Tobias Diedrich (ranma+coreboot@tdiedrich.de) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12796
commit 08c2ac39424e565a63efa60256c8c4f4ffa63299 Author: Tobias Diedrich ranma+coreboot@tdiedrich.de Date: Wed Dec 23 23:27:06 2015 +0100
pcengines/apu1: Supply TPM modules on the LPC connector
Since the APU1 has an LPC connector it is possible to connect a TPM. I'm using mine mostly for the HWRNG which the APU1 lacks.
This takes care of setting up the TPM interrupt. Interrupt 5 was chosen since it is not otherwise used on the APU1, Alternatively 1, 7, 10-11 and 14-15 should be available as well. It may also be possible to share the ACPI interrupt (9).
Previously I was getting frequent "genirq: Flags mismatch irq 4. 00000000 (serial) vs. 00000080 (tpm0)" errors.
With this I also no longer need to use "tpm_tis.force=1" on the kernel commandline since the TPM is now declared in the ACPI DSDT.
The tpm support asl is changed to probe for the TPM before returning "Device present" status, so it will fail gracefully if no TPM module is installed.
See also https://plus.google.com/+TobiasDiedrich/posts/cRv9MwrCdEa and https://plus.google.com/+TobiasDiedrich/posts/BDnJLGFMW8o
Change-Id: Ie732228471f6c40d77e17cbed34726961b1fcddd Signed-off-by: Tobias Diedrich ranma+coreboot@tdiedrich.de --- src/drivers/pc80/tpm/acpi/tpm.asl | 39 ++++++++++++++++++----------- src/mainboard/pcengines/apu1/Kconfig | 1 + src/mainboard/pcengines/apu1/devicetree.cb | 5 ++++ src/southbridge/amd/cimx/sb800/acpi/lpc.asl | 4 +++ 4 files changed, 34 insertions(+), 15 deletions(-)
diff --git a/src/drivers/pc80/tpm/acpi/tpm.asl b/src/drivers/pc80/tpm/acpi/tpm.asl index 7755e9b..de25114 100644 --- a/src/drivers/pc80/tpm/acpi/tpm.asl +++ b/src/drivers/pc80/tpm/acpi/tpm.asl @@ -21,10 +21,33 @@ Device (TPM) Name (_CID, 0x310cd041) Name (_UID, 1)
+ OperationRegion (TREG, SystemMemory, + CONFIG_TPM_TIS_BASE_ADDRESS, 0x5000) + Field (TREG, ByteAcc, NoLock, Preserve) + { + /* TPM_INT_ENABLE_0 */ + Offset (0x0008), + , 3, + ITPL, 2, /* Interrupt type and polarity */ + + /* TPM_INT_VECTOR_0 */ + Offset (0x000C), + IVEC, 4, /* SERIRQ vector */ + + /* TPM_DID_VID */ + Offset (0x0f00), + DVID, 32, /* Device and vendor ID */ + } + Method (_STA, 0) { #if CONFIG_LPC_TPM && !CONFIG_TPM_DEACTIVATE - Return (0xf) + If (LAnd (LGreater (DVID, 0), LLess (DVID, 0xffffffff))) { + Return (0xf) + } Else { + /* TPM module missing */ + Return (0x0) + } #else Return (0x0) #endif @@ -45,20 +68,6 @@ Device (TPM)
Method (_CRS, 0, Serialized) { - OperationRegion (TREG, SystemMemory, - CONFIG_TPM_TIS_BASE_ADDRESS, 0x5000) - Field (TREG, ByteAcc, NoLock, Preserve) - { - /* TPM_INT_ENABLE_0 */ - Offset (0x0008), - , 3, - ITPL, 2, /* Interrupt type and polarity */ - - /* TPM_INT_VECTOR_0 */ - Offset (0x000C), - IVEC, 4, /* SERIRQ vector */ - } - CreateField (^IBUF, ^TIRQ._INT, 32, TVEC) CreateBitField (^IBUF, ^TIRQ._HE, TTYP) CreateBitField (^IBUF, ^TIRQ._LL, TPOL) diff --git a/src/mainboard/pcengines/apu1/Kconfig b/src/mainboard/pcengines/apu1/Kconfig index 2328776..5eb9e1c 100644 --- a/src/mainboard/pcengines/apu1/Kconfig +++ b/src/mainboard/pcengines/apu1/Kconfig @@ -30,6 +30,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_CMOS_DEFAULT select BOARD_ROMSIZE_KB_2048 select SPD_CACHE + select MAINBOARD_HAS_LPC_TPM
config MAINBOARD_DIR string diff --git a/src/mainboard/pcengines/apu1/devicetree.cb b/src/mainboard/pcengines/apu1/devicetree.cb index 72e89c0..1a263a2 100644 --- a/src/mainboard/pcengines/apu1/devicetree.cb +++ b/src/mainboard/pcengines/apu1/devicetree.cb @@ -43,6 +43,11 @@ chip northbridge/amd/agesa/family14/root_complex device pci 14.1 off end # IDE 0x439c device pci 14.2 off end # HDA 0x4383 device pci 14.3 on # LPC 0x439d + chip drivers/pc80/tpm # Support TPM on the LPC header. + device pnp 0c31.0 on + irq 0x70 = 5 + end + end chip superio/nuvoton/nct5104d register "irq_trigger_type" = "0" device pnp 2e.0 off end diff --git a/src/southbridge/amd/cimx/sb800/acpi/lpc.asl b/src/southbridge/amd/cimx/sb800/acpi/lpc.asl index 98d5aa5..c2d1ebd 100644 --- a/src/southbridge/amd/cimx/sb800/acpi/lpc.asl +++ b/src/southbridge/amd/cimx/sb800/acpi/lpc.asl @@ -77,4 +77,8 @@ Device(LIBR) { }) } /* End Device(_SB.PCI0.LpcIsaBr.COPR) */ #include "acpi/superio.asl" + +#if CONFIG_MAINBOARD_HAS_LPC_TPM + #include <drivers/pc80/tpm/acpi/tpm.asl> +#endif } /* end LIBR */
