Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3194
commit 6c84286e4246d6af1a1b3da10bd5a548dac8c323 Author: Rudolf Marek r.marek@assembler.cz Date: Sat May 4 00:08:34 2013 +0200
ASUS F2A85-M: Correct and clean up PCIe config
Assign the lanes correctly to the physical slots on the motherboard in `PlatformGnbPcie.c`.
• UMI is connected to SB via 4x PCIe bridge 8. • The blue x16 slot is not shared with DDI and is routed through PCIe bridge 2. • The black x8 slot is in fact a x4 slot and uses all 4 GPPs from the CPU. • Assume that DDI is on out-of-PCIe-band lanes.
Change-Id: I44c4c83e6a8e31d6150a602a0993972ac63105bd Signed-off-by: Rudolf Marek r.marek@assembler.cz Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- src/mainboard/asus/f2a85-m/PlatformGnbPcie.c | 66 ++++------------------ .../asus/f2a85-m/PlatformGnbPcieComplex.h | 40 ------------- 2 files changed, 10 insertions(+), 96 deletions(-)
diff --git a/src/mainboard/asus/f2a85-m/PlatformGnbPcie.c b/src/mainboard/asus/f2a85-m/PlatformGnbPcie.c index fff40a8..8ff64c6 100644 --- a/src/mainboard/asus/f2a85-m/PlatformGnbPcie.c +++ b/src/mainboard/asus/f2a85-m/PlatformGnbPcie.c @@ -72,57 +72,32 @@ */
PCIe_PORT_DESCRIPTOR PortList [] = { - /* PCIe port, Lanes 8:23, PCI Device Number 2 */ + /* PCIe port, Lanes 8:23, PCI Device Number 2, blue x16 slot */ { 0, /* Descriptor flags */ PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 8, 23), PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 2, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) }, - /* PCIe port, Lanes 16:23, PCI Device Number 3 */ + /* PCIe port, Lanes 4:7, PCI Device Number 4, black x16 slot (in fact x4) */ { 0, /* Descriptor flags */ - PCIE_ENGINE_DATA_INITIALIZER (PcieUnusedEngine, 16, 23), - PCIE_PORT_DATA_INITIALIZER (PortDisabled, ChannelTypeExt6db, 3, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) - }, - - /* PCIe port, Lanes 4, PCI Device Number 4, PCIE MINI0 */ - { - 0, /* Descriptor flags */ - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 4, 4), + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 4, 7), PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 4, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) }, - - /* PCIe port, Lanes 5, PCI Device Number 5, PCIE MINI1 */ - { - 0, /* Descriptor flags */ - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 5, 5), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 5, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) - }, - - /* PCIe port, Lanes 6, PCI Device Number 6, PCIE SLOT1, TODO: Disabled. */ - { - 0, /* Descriptor flags */ - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 6, 6), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 6, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) - }, - - /* PCIe port, Lanes 7, PCI Device Number 7, LAN , TODO: not the last entry.*/ - { - 0, /* Descriptor flags !!!IMPORTANT!!! Terminate last element of array */ - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 7, 7), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 7, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 1) - }, - -#if 1 - /* Initialize Port descriptor (PCIe port, Lanes ?, PCI Device Number 8, ...) */ + /* PCIe port, Lanes 0:3, UMI link to SB, PCI Device Number 8 */ { DESCRIPTOR_TERMINATE_LIST, /* Descriptor flags !!!IMPORTANT!!! Terminate last element of array */ PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 0, 3), PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 8, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) }, -#endif };
+/* + * It is not known, if the setup is complete. + * + * Tested and works: VGA/DVI + * Untested: HDMI + */ PCIe_DDI_DESCRIPTOR DdiList [] = { // DP0 to HDMI0/DP { @@ -139,29 +114,9 @@ PCIe_DDI_DESCRIPTOR DdiList [] = { // DP2 to HDMI1/DP { 0, -// PCIE_ENGINE_DATA_INITIALIZER (PcieUnusedEngine, 32, 38), PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 32, 35), - //PCIE_DDI_DATA_INITIALIZER (ConnectorTypeEDP, Aux3, Hdp3) PCIE_DDI_DATA_INITIALIZER (ConnectorTypeHDMI, Aux3, Hdp3) }, - // GFX Lane 15-12 - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PcieUnusedEngine, 12, 15), - PCIE_DDI_DATA_INITIALIZER (ConnectorTypeHDMI, Aux4, Hdp4) - }, - // GFX Lane 11-8 - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PcieUnusedEngine, 16, 19), - PCIE_DDI_DATA_INITIALIZER (ConnectorTypeHDMI, Aux5, Hdp5) - }, - // GFX Lane 7-4 - { - DESCRIPTOR_TERMINATE_LIST, - PCIE_ENGINE_DATA_INITIALIZER (PcieUnusedEngine, 20, 23), - PCIE_DDI_DATA_INITIALIZER (ConnectorTypeHDMI, Aux6, Hdp6) - } };
PCIe_COMPLEX_DESCRIPTOR Trinity = { @@ -205,7 +160,6 @@ OemCustomizeInitEarly ( // Allocate buffer for PCIe_COMPLEX_DESCRIPTOR , PCIe_PORT_DESCRIPTOR and PCIe_DDI_DESCRIPTOR // AllocHeapParams.RequestedBufferSize = sizeof(Trinity) + sizeof(PortList) + sizeof(DdiList); - AllocHeapParams.BufferHandle = AMD_MEM_MISC_HANDLES_START; AllocHeapParams.Persist = HEAP_LOCAL_CACHE; Status = HeapAllocateBuffer (&AllocHeapParams, &InitEarly->StdHeader); diff --git a/src/mainboard/asus/f2a85-m/PlatformGnbPcieComplex.h b/src/mainboard/asus/f2a85-m/PlatformGnbPcieComplex.h index 3f14805..b3c69cf 100644 --- a/src/mainboard/asus/f2a85-m/PlatformGnbPcieComplex.h +++ b/src/mainboard/asus/f2a85-m/PlatformGnbPcieComplex.h @@ -24,46 +24,6 @@ #include "AGESA.h" #include "amdlib.h"
-//GNB GPP Port4 -#define GNB_GPP_PORT4_PORT_PRESENT 1 //0:Disable 1:Enable -#define GNB_GPP_PORT4_SPEED_MODE 2 //0:Auto 1:GEN1 2:GEN2 -#define GNB_GPP_PORT4_LINK_ASPM 3 //0:Disable 1:L0s 2:L1 3:L0s+L1 -#define GNB_GPP_PORT4_CHANNEL_TYPE 4 //0:LowLoss(-3.5db) 1:HighLoss(-6db) 2:Half-swing(0db) - //3:Half-swing(-3.5db) 4:extended length (-6db) 5:extended length(-8db) -#define GNB_GPP_PORT4_HOTPLUG_SUPPORT 0 //0:Disable 1:Basic 3:Enhanced - -//GNB GPP Port5 -#define GNB_GPP_PORT5_PORT_PRESENT 1 //0:Disable 1:Enable -#define GNB_GPP_PORT5_SPEED_MODE 2 //0:Auto 1:GEN1 2:GEN2 -#define GNB_GPP_PORT5_LINK_ASPM 3 //0:Disable 1:L0s 2:L1 3:L0s+L1 -#define GNB_GPP_PORT5_CHANNEL_TYPE 4 //0:LowLoss(-3.5db) 1:HighLoss(-6db) 2:Half-swing(0db) - //3:Half-swing(-3.5db) 4:extended length (-6db) 5:extended length(-8db) -#define GNB_GPP_PORT5_HOTPLUG_SUPPORT 0 //0:Disable 1:Basic 3:Enhanced - -//GNB GPP Port6 -#define GNB_GPP_PORT6_PORT_PRESENT 1 //0:Disable 1:Enable -#define GNB_GPP_PORT6_SPEED_MODE 2 //0:Auto 1:GEN1 2:GEN2 -#define GNB_GPP_PORT6_LINK_ASPM 3 //0:Disable 1:L0s 2:L1 3:L0s+L1 -#define GNB_GPP_PORT6_CHANNEL_TYPE 4 //0:LowLoss(-3.5db) 1:HighLoss(-6db) 2:Half-swing(0db) - //3:Half-swing(-3.5db) 4:extended length (-6db) 5:extended length(-8db) -#define GNB_GPP_PORT6_HOTPLUG_SUPPORT 0 //0:Disable 1:Basic 3:Enhanced - -//GNB GPP Port7 -#define GNB_GPP_PORT7_PORT_PRESENT 1 //0:Disable 1:Enable -#define GNB_GPP_PORT7_SPEED_MODE 2 //0:Auto 1:GEN1 2:GEN2 -#define GNB_GPP_PORT7_LINK_ASPM 3 //0:Disable 1:L0s 2:L1 3:L0s+L1 -#define GNB_GPP_PORT7_CHANNEL_TYPE 4 //0:LowLoss(-3.5db) 1:HighLoss(-6db) 2:Half-swing(0db) - //3:Half-swing(-3.5db) 4:extended length (-6db) 5:extended length(-8db) -#define GNB_GPP_PORT7_HOTPLUG_SUPPORT 0 //0:Disable 1:Basic 3:Enhanced - -//GNB GPP Port8 -#define GNB_GPP_PORT8_PORT_PRESENT 1 //0:Disable 1:Enable -#define GNB_GPP_PORT8_SPEED_MODE 2 //0:Auto 1:GEN1 2:GEN2 -#define GNB_GPP_PORT8_LINK_ASPM 3 //0:Disable 1:L0s 2:L1 3:L0s+L1 -#define GNB_GPP_PORT8_CHANNEL_TYPE 4 //0:LowLoss(-3.5db) 1:HighLoss(-6db) 2:Half-swing(0db) - //3:Half-swing(-3.5db) 4:extended length (-6db) 5:extended length(-8db) -#define GNB_GPP_PORT8_HOTPLUG_SUPPORT 0 //0:Disable 1:Basic 3:Enhanced - VOID OemCustomizeInitEarly ( IN OUT AMD_EARLY_PARAMS *InitEarly
