Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11959
commit 76f6a3ed5781c3ac156df36bcc28a16266248fe8 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sun May 31 18:46:40 2015 -0500
northbridge/amd/amdmct/mct_ddr3: Fix S3 suspend overrunning the stack size limit
Change-Id: Id7441dacef2e46e283d1fc99d5e5fa3f20e0d097 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdmct/mct_ddr3/s3utils.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c b/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c index 34c52ac..4b745d2 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c @@ -539,10 +539,17 @@ int8_t save_mct_information_to_nvram(void)
struct spi_flash *flash; ssize_t s3nv_offset; - struct amd_s3_persistent_data persistent_data; + struct amd_s3_persistent_data *persistent_data; + + /* Allocate temporary data structures */ + persistent_data = malloc(sizeof(struct amd_s3_persistent_data)); + if (!persistent_data) { + printk(BIOS_DEBUG, "Could not allocate S3 data structure in RAM\n"); + return -1; + }
/* Obtain MCT configuration data */ - copy_mct_data_to_save_variable(&persistent_data); + copy_mct_data_to_save_variable(persistent_data);
/* Obtain CBFS file offset */ s3nv_offset = get_s3nv_file_offset(); @@ -572,7 +579,10 @@ int8_t save_mct_information_to_nvram(void)
/* Erase and write data structure */ flash->erase(flash, s3nv_offset, CONFIG_S3_DATA_SIZE); - flash->write(flash, s3nv_offset, sizeof(struct amd_s3_persistent_data), &persistent_data); + flash->write(flash, s3nv_offset, sizeof(struct amd_s3_persistent_data), persistent_data); + + /* Deallocate temporary data structures */ + free(persistent_data);
/* Tear down SPI flash access */ flash->spi->rw = SPI_WRITE_FLAG;
