Stefan Tauner (stefan.tauner@gmx.at) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/9305
commit 7b88baa66f7d0bf0c75872dee1a2fe59e6fb3040 Author: Stefan Tauner stefan.tauner@gmx.at Date: Mon May 2 23:16:57 2016 +0200
utils: introduce find_usbdebug.sh to help find USB debug ports
Carl-Daniel made this script a long time ago but it never was picked up in the tree. Now that USB debugging is way more common it makes sense to include it.
I have made a number of changes to the original version: * -h help text * check for running as root * enhanced readability (test -> if) * new execution flow and refined output that better shows the device(s) attached to the debug port(s) * handling of Intel rate-matching hubs * hiding of (bogus) error messages from lspci and lsusb
Signed-off-by: Stefan Tauner stefan.tauner@gmx.at Change-Id: Iadf775e990f5c5f91a28d57e3331d1f59acee305 --- util/find_usbdebug/find_usbdebug.sh | 169 ++++++++++++++++++++++++++++++++++++ 1 file changed, 169 insertions(+)
diff --git a/util/find_usbdebug/find_usbdebug.sh b/util/find_usbdebug/find_usbdebug.sh new file mode 100755 index 0000000..30bf86f --- /dev/null +++ b/util/find_usbdebug/find_usbdebug.sh @@ -0,0 +1,169 @@ +#!/bin/bash + +# Copyright 2008 Carl-Daniel Hailfinger +# Copyright 2015 Stefan Tauner +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. + +LANG=C +# Some tools emmit errors that don't matter (bugs in lspci/PCI firmware and lsusb). +# To shown them anyway (e.g. for debugging) comment next line. +exec 2>/dev/null + +if [ "$1" = "-h" ]; then + printf "Usage: $0 [-h | path to dmesg log] + +This script tries to find USB ports compatible with USB2/EHCI debug devices and +helps you to find their physical locations. To that end, attach at least one +uniquely identifiable device to a USB port and run this script. The device needs +to be visible in the output of "lsusb -t" (debug devices are often *not*!). + +After determining compatibility of the USB controllers the script will print the +devices attached to the debug port as shown by lsusb. If nothing shows up simply +switch ports and repeat the process. + +Note: usually only one port is supported for debugging.\n" + exit 0 +fi +uid=`id -u` +if [ "$uid" -ne 0 ]; then + echo "Must be run as root. Exiting." + exit 1 +fi +dmesgfile=$1 + +find_devs_in_tree () { + bus=$1 + port=$2 + busstr=`printf "Bus %02d" "$bus"` + portstr="Port $port" + + hubs_to_ignore="8087:0020 8087:0024" + reqlvl=1 + + found= + # Iterate over the output of lsusb -t because it contains the physical port numbers + while IFS='' read -r line; do + # We need to keep track of the current bus "branch" + # Look out for lines starting with /: (that indicate a bus) + if [ "${line#*/:}" != "$line" ]; then + if [ "${line#*$busstr}" != "$line" ]; then + cur_bus=$busstr + else + cur_bus= + fi + continue + fi + + # Skip all lines not belonging to the wanted bus number + if [ "$cur_bus" != "$busstr" ]; then + continue + fi + + # Calculate current USB tier/level + spaces="${line%%[!' ']*}" + curlvl=$((${#spaces} / 4)) + if [ $curlvl -ne $reqlvl ]; then + continue + fi + + # Fetch USB IDs of the current device + dev=`echo ${line#*Dev } | cut -d ',' -f 1` + lsusbline=`lsusb -s "$bus":"$dev"` + if [[ ! "$lsusbline" =~ .*([[:xdigit:]]{4}:[[:xdigit:]]{4}) ]]; then + printf "Unexpected output from "%s": "%s"\n" "lsusb -s $bus:$dev" "$usbline" + exit 1 + fi + ids=${BASH_REMATCH[1]} + + # Skip over rate matching hubs + if [[ "$hubs_to_ignore" == *"$ids"* ]]; then + ((reqlvl += 1)) + continue + fi + + # Check for matching physical USB port + if [ "${line#*$portstr}" != "$line" ]; then + echo "$lsusbline" + return + fi + done<< EOF +$(lsusb -t) +EOF + if [ -z "$found" ]; then + echo "none" + fi +} + +debug_lspci_devs=`lspci -nvvD | + grep -i "^[0-9a-f]|debug port" | + grep -iB1 --no-group-separator "debug port" | + grep -vi "debug port" | + cut -f 1 -d" " | + sort | + xargs echo` + +if [ -z "$debug_lspci_devs" ]; then + printf "No USB controller with debug capability found by lspci.\n +Possible reasons: lspci too old, USB controller does not support a debug device, ... Exiting.\n" + exit 1 +fi +printf "The following PCI devices support a USB debug port (says lspci): $debug_lspci_devs\n" + +debug_dmesg_devs_with_port=`( test -z "$dmesgfile" && + dmesg || + cat "$dmesgfile") | + grep -i "ehci.*debug port" | + sed "s/.* ([0-9a-f]*:*[0-9a-f]{2}:[0-9a-f]{2}.[0-9a-f]).*ebug port /\1 /" | + sort` + +debug_dmesg_devs=`echo "$debug_dmesg_devs_with_port" | + cut -f 1 -d" " | + xargs echo` + +if [ -z "$debug_dmesg_devs" ]; then + printf "dmesg does not show any supported ports.\n +Possible reasons: dmesg scrolled off, kernel too old, USB controller does not support a debug device, ... Exiting.\n +Note: You can specify a file containing kernel messages as an argument to this program (e.g. /var/log/dmesg)." + exit 1 +fi + +if [ "$debug_lspci_devs" != "$debug_dmesg_devs" ]; then + echo "lspci and the kernel do not agree on USB debug device support. Exiting." + exit 1 +fi + +printf "and the kernel agrees, good.\n\n" + +while true; do + for dev in $debug_dmesg_devs; do + bus=`lsusb -v | + grep "^Bus|iSerial.*" | + grep -B1 --no-group-separator "iSerial.*$dev" | + grep "^Bus" | + sed "s/Bus *0*([0-9a-f]*).*/\1/"` + port=`echo "$debug_dmesg_devs_with_port" | + grep "^$dev" | + cut -f 2 -d" "` + + echo "Device(s) currently connected to the debug-capable port $port on PCI device $dev, USB bus $bus:" + + find_devs_in_tree "$bus" "$port" + echo + done + + echo "Enter 'q' to abort or anything else to repeat" + read -r r + if [ $? -ne 0 -o "$r" = "q" ]; then + break; + fi +done + +exit 0
