Reka Norman has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/68641 )
Change subject: arch/x86/postcar_loader: Don't add postcar to stage cache ......................................................................
In romstage, CBMEM and TSEG are not yet cached, so reading/writing to the stage cache is slow. This means there isn't really any benefit to adding postcar to the stage cache: - During boot, adding it to the stage cache adds a few ms of boot time, since writing to uncached memory is slow. - During S3 resume, reading from stage cache takes rougly the same time as reading from SPI, so we get little or no savings anyway.
E.g. on nivviks, this change saves 6 ms of boot time and 2 ms of S3 resume time.
Adding postcar to stage cache: Boot: rmodule_stage_load() - 4 ms stage_cache_add() - 6 ms S3 resume: stage_cache_load_stage() - 6 ms
Not adding postcar to stage cache: Boot: rmodule_stage_load() - 4 ms S3 resume: rmodule_stage_load() - 4 ms
Savings: Boot time - 6 ms S3 resume time - 2 ms
------------------------------------ Savings on other devices:
nivviks anahera kindred treeya rmodule_stage_load() 4.0 1.4 0.8 2.8 stage_cache_add() 6.0 2.8 1.5 2.0 stage_cache_load_stage() 6.0 2.8 1.5 2.0
Boot time savings 6.0 2.8 1.5 2.0 S3 resume time savings 2.0 1.4 0.7 -0.8
BUG=b:247940538 TEST=On nivviks, boot and check S3 resume still works. Add logging to check postcar is added to stage cache when POSTCAR_IN_STAGE_CACHE is selected, and not added otherwise.
Change-Id: I3614c0874a6c71d13606b0b782ea445692d88bb1 Signed-off-by: Reka Norman rekanorman@chromium.org --- M src/arch/x86/Kconfig M src/arch/x86/postcar_loader.c 2 files changed, 67 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/41/68641/1
diff --git a/src/arch/x86/Kconfig b/src/arch/x86/Kconfig index c00eb0c..bba3eba 100644 --- a/src/arch/x86/Kconfig +++ b/src/arch/x86/Kconfig @@ -207,6 +207,16 @@ depends on ARCH_X86 depends on !RESET_VECTOR_IN_RAM
+config POSTCAR_IN_STAGE_CACHE + bool + depends on !NO_STAGE_CACHE && POSTCAR_STAGE + help + In romstage, CBMEM and TSEG are not yet cached, so reading and + writing to stage cache is slow. This means on most platforms + adding postcar to the stage cache gives little if any S3 resume + time savings, while also adding a few ms of boot time. Therefore + this config is disabled by default. + config VERSTAGE_DEBUG_SPINLOOP bool default n diff --git a/src/arch/x86/postcar_loader.c b/src/arch/x86/postcar_loader.c index c6a128b..8987e25 100644 --- a/src/arch/x86/postcar_loader.c +++ b/src/arch/x86/postcar_loader.c @@ -110,7 +110,8 @@
finalize_load(rsl.params, (uintptr_t)pcf->mtrr);
- stage_cache_add(STAGE_POSTCAR, prog); + if (CONFIG(POSTCAR_IN_STAGE_CACHE)) + stage_cache_add(STAGE_POSTCAR, prog); }
/* @@ -141,7 +142,7 @@ struct prog prog = PROG_INIT(PROG_POSTCAR, CONFIG_CBFS_PREFIX "/postcar");
- if (resume_from_stage_cache()) { + if (CONFIG(POSTCAR_IN_STAGE_CACHE) && resume_from_stage_cache()) { stage_cache_load_stage(STAGE_POSTCAR, &prog); /* This is here to allow platforms to pass different stack parameters between S3 resume and normal boot. On the
