Paul Fagerburg has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56451 )
Change subject: soc/amd/cezanne: Generate IVRS for cezanne ......................................................................
Generate IVRS for cezanne using common IVRS generation code.
BUG=b:190515051 TEST=Build cezanne coreboot image. Compare IVRS table with agesa generated tables.
Signed-off-by: Jason Glenesk jason.glenesk@amd.corp-partner.google.com Change-Id: Ie15addba62ec7da25a7452512b6871e46c61b0a1 Reviewed-on: https://review.coreboot.org/c/coreboot/+/56451 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/cezanne/Kconfig M src/soc/amd/cezanne/agesa_acpi.c 2 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/src/soc/amd/cezanne/Kconfig b/src/soc/amd/cezanne/Kconfig index fab31d4..306f181 100644 --- a/src/soc/amd/cezanne/Kconfig +++ b/src/soc/amd/cezanne/Kconfig @@ -42,6 +42,7 @@ select SOC_AMD_COMMON_BLOCK_ACPIMMIO select SOC_AMD_COMMON_BLOCK_ACPI_ALIB select SOC_AMD_COMMON_BLOCK_ACPI_GPIO + select SOC_AMD_COMMON_BLOCK_ACPI_IVRS select SOC_AMD_COMMON_BLOCK_AOAC select SOC_AMD_COMMON_BLOCK_APOB select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS diff --git a/src/soc/amd/cezanne/agesa_acpi.c b/src/soc/amd/cezanne/agesa_acpi.c index 35114a1..47ca5f2 100644 --- a/src/soc/amd/cezanne/agesa_acpi.c +++ b/src/soc/amd/cezanne/agesa_acpi.c @@ -10,8 +10,17 @@ uintptr_t agesa_write_acpi_tables(const struct device *device, uintptr_t current, acpi_rsdp_t *rsdp) { + acpi_ivrs_t *ivrs; + /* add ALIB SSDT from HOB */ current = add_agesa_fsp_acpi_table(AMD_FSP_ACPI_ALIB_HOB_GUID, "ALIB", rsdp, current);
+ /* IVRS */ + current = ALIGN(current, 8); + ivrs = (acpi_ivrs_t *) current; + acpi_create_ivrs(ivrs, acpi_fill_ivrs); + current += ivrs->header.length; + acpi_add_table(rsdp, ivrs); + return current; }
