Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49291 )
Change subject: soc/intel/adl: Add new Kconfig ENABLE_DISPLAY_OVER_DGPU for ADLRVP with DG ......................................................................
This ENABLE_DISPLAY_OVER_DGPU Kconfig will allow ADLRVP to work with DG over PCIE to get display. Also ensure to turn off running IGD initialization using FSP GOP when ENABLE_DISPLAY_OVER_DGPU is enable.
TEST=Able to get Pre-OS splash screen with AMD Radeon RX 5700 PCI-E DGPU when mainboard user selects ENABLE_DISPLAY_OVER_DGPU.
Change-Id: Ibbe9c8c4d77018de83815d7d203284b1fbc0da58 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/mainboard/intel/adlrvp/devicetree.cb M src/soc/intel/alderlake/Kconfig 2 files changed, 15 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/91/49291/1
diff --git a/src/mainboard/intel/adlrvp/devicetree.cb b/src/mainboard/intel/adlrvp/devicetree.cb index cf9afaf..294fa8c 100644 --- a/src/mainboard/intel/adlrvp/devicetree.cb +++ b/src/mainboard/intel/adlrvp/devicetree.cb @@ -189,7 +189,11 @@ device domain 0 on device pci 00.0 on end # Host Bridge device pci 01.0 on end # PEG10 +#if CONFIG(ENABLE_DISPLAY_OVER_DGPU) + device pci 02.0 off end # Graphics +#else device pci 02.0 on end # Graphics +#endif device pci 04.0 on end # DPTF device pci 05.0 on end # IPU device pci 06.0 on end # PEG60 diff --git a/src/soc/intel/alderlake/Kconfig b/src/soc/intel/alderlake/Kconfig index 8009a42..df23822 100644 --- a/src/soc/intel/alderlake/Kconfig +++ b/src/soc/intel/alderlake/Kconfig @@ -242,4 +242,15 @@ 0:Disabled, 1:Enabled (DCI OOB+[DbC]), 2:Enabled (DCI OOB), 3:Enabled (USB3 DbC), 4:Enabled (XDP/MIPI60), 5:Enabled (USB2 DbC), 6:Enable (2-wire DCI OOB), 7:Manual + +config ENABLE_DISPLAY_OVER_DGPU + select VGA_ROM_RUN_DEFAULT + select MAINBOARD_NO_FSP_GOP + help + This option enables graphics initialization with external + graphics card by load/execute VGA OpRom without running + FSP GOP. + + Selected by mainboard that runs OpRom to perform display + initialization over attached PCIe GFX card. endif
