Attention is currently required from: Patrick Rudolph, Deomid "rojer" Ryabkov. Hello build bot (Jenkins), Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/51230
Change subject: soc/intel/xeon_sp: Set the MRC "cold boot required" status bit ......................................................................
If bit 0 of byte 0x47 is set FSP will perform full memory training even if previously saved data is supplied.
Up to and including FSP 2021 WW01 it was reset internally at the end of PostMemoryInit. Starting with WW03 this is no longer the case and Intel advised that this bit should be reset externally if valid MRC data is present.
Change-Id: I9c4191d2fa2e0203b3464dcf40d845ede5f14c6b Signed-off-by: Deomid "rojer" Ryabkov rojer9@fb.com --- M src/soc/intel/xeon_sp/cpx/chip.h M src/soc/intel/xeon_sp/cpx/romstage.c 2 files changed, 18 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/30/51230/3
