Julius Werner has submitted this change and it was merged. ( https://review.coreboot.org/22746 )
Change subject: google/scarlet: update Kingdisplay kd097d04 timing ......................................................................
With the old timing, the hblank time isn't large enough, it may cause display artifacts. So fix it.
BUG=b:70160653 TEST=panel work on Scarlet rev2 board
Change-Id: Ib061f5e215611d20f59e3f24cfe3c7fbc507ebed Signed-off-by: Lin Huang hl@rock-chips.com Reviewed-on: https://review.coreboot.org/22746 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Julius Werner jwerner@chromium.org --- M src/mainboard/google/gru/mainboard.c 1 file changed, 4 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Julius Werner: Looks good to me, approved
diff --git a/src/mainboard/google/gru/mainboard.c b/src/mainboard/google/gru/mainboard.c index d83c486..9a241f5 100644 --- a/src/mainboard/google/gru/mainboard.c +++ b/src/mainboard/google/gru/mainboard.c @@ -527,14 +527,14 @@
static const struct edid_mode kd097d04_edid_mode = { .name = "1536x2048@60Hz", - .pixel_clock = 213000, + .pixel_clock = 216000, .refresh = 60, .ha = 1536, - .hbl = 164, - .hso = 70, + .hbl = 186, + .hso = 81, .hspw = 24, .va = 2048, - .vbl = 44, + .vbl = 42, .vso = 17, .vspw = 2, };
