Attention is currently required from: Anil Kumar K, Bora Guvendik, Cliff Huang, Martin L Roth, Wonkyu Kim.
Hello Anil Kumar K, Bora Guvendik, Martin L Roth, Subrata Banik, Wonkyu Kim, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84107?usp=email
Change subject: payloads/depthcharge: Add default 64-bit libpayload config ......................................................................
Add CONFIG_LP_DEFCONFIG_OVERRIDE_X64 flag to select default 64-bit config file in payloads/libpayload/configs directory.
This is used in standalone environment. The existing libpayload deconfig file is for boards with 32-bit format and deconfig_64 file is added for 64-bit without adding specific board.[board name] file in libpayload.
BUG=none TEST=Build with this new flag and check that the libpayload and depthcharge.elf are built in 64-bit format.
Signed-off-by: Cliff Huang cliff.huang@intel.com Change-Id: Iac07cf9e3c11e49955c69553407be76ef4f8c060 --- M payloads/external/Makefile.mk M payloads/external/depthcharge/Kconfig M payloads/external/depthcharge/Makefile A payloads/libpayload/configs/defconfig_64 4 files changed, 27 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/84107/4
