Antonello Dettori (dev@dettori.io) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16437
commit 650c54cb12ae37bca66a92363b974c966b44f057 Author: Antonello Dettori dev@dettori.io Date: Sat Sep 3 10:45:33 2016 +0200
cpu/amd/model_fxx: transition away from device_t
Replace the use of the old device_t definition inside cpu/amd/model_fxx.
Change-Id: Iac7571956ed2fb927a6b8cc88514e533f40490d0 Signed-off-by: Antonello Dettori dev@dettori.io --- src/cpu/amd/model_fxx/init_cpus.c | 2 +- src/include/cpu/amd/model_fxx_rev.h | 41 +++++++++++++++++++------------------ 2 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/src/cpu/amd/model_fxx/init_cpus.c b/src/cpu/amd/model_fxx/init_cpus.c index 63c8823..d38c552 100644 --- a/src/cpu/amd/model_fxx/init_cpus.c +++ b/src/cpu/amd/model_fxx/init_cpus.c @@ -342,7 +342,7 @@ static u32 init_cpus(u32 cpu_init_detectedx) static u32 is_core0_started(u32 nodeid) { u32 htic; - device_t device; + pci_devfn_t device; device = PCI_DEV(0, 0x18 + nodeid, 0); htic = pci_read_config32(device, HT_INIT_CONTROL); htic &= HTIC_INIT_Detect; diff --git a/src/include/cpu/amd/model_fxx_rev.h b/src/include/cpu/amd/model_fxx_rev.h index be961f2..88945a2 100644 --- a/src/include/cpu/amd/model_fxx_rev.h +++ b/src/include/cpu/amd/model_fxx_rev.h @@ -73,29 +73,29 @@ static inline int is_e0_later_in_bsp(int nodeid) if (IS_ENABLED(CONFIG_K8_REV_F_SUPPORT)) return 1;
- if (nodeid == 0) { // we don't need to do that for node 0 in core0/node0 - return !is_cpu_pre_e0(); - } - // d0 will be treated as e0 with this methods, but the d0 nb_cfg_54 always 0 - device_t dev; - dev = PCI_DEV(0, 0x18+nodeid,2); - val_old = pci_read_config32(dev, 0x80); - val = val_old; - val |= (1<<3); - pci_write_config32(dev, 0x80, val); - val = pci_read_config32(dev, 0x80); - e0_later = !!(val & (1<<3)); - if (e0_later) { // pre_e0 bit 3 always be 0 and can not be changed - pci_write_config32(dev, 0x80, val_old); // restore it - } - - return e0_later; + if (nodeid==0) { // we don't need to do that for node 0 in core0/node0 + return !is_cpu_pre_e0(); + } + // d0 will be treated as e0 with this methods, but the d0 nb_cfg_54 always 0 + pci_devfn_t dev; + dev = PCI_DEV(0, 0x18+nodeid,2); + val_old = pci_read_config32(dev, 0x80); + val = val_old; + val |= (1<<3); + pci_write_config32(dev, 0x80, val); + val = pci_read_config32(dev, 0x80); + e0_later = !!(val & (1<<3)); + if (e0_later) { // pre_e0 bit 3 always be 0 and can not be changed + pci_write_config32(dev, 0x80, val_old); // restore it + } + + return e0_later; }
static inline int is_cpu_f0_in_bsp(int nodeid) { uint32_t dword; - device_t dev; + pci_devfn_t dev; if (!IS_ENABLED(CONFIG_K8_REV_F_SUPPORT)) return 0; dev = PCI_DEV(0, 0x18+nodeid, 3); @@ -105,8 +105,9 @@ static inline int is_cpu_f0_in_bsp(int nodeid)
static inline int is_cpu_pre_f2_in_bsp(int nodeid) { - uint32_t dword; - device_t dev; + uint32_t dword; + pci_devfn_t dev; + if (!IS_ENABLED(CONFIG_K8_REV_F_SUPPORT)) return 1; dev = PCI_DEV(0, 0x18+nodeid, 3);
