Attention is currently required from: Michael Niewöhner, Karthik Ramasubramanian. Hello Felix Singer, build bot (Jenkins), Patrick Georgi, Furquan Shaikh, Benjamin Doron, Paul Menzel, Subrata Banik, Kyösti Mälkki, Andrey Petrov, Patrick Rudolph, Lance Zhao, Nico Huber, Martin Roth, Tim Wawrzynczak, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/48829
Change subject: soc/intel/*: drop UART pad configuration from common code ......................................................................
UART pad configuration should not be done in common code, because that may cause short circuits, when the user sets a wrong UART index.
Since all boards do pad setup on their own now, finally drop the pad configuration from SoC common code.
Change-Id: Id03719eb8bd0414083148471ed05dea62a895126 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/alderlake/uart.c M src/soc/intel/apollolake/uart.c M src/soc/intel/cannonlake/bootblock/bootblock.c M src/soc/intel/cannonlake/uart.c M src/soc/intel/common/block/include/intelblocks/uart.h M src/soc/intel/common/block/uart/Kconfig M src/soc/intel/common/block/uart/uart.c M src/soc/intel/elkhartlake/uart.c M src/soc/intel/icelake/uart.c M src/soc/intel/jasperlake/uart.c M src/soc/intel/skylake/uart.c M src/soc/intel/tigerlake/uart.c 12 files changed, 47 insertions(+), 335 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/48829/10
