Lee Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15859
commit d0a1e48d56baad3f639db17d2e38a6467bc27467 Author: Lee Leahy leroy.p.leahy@intel.com Date: Thu Jul 21 09:28:56 2016 -0700
mainboard/intel/galileo: Remove use of EDK-II macros & data types
Replace the use of ASSERT macro with if/die. Replace the use of UINT8 data type with uint8_t.
TEST=Build and run on Galileo Gen2.
Change-Id: I0756b0f30b3488647530e2dd1a4ab62813815f3e Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/mainboard/intel/galileo/reg_access.c | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/src/mainboard/intel/galileo/reg_access.c b/src/mainboard/intel/galileo/reg_access.c index 36345ff..8934e8a 100644 --- a/src/mainboard/intel/galileo/reg_access.c +++ b/src/mainboard/intel/galileo/reg_access.c @@ -45,8 +45,9 @@ static uint64_t reg_read(struct reg_script_context *ctx) case GEN2_I2C_LED_PWM: if (ctx->display_features) printk(BIOS_INFO, "I2C chip 0x%02x: ", step->id); - ret_code = i2c_readb(0, step->id, (UINT8)step->reg, &value); - ASSERT(ret_code == 2); + ret_code = i2c_readb(0, step->id, (uint8_t)step->reg, &value); + if (ret_code != 2) + die("ERROR - ret_code != 2\n"); break; } return value; @@ -76,9 +77,10 @@ static void reg_write(struct reg_script_context *ctx) case RMU_TEMP_REGS: if (ctx->display_features) printk(BIOS_INFO, "I2C chip 0x%02x: ", step->id); - value = (UINT8)step->value; - ret_code = i2c_writeb(0, step->id, (UINT8)step->reg, value); - ASSERT(ret_code == 2); + value = (uint8_t)step->value; + ret_code = i2c_writeb(0, step->id, (uint8_t)step->reg, value); + if (ret_code != 2) + die("ERROR - ret_code != 2\n"); break; } }
