Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/59922 )
Change subject: mb/google/zork,soc/amd/psp_verstage: Add verstage_mb_{tpm/espi}_init ......................................................................
These functions can't be weak, because they actually need to configure the GPIOs for eSPI and the TPM. With this change zork boots again.
I also noticed that zork doesn't use the early table in bootblock. This means that zork will only boot if psp_verstage is enabled.
BUG=b:209465425 TEST=boot zork to ramstage
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I384fd578efe7da0a3d74829cccf38c3ed524f130 Reviewed-on: https://review.coreboot.org/c/coreboot/+/59922 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Rob Barnes robbarnes@google.com --- M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c M src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/zork/verstage.c M src/soc/amd/common/psp_verstage/psp_verstage.c 5 files changed, 85 insertions(+), 21 deletions(-)
Approvals: build bot (Jenkins): Verified Rob Barnes: Looks good to me, approved
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c index 5d3e21f..45b9e1d 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c @@ -311,25 +311,43 @@ return gpio_sleep_table; }
-static const struct soc_amd_gpio early_gpio_table[] = { - /* H1_FCH_INT_ODL */ - PAD_INT(GPIO_3, PULL_NONE, EDGE_LOW, STATUS), - /* I2C3_SCL - H1 */ - PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), - /* I2C3_SDA - H1 */ - PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), +static const struct soc_amd_gpio espi_gpio_table[] = { /* PCIE_RST0_L - Fixed timings */ PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* FCH_ESPI_EC_CS_L */ PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), /* ESPI_ALERT_L */ PAD_NF(GPIO_108, ESPI_ALERT_L, PULL_NONE), +}; + +const __weak struct soc_amd_gpio *variant_espi_gpio_table(size_t *size) +{ + *size = ARRAY_SIZE(espi_gpio_table); + return espi_gpio_table; +} + +static const struct soc_amd_gpio tpm_gpio_table[] = { + /* H1_FCH_INT_ODL */ + PAD_INT(GPIO_3, PULL_NONE, EDGE_LOW, STATUS), + /* I2C3_SCL - H1 */ + PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), + /* I2C3_SDA - H1 */ + PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), + /* EC_IN_RW_OD */ + PAD_GPI(GPIO_11, PULL_NONE), +}; + +const __weak struct soc_amd_gpio *variant_tpm_gpio_table(size_t *size) +{ + *size = ARRAY_SIZE(tpm_gpio_table); + return tpm_gpio_table; +} + +static const struct soc_amd_gpio early_gpio_table[] = { /* UART0_RXD - DEBUG */ PAD_NF(GPIO_136, UART0_RXD, PULL_NONE), /* UART0_TXD - DEBUG */ PAD_NF(GPIO_138, UART0_TXD, PULL_NONE), - /* EC_IN_RW_OD */ - PAD_GPI(GPIO_11, PULL_NONE), };
const struct soc_amd_gpio *variant_early_gpio_table(size_t *size) diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index 415c426..7220c38 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -360,25 +360,43 @@ return gpio_sleep_table; }
-static const struct soc_amd_gpio early_gpio_table[] = { - /* H1_FCH_INT_ODL */ - PAD_INT(GPIO_3, PULL_NONE, EDGE_LOW, STATUS), - /* I2C3_SCL - H1 */ - PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), - /* I2C3_SDA - H1 */ - PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), +static const struct soc_amd_gpio espi_gpio_table[] = { /* PCIE_RST0_L - Fixed timings */ PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* FCH_ESPI_EC_CS_L */ PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), /* ESPI_ALERT_L */ PAD_NF(GPIO_108, ESPI_ALERT_L, PULL_NONE), +}; + +const struct soc_amd_gpio *variant_espi_gpio_table(size_t *size) +{ + *size = ARRAY_SIZE(espi_gpio_table); + return espi_gpio_table; +} + +static const struct soc_amd_gpio tpm_gpio_table[] = { + /* H1_FCH_INT_ODL */ + PAD_INT(GPIO_3, PULL_NONE, EDGE_LOW, STATUS), + /* I2C3_SCL - H1 */ + PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), + /* I2C3_SDA - H1 */ + PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), + /* EC_IN_RW_OD */ + PAD_GPI(GPIO_130, PULL_NONE), +}; + +const struct soc_amd_gpio *variant_tpm_gpio_table(size_t *size) +{ + *size = ARRAY_SIZE(tpm_gpio_table); + return tpm_gpio_table; +} + +static const struct soc_amd_gpio early_gpio_table[] = { /* UART0_RXD - DEBUG */ PAD_NF(GPIO_136, UART0_RXD, PULL_NONE), /* UART0_TXD - DEBUG */ PAD_NF(GPIO_138, UART0_TXD, PULL_NONE), - /* EC_IN_RW_OD */ - PAD_GPI(GPIO_130, PULL_NONE), };
const struct soc_amd_gpio *variant_early_gpio_table(size_t *size) diff --git a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h index 3f7e5d1..38c5d4a 100644 --- a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h @@ -33,6 +33,12 @@ */ const struct soc_amd_gpio *variant_sleep_gpio_table(size_t *size, int slp_typ);
+/* This function provides GPIO settings for eSPI bus. */ +const struct soc_amd_gpio *variant_espi_gpio_table(size_t *size); + +/* This function provides GPIO settings for TPM i2c bus. */ +const struct soc_amd_gpio *variant_tpm_gpio_table(size_t *size); + void variant_updm_update(FSP_M_CONFIG *mcfg);
/* Program any required GPIOs at the finalize phase */ diff --git a/src/mainboard/google/zork/verstage.c b/src/mainboard/google/zork/verstage.c index e1277f4..0603257 100644 --- a/src/mainboard/google/zork/verstage.c +++ b/src/mainboard/google/zork/verstage.c @@ -2,6 +2,7 @@
#include <amdblocks/gpio.h> #include <baseboard/variants.h> +#include <psp_verstage.h> #include <security/vboot/vboot_common.h>
static void setup_gpio(void) @@ -19,3 +20,27 @@ { setup_gpio(); } + +void verstage_mainboard_espi_init(void) +{ + const struct soc_amd_gpio *gpios; + size_t num_gpios; + + if (!CONFIG(VBOOT_STARTS_BEFORE_BOOTBLOCK)) + return; + + gpios = variant_espi_gpio_table(&num_gpios); + gpio_configure_pads(gpios, num_gpios); +} + +void verstage_mainboard_tpm_init(void) +{ + const struct soc_amd_gpio *gpios; + size_t num_gpios; + + if (!CONFIG(VBOOT_STARTS_BEFORE_BOOTBLOCK)) + return; + + gpios = variant_tpm_gpio_table(&num_gpios); + gpio_configure_pads(gpios, num_gpios); +} diff --git a/src/soc/amd/common/psp_verstage/psp_verstage.c b/src/soc/amd/common/psp_verstage/psp_verstage.c index 2e3d09d..05c14d6 100644 --- a/src/soc/amd/common/psp_verstage/psp_verstage.c +++ b/src/soc/amd/common/psp_verstage/psp_verstage.c @@ -25,9 +25,6 @@
extern char _bss_start, _bss_end;
-void __weak verstage_mainboard_early_init(void) {} -void __weak verstage_mainboard_espi_init(void) {} -void __weak verstage_mainboard_tpm_init(void) {} void __weak verstage_mainboard_init(void) {}
uint32_t __weak get_max_workbuf_size(uint32_t *size)
