Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6135
commit 4396eaaef426882737656f078888707a27f3758e Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Fri Jun 27 12:13:30 2014 +1000
intel: Make monotonic timer a first class citizen
NOTFORMERGE
Change-Id: I4e43d2680bf84bc525138f71c2b813b0f6be5265 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/cpu/intel/model_206ax/Kconfig | 2 ++ src/mainboard/intel/baskingridge/Kconfig | 1 + 2 files changed, 3 insertions(+)
diff --git a/src/cpu/intel/model_206ax/Kconfig b/src/cpu/intel/model_206ax/Kconfig index a679e00..1456f94 100644 --- a/src/cpu/intel/model_206ax/Kconfig +++ b/src/cpu/intel/model_206ax/Kconfig @@ -19,6 +19,8 @@ config CPU_SPECIFIC_OPTIONS select PARALLEL_CPU_INIT #select AP_IN_SIPI_WAIT select TSC_SYNC_MFENCE + select HAVE_MONOTONIC_TIMER + select LAPIC_MONOTONIC_TIMER
config BOOTBLOCK_CPU_INIT string diff --git a/src/mainboard/intel/baskingridge/Kconfig b/src/mainboard/intel/baskingridge/Kconfig index b52df97..051072a 100644 --- a/src/mainboard/intel/baskingridge/Kconfig +++ b/src/mainboard/intel/baskingridge/Kconfig @@ -12,6 +12,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_SMI_HANDLER select MAINBOARD_HAS_CHROMEOS select LAPIC_MONOTONIC_TIMER + select MONOTONIC_TIMER_MSR
config MAINBOARD_DIR string
