the following patch was just integrated into master: commit f6776fa62c84ae516f84c99859d826f77d508079 Author: Paul Menzel pmenzel@molgen.mpg.de Date: Fri Jan 20 14:49:35 2017 +0100
amd/amdht: Fix format security errors
Ubuntu’s default compiler flags for GCC [1][2] include `-Wformat -Wformat-security`, causing errors similar like the one below.
``` CC romstage/northbridge/amd/amdht/ht_wrapper.o src/northbridge/amd/amdht/ht_wrapper.c: In function 'AMD_CB_EventNotify': src/northbridge/amd/amdht/ht_wrapper.c:124:4: error: format not a string literal and no format arguments [-Werror=format-security] printk(log_level, event_class_string_decodes[evtClass]); ^ […] ```
Fix that, by explicitly using a format string.
TEST=Built and booted on ASUS KGPE-D16.
[1] https://stackoverflow.com/questions/17260409/fprintf-error-format-not-a-stri... "fprintf, error: format not a string literal and no format arguments [-Werror=format-security" [2] I tested with gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609.
Change-Id: Iabe60deeffa441146eab31dac4416846ce95c32a Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de Reviewed-on: https://review.coreboot.org/18208 Tested-by: build bot (Jenkins) Reviewed-by: Nico Huber nico.h@gmx.de
See https://review.coreboot.org/18208 for details.
