ Store (Local0, IO1L) Store (Local1, IO1H) @@ -585,7 +587,7 @@ Subtract(FindSetLeftBit (IRQL), 1, IRQ0) /* Activate */ Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -600,7 +602,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (2) + ENTER_CONFIG_MODE (2) If (ACTR) { Store (0x0F, Local0) } @@ -608,35 +610,35 @@ { Store (0x0D, Local0) } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_PSC) { Store(^^_PSC (), Local0) If (Local0) { Return (Local0) } - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (UAPW, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } } Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, UAPW) - EXCM () + EXIT_CONFIG_MODE () } Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, UAPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_DIS) { - ENCM (2) + ENTER_CONFIG_MODE (2) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS, 0, Serialized) @@ -645,11 +647,11 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x08, IO0) IRQNoFlags (IRQX) {6} }) - ENCM (2) + ENTER_CONFIG_MODE (2) Store(IO1L, Local0) Store(IO1H, Local1) Store(IRQ0, Local2) - EXCM () + EXIT_CONFIG_MODE () Or(ShiftLeft(Local1, 8), Local0, Local0)
CreateWordField (CRS, IO0._MIN, IMIN) @@ -702,12 +704,12 @@
Subtract(FindSetLeftBit (IRQL), 1, Local3)
- ENCM (2) + ENTER_CONFIG_MODE (2) Store (Local0, IO1L) Store (Local1, IO1H) Store (Local3, IRQ0) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -722,7 +724,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (3) + ENTER_CONFIG_MODE (3) If (LNot(And(OPT2, 0x30))) { If (ACTR) { @@ -733,35 +735,35 @@ Store (0x0D, Local0) } } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_PSC) { Store(^^_PSC (), Local0) If (Local0) { Return (Local0) } - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (UBPW, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } } Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, UBPW) - EXCM () + EXIT_CONFIG_MODE () } Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, UBPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_DIS) { - ENCM (3) + ENTER_CONFIG_MODE (3) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS) @@ -770,11 +772,11 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x08, IO0) IRQNoFlags (IRQX) {6} }) - ENCM (3) + ENTER_CONFIG_MODE (3) Store(IO1L, Local0) Store(IO1H, Local1) Store(IRQ0, Local2) - EXCM () + EXIT_CONFIG_MODE () Or(ShiftLeft(Local1, 8), Local0, Local0)
CreateWordField (CRS, IO0._MIN, IMIN) @@ -827,12 +829,12 @@
- ENCM (3) + ENTER_CONFIG_MODE (3) Store (Local0, IO1L) Store (Local1, IO1H) Store (Local3, IRQ0) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -847,7 +849,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (3) + ENTER_CONFIG_MODE (3) If (And(OPT2, 0x30)) { If (ACTR) { @@ -858,35 +860,35 @@ Store (0x0D, Local0) } } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_CRS) @@ -895,11 +897,11 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x08, IO0) IRQNoFlags (IRQX) {6} }) - ENCM (3) + ENTER_CONFIG_MODE (3) Store(IO1H, Local1) Store(IO1L, Local0) Store(IRQ0, Local2) - EXCM () + EXIT_CONFIG_MODE () Or(ShiftLeft(Local1, 8), Local0, Local0)
CreateWordField (CRS, IO0._MIN, IMIN) @@ -952,12 +954,12 @@
- ENCM (3) + ENTER_CONFIG_MODE (3) Store (Local0, IO1L) Store (Local1, IO1H) Store (Local3, IRQ0) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -973,7 +975,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (6) + ENTER_CONFIG_MODE (6) If (ACTR) { Store (0x0F, Local0) } @@ -981,15 +983,15 @@ { Store (0x0D, Local0) } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_DIS) { - ENCM (6) + ENTER_CONFIG_MODE (6) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS) @@ -998,11 +1000,11 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x08, IO0) IRQNoFlags (IRQX) {6} }) - ENCM (6) + ENTER_CONFIG_MODE (6) Store(IO1L, Local0) Store(IO1H, Local1) Store(IRQ0, Local2) - EXCM () + EXIT_CONFIG_MODE () Or(ShiftLeft(Local1, 8), Local0, Local0)
CreateWordField (CRS, IO0._MIN, IMIN) @@ -1039,12 +1041,12 @@
- ENCM (6) + ENTER_CONFIG_MODE (6) Store (Local0, IO1L) Store (Local1, IO1H) Store (Local3, IRQ0) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -1059,7 +1061,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (5) + ENTER_CONFIG_MODE (5) If (ACTR) { Store (0x0F, Local0) } @@ -1071,15 +1073,15 @@ Store (0x0D, Local0) #endif } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_DIS) { - ENCM (5) + ENTER_CONFIG_MODE (5) Store (Zero, ACTR) - EXCM () + EXIT_CONFIG_MODE () Notify(PS2M, 1) }
@@ -1090,13 +1092,13 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x01, IO0) IO (Decode16, 0x0000, 0x0000, 0x01, 0x01, IO1) }) - ENCM (5) + ENTER_CONFIG_MODE (5) Store(IO1L, Local0) Store(IO1H, Local1) Store(IO2L, Local2) Store(IO2H, Local3) Store(IRQ0, Local4) - EXCM () + EXIT_CONFIG_MODE ()
Or(ShiftLeft(Local1, 8), Local0, Local0) Or(ShiftLeft(Local3, 8), Local2, Local2) @@ -1144,14 +1146,14 @@
Subtract(FindSetLeftBit (IRQL), 1, Local4)
- ENCM (5) + ENTER_CONFIG_MODE (5) Store (Local0, IO1L) Store (Local1, IO1H) Store (Local2, IO2L) Store (Local3, IO2H) Store (Local4, IRQ0) Store (One, ACTR) - EXCM () + EXIT_CONFIG_MODE () Notify(PS2M, 1) } } @@ -1164,7 +1166,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (5) + ENTER_CONFIG_MODE (5) If (LAnd(ACTR, IRQ1) ) { Store (0x0F, Local0) } @@ -1176,15 +1178,15 @@ Store (0x0D, Local0) #endif } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
Method (_DIS) { - ENCM (5) + ENTER_CONFIG_MODE (5) Store (Zero, IRQ1) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS, 0, Serialized) @@ -1192,9 +1194,9 @@ Name (CRS, ResourceTemplate () { IRQNoFlags (IRQX) {} }) - ENCM (5) + ENTER_CONFIG_MODE (5) Store(IRQ1, Local4) - EXCM () + EXIT_CONFIG_MODE ()
CreateWordField (CRS, IRQX._INT, IRQW) Store (One, Local5) @@ -1223,10 +1225,10 @@
Subtract(FindSetLeftBit (IRQL), 1, Local0)
- ENCM (5) + ENTER_CONFIG_MODE (5) Store (Local0, IRQ1) /* Only activates if KBD is active */ - EXCM () + EXIT_CONFIG_MODE () } } #endif @@ -1242,7 +1244,7 @@
Method (_STA) { Store(0, Local0) - ENCM (7) + ENTER_CONFIG_MODE (7) If (LOr(IO1L, IO1H)) { If (LOr(ACTR, ACT1)) { Store (0x0F, Local0) @@ -1251,7 +1253,7 @@ Store (0x0D, Local0) } } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
@@ -1261,11 +1263,11 @@ IO (Decode16, 0x0000, 0x0000, 0x01, 0x01, IO0) IRQNoFlags (IRQX) {} }) - ENCM (7) + ENTER_CONFIG_MODE (7) Store(IO1L, Local0) Store(IO1H, Local1) Store(IRQ0, Local2) - EXCM () + EXIT_CONFIG_MODE ()
@@ -1297,7 +1299,7 @@ Method (_STA) { Store(0, Local0) - ENCM (7) + ENTER_CONFIG_MODE (7) If (LOr(IO2L, IO2H)) { If (LOr(ACTR, ACT2)) { Store (0x0F, Local0) @@ -1306,7 +1308,7 @@ Store (0x0D, Local0) } } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
@@ -1316,11 +1318,11 @@ IO (Decode16, 0x0000, 0x0000, 0x02, 0x02, IO0) IRQNoFlags (IRQX) {} }) - ENCM (7) + ENTER_CONFIG_MODE (7) Store(IO2L, Local0) Store(IO2H, Local1) Store(IRQ1, Local2) - EXCM () + EXIT_CONFIG_MODE ()
@@ -1344,21 +1346,21 @@ /* ==== Suspend LED control if it is connected to the SuperIO ==== */ Method (SLED, 1) { - ENCM (9) + ENTER_CONFIG_MODE (9) Store(OPT4, Local0) And(Local0, 63, Local0) Or(Local0, ShiftLeft(And(Arg0, 0x03), 6), OPT4) - EXCM () + EXIT_CONFIG_MODE () }
/* ===== Power LED control if it is connected to the SuperIO ===== */ Method (PLED, 1) { - ENCM (8) + ENTER_CONFIG_MODE (8) Store(OPT4, Local0) And(Local0, 63, Local0) Or(Local0, ShiftLeft(And(Arg0, 0x03), 6), OPT4) - EXCM () + EXIT_CONFIG_MODE () }
#ifndef NO_W83627HF_HWMON @@ -1372,7 +1374,7 @@ Method (_STA) { Store (0x00, Local0) - ENCM (11) + ENTER_CONFIG_MODE (11) If (ACTR) { Store (0x0F, Local0) } @@ -1380,7 +1382,7 @@ { Store (0x0D, Local0) } - EXCM () + EXIT_CONFIG_MODE () Return (Local0) }
@@ -1388,25 +1390,25 @@ { Store(^^_PSC (), Local0) If (Local0) { Return (Local0) } - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (HWPW, Local0) - EXCM () + EXIT_CONFIG_MODE () If (Local0) { Return (3) } Else { Return (0) } }
Method (_PS0) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (One, HWPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_PS3) { - ENCM (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (Zero, HWPW) - EXCM () + EXIT_CONFIG_MODE () }
Method (_CRS, 0, Serialized) @@ -1415,11 +1417,11 @@ IO (Decode16, 0x0000, 0x0000, 0x08, 0x02, IO0) IRQNoFlags (IRQX) {} }) - ENCM (11) + ENTER_CONFIG_MODE (11) Store(IO1L, Local0) Store(IO1H, Local1) Store(IRQ1, Local2) - EXCM () + EXIT_CONFIG_MODE ()
@@ -1449,9 +1451,9 @@ */ Method (WAKS) { - ENCM (10) + ENTER_CONFIG_MODE (10) Store (CRE3, Local0) - EXCM () + EXIT_CONFIG_MODE () Return (Local0) } } diff --git a/src/superio/winbond/w83977tf/acpi/superio.asl b/src/superio/winbond/w83977tf/acpi/superio.asl index c7a62cd..0a37ac9 100644 --- a/src/superio/winbond/w83977tf/acpi/superio.asl +++ b/src/superio/winbond/w83977tf/acpi/superio.asl @@ -74,7 +74,7 @@
/* PM: indicate IPD (Immediate Power Down) bit state as D0/D3 */ Method (_PSC) { - ENTER_CONFIG_MODE (0xFF) + ENTER_CONFIG_MODE (PNP_NO_LDN_CHANGE) Store (IPD, Local0) EXIT_CONFIG_MODE () If (Local0) { Return (3) }
Hello build bot (Jenkins), Felix Held,
Change-Id: I3ac8dd2ba089970a18b460769dfc3fabf9395709 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/superio/winbond/w83627hf/acpi/superio.asl M src/superio/winbond/w83977tf/acpi/superio.asl 2 files changed, 137 insertions(+), 135 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/39907/2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39907 )
Patch Set 2:
Have you checked that this does not change the resulting binary?
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39907 )
Patch Set 2:
Patch Set 2:
make BUILD_TIMELESS=1 gives : with current patch:
Name Offset Type Size Comp cbfs master header 0x0 cbfs header 32 none fallback/romstage 0x80 stage 16604 none cpu_microcode_blob.bin 0x41c0 microcode 83968 none fallback/ramstage 0x18a40 stage 47640 none config 0x244c0 raw 106 none revision 0x24580 raw 665 none fallback/postcar 0x24880 stage 15780 none fallback/payload 0x28680 simple elf 69336 none payload_config 0x395c0 raw 1621 none payload_revision 0x39c80 raw 235 none (empty) 0x39dc0 null 16344 none bootblock 0x3ddc0 bootblock 8192 none HOSTCC cbfstool/ifwitool.o HOSTCC cbfstool/ifwitool (link)
Built asus/p2b-d (P2B-D)
$ md5sum build/coreboot.rom cf84fe13ad961d10b6c54ed73cef33f6 build/coreboot.rom
========================================== without current patch:
(looks like w83627hf isn't used ... yet? )
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39907 )
Patch Set 2:
only had a very brief look at the change
https://review.coreboot.org/c/coreboot/+/39907/2/src/superio/winbond/w83627h... File src/superio/winbond/w83627hf/acpi/superio.asl:
https://review.coreboot.org/c/coreboot/+/39907/2/src/superio/winbond/w83627h... PS2, Line 143: IO (Decode16, 0x004E, 0x004E, 0x01, 0x01) /* this port is used in some configurations, so announce it to be sure */ when using SUPERIO_PNP_BASE, this shouldn't be needed
Change-Id: I3ac8dd2ba089970a18b460769dfc3fabf9395709 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/superio/winbond/w83627hf/acpi/superio.asl M src/superio/winbond/w83977tf/acpi/superio.asl 2 files changed, 137 insertions(+), 136 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/39907/3
Patch Set 3:
Thx
Ack
Patch Set 3: Code-Review+2
Patch Set 2:
Patch Set 2:
*snip*
The new patchset might change the binary, but it's the right thing to do.
https://review.coreboot.org/c/coreboot/+/39907/3/src/superio/winbond/w83627h... File src/superio/winbond/w83627hf/acpi/superio.asl:
https://review.coreboot.org/c/coreboot/+/39907/3/src/superio/winbond/w83627h... PS3, Line 142: /* Announce the used I/O ports to the OS */ Maybe move it to the previous line
Hello build bot (Jenkins), Angel Pons, Felix Held,
Change-Id: I3ac8dd2ba089970a18b460769dfc3fabf9395709 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/superio/winbond/w83627hf/acpi/superio.asl M src/superio/winbond/w83977tf/acpi/superio.asl 2 files changed, 138 insertions(+), 136 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/39907/4
Patch Set 4:
Thx
Done
Patch Set 4: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39907 )
Change-Id: I3ac8dd2ba089970a18b460769dfc3fabf9395709 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/39907 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/superio/winbond/w83627hf/acpi/superio.asl M src/superio/winbond/w83977tf/acpi/superio.asl 2 files changed, 138 insertions(+), 136 deletions(-)
diff --git a/src/superio/winbond/w83627hf/acpi/superio.asl b/src/superio/winbond/w83627hf/acpi/superio.asl index d5c5ec9..8f18612 100644 --- a/src/superio/winbond/w83627hf/acpi/superio.asl +++ b/src/superio/winbond/w83627hf/acpi/superio.asl @@ -43,6 +43,8 @@ * http://www.itox.com/pages/support/wdt/W83627HF.pdf */
+#include <superio/acpi/pnp.asl> + Device(SIO) { Name (_HID, EisaId("PNP0A05")) Name (_STR, Unicode("Winbond W83627HF SuperIO")) @@ -52,7 +54,7 @@ Mutex(CRMX, 1)
/* SuperIO configuration ports */ - OperationRegion (CREG, SystemIO, 0x2E, 0x02) + OperationRegion (CREG, SystemIO, SUPERIO_PNP_BASE, 0x02) Field (CREG, ByteAcc, NoLock, Preserve) { PNP_ADDR_REG, 8, @@ -137,8 +139,8 @@ Method (_CRS) { Return (ResourceTemplate () { - IO (Decode16, 0x002E, 0x002E, 0x02, 0x01) /* Announce the used I/O ports to the OS */ - IO (Decode16, 0x004E, 0x004E, 0x01, 0x01) /* this port is used in some configurations, so announce it to be sure */ + /* Announce the used I/O ports to the OS */ + IO (Decode16, SUPERIO_PNP_BASE, SUPERIO_PNP_BASE, 0x02, 0x01) }) }
