Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44121 )
Change subject: nb/intel/sandybridge: Refactor `get_pcie_bar` ......................................................................
Turn it into `decode_pcie_bar`, taken from gm45.
Change-Id: Id1c2cfbcac1a798d046beced790930511dc97972 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/44121 Reviewed-by: Patrick Rudolph siro@das-labor.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/northbridge/intel/sandybridge/northbridge.c 1 file changed, 17 insertions(+), 16 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved Arthur Heymans: Looks good to me, but someone else must approve
diff --git a/src/northbridge/intel/sandybridge/northbridge.c b/src/northbridge/intel/sandybridge/northbridge.c index 1d20a4b..8f1db97 100644 --- a/src/northbridge/intel/sandybridge/northbridge.c +++ b/src/northbridge/intel/sandybridge/northbridge.c @@ -2,6 +2,7 @@
#include <console/console.h> #include <acpi/acpi.h> +#include <commonlib/helpers.h> #include <device/pci_ops.h> #include <stdint.h> #include <delay.h> @@ -39,18 +40,16 @@ static const int legacy_hole_base_k = 0xa0000 / 1024; static const int legacy_hole_size_k = 384;
-static int get_pcie_bar(u32 *base) +static int decode_pcie_bar(u32 *const base, u32 *const len) { - struct device *dev; - u32 pciexbar_reg; - *base = 0; + *len = 0;
- dev = pcidev_on_root(0, 0); + struct device *dev = pcidev_on_root(0, 0); if (!dev) return 0;
- pciexbar_reg = pci_read_config32(dev, PCIEXBAR); + const u32 pciexbar_reg = pci_read_config32(dev, PCIEXBAR);
/* MMCFG not supported or not enabled */ if (!(pciexbar_reg & (1 << 0))) @@ -58,14 +57,17 @@
switch ((pciexbar_reg >> 1) & 3) { case 0: /* 256MB */ - *base = pciexbar_reg & (0xffffffffULL << 28); - return 256; + *base = pciexbar_reg & (0x0f << 28); + *len = 256 * MiB; + return 1; case 1: /* 128M */ - *base = pciexbar_reg & (0xffffffffULL << 27); - return 128; + *base = pciexbar_reg & (0x1f << 27); + *len = 128 * MiB; + return 1; case 2: /* 64M */ - *base = pciexbar_reg & (0xffffffffULL << 26); - return 64; + *base = pciexbar_reg & (0x3f << 26); + *len = 64 * MiB; + return 1; }
return 0; @@ -129,8 +131,7 @@
static void mc_read_resources(struct device *dev) { - u32 pcie_config_base; - int buses; + u32 pcie_config_base, pcie_config_len; uint64_t tom, me_base, touud; uint32_t tseg_base, uma_size, tolud; uint16_t ggc; @@ -139,8 +140,8 @@
pci_dev_read_resources(dev);
- buses = get_pcie_bar(&pcie_config_base); - if (buses) { + if (decode_pcie_bar(&pcie_config_base, &pcie_config_len)) { + const int buses = pcie_config_len / MiB; struct resource *resource = new_resource(dev, PCIEXBAR); mmconf_resource_init(resource, pcie_config_base, buses); }
