Julius Werner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61308 )
Change subject: console: Add loglevel marker codes to stored consoles ......................................................................
In order to provide the same loglevel prefixes and highlighting that were recently introduced for "interactive" consoles (e.g. UART) to "stored" consoles (e.g. CBMEM) but minimize the amont of extra storage space wasted on this info, this patch will write a 1-byte control character marker indicating the loglevel to the start of every line logged in those consoles. The `cbmem` utility will then interpret those markers and translate them back into loglevel prefixes and escape sequences as needed.
Since coreboot and userspace log readers aren't always in sync, occasionally an older reader may come across these markers and not know how to interpret them... but that should usually be fine, as the range chosen contains non-printable ASCII characters that normally have no effect on the terminal. At worst the outdated reader would display one garbled character at the start of every line which isn't that bad. (Older versions of the `cbmem` utility will translate non-printable characters into `?` question marks.)
Signed-off-by: Julius Werner jwerner@chromium.org Change-Id: I86073f48aaf1e0a58e97676fb80e2475ec418ffc Reviewed-on: https://review.coreboot.org/c/coreboot/+/61308 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/commonlib/include/commonlib/loglevel.h M src/console/printk.c M src/lib/cbmem_console.c M util/cbmem/cbmem.c 4 files changed, 51 insertions(+), 5 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/src/commonlib/include/commonlib/loglevel.h b/src/commonlib/include/commonlib/loglevel.h index 1594465..34d9824 100644 --- a/src/commonlib/include/commonlib/loglevel.h +++ b/src/commonlib/include/commonlib/loglevel.h @@ -201,6 +201,20 @@ [BIOS_SPEW] = "0", };
+/* + * When storing console logs somewhere for later retrieval, log level prefixes + * and escape sequences should not be stored raw to preserve space. Instead, a + * non-printable control character marker is inserted into the log to indicate + * the log level. Decoders reading this character should translate it back into + * the respective escape sequence and prefix. If a decoder doesn't support this + * feature, the non-printable character should usually be harmless. + */ +#define BIOS_LOG_MARKER_START 0x10 +#define BIOS_LOG_MARKER_END (BIOS_LOG_MARKER_START + BIOS_LOG_PREFIX_MAX_LEVEL) +#define BIOS_LOG_IS_MARKER(c) ((c) >= BIOS_LOG_MARKER_START && (c) <= BIOS_LOG_MARKER_END) +#define BIOS_LOG_LEVEL_TO_MARKER(level) (BIOS_LOG_MARKER_START + (level)) +#define BIOS_LOG_MARKER_TO_LEVEL(c) ((c) - BIOS_LOG_MARKER_START) + #endif /* __ASSEMBLER__ */
#endif /* LOGLEVEL_H */ diff --git a/src/console/printk.c b/src/console/printk.c index 93aed52..ffa3106 100644 --- a/src/console/printk.c +++ b/src/console/printk.c @@ -78,8 +78,16 @@ { if (state.level > BIOS_LOG_PREFIX_MAX_LEVEL) return; - if (state.speed == CONSOLE_LOG_FAST) + + /* Stored consoles just get a single control char marker to save space. If we are in + LOG_FAST mode, just write the marker to CBMC and exit -- the rest of this function + implements the LOG_ALL case. */ + unsigned char marker = BIOS_LOG_LEVEL_TO_MARKER(state.level); + if (state.speed == CONSOLE_LOG_FAST) { + __cbmemc_tx_byte(marker); return; + } + console_stored_tx_byte(marker, NULL);
/* Interactive consoles get a `[DEBUG] ` style readable prefix, and potentially an escape sequence for highlighting. */ diff --git a/src/lib/cbmem_console.c b/src/lib/cbmem_console.c index 2faa5d5..0c56095 100644 --- a/src/lib/cbmem_console.c +++ b/src/lib/cbmem_console.c @@ -182,12 +182,16 @@ if (current_console->cursor & OVERFLOW) { for (cursor = current_console->cursor & CURSOR_MASK; cursor < current_console->size; cursor++) { + if (BIOS_LOG_IS_MARKER(current_console->body[cursor])) + continue; if (current_console->body[cursor] == '\n') uart_tx_byte(console_index, '\r'); uart_tx_byte(console_index, current_console->body[cursor]); } } for (cursor = 0; cursor < (current_console->cursor & CURSOR_MASK); cursor++) { + if (BIOS_LOG_IS_MARKER(current_console->body[cursor])) + continue; if (current_console->body[cursor] == '\n') uart_tx_byte(console_index, '\r'); uart_tx_byte(console_index, current_console->body[cursor]); @@ -206,9 +210,11 @@ if (current_console->cursor & OVERFLOW) for (cursor = current_console->cursor & CURSOR_MASK; cursor < current_console->size; cursor++) - do_putchar(current_console->body[cursor]); + if (!BIOS_LOG_IS_MARKER(current_console->body[cursor])) + do_putchar(current_console->body[cursor]); for (cursor = 0; cursor < (current_console->cursor & CURSOR_MASK); cursor++) - do_putchar(current_console->body[cursor]); + if (!BIOS_LOG_IS_MARKER(current_console->body[cursor])) + do_putchar(current_console->body[cursor]);
console_paused = false; } diff --git a/util/cbmem/cbmem.c b/util/cbmem/cbmem.c index 51b4adc..d5a8ae4 100644 --- a/util/cbmem/cbmem.c +++ b/util/cbmem/cbmem.c @@ -18,6 +18,7 @@ #include <assert.h> #include <regex.h> #include <commonlib/bsd/cbmem_id.h> +#include <commonlib/loglevel.h> #include <commonlib/timestamp_serialized.h> #include <commonlib/tcpa_log_serialized.h> #include <commonlib/coreboot_tables.h> @@ -783,7 +784,8 @@ /* Slight memory corruption may occur between reboots and give us a few unprintable characters like '\0'. Replace them with '?' on output. */ for (cursor = 0; cursor < size; cursor++) - if (!isprint(console_c[cursor]) && !isspace(console_c[cursor])) + if (!isprint(console_c[cursor]) && !isspace(console_c[cursor]) + && !BIOS_LOG_IS_MARKER(console_c[cursor])) console_c[cursor] = '?';
/* We detect the reboot cutoff by looking for a bootblock, romstage or @@ -822,7 +824,23 @@ cursor = previous; }
- puts(console_c + cursor); + char c; + int tty = isatty(fileno(stdout)); + while ((c = console_c[cursor++])) { + if (BIOS_LOG_IS_MARKER(c)) { + int lvl = BIOS_LOG_MARKER_TO_LEVEL(c); + if (tty) + printf(BIOS_LOG_ESCAPE_PATTERN, bios_log_escape[lvl]); + printf(BIOS_LOG_PREFIX_PATTERN, bios_log_prefix[lvl]); + } else { + putchar(c); + if (tty && c == '\n') + printf(BIOS_LOG_ESCAPE_RESET); + } + } + if (tty) + printf(BIOS_LOG_ESCAPE_RESET); + free(console_c); unmap_memory(&console_mapping); }
10 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
