Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4834
commit 6ba7b220fedae0ebe2f53b845395ebdd9755ad2a Author: Alexandru Gagniuc mr.nuke.me@gmail.com Date: Sun Jan 26 22:55:01 2014 -0600
cbfstool: Use stdint and stdbool types in lzma code
This is the first patch on a long road to refactor and fix the lzma code in cbfstool. I want to submit it in small atomic patches, so that any potential errors are easy to spot before it's too late.
Change-Id: Ib557f8c83f49f18488639f38bf98d3ce849e61af Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- util/cbfstool/lzma/C/LzFind.c | 164 +++++----- util/cbfstool/lzma/C/LzFind.h | 84 +++--- util/cbfstool/lzma/C/LzHash.h | 32 +- util/cbfstool/lzma/C/LzmaDec.c | 144 ++++----- util/cbfstool/lzma/C/LzmaDec.h | 44 +-- util/cbfstool/lzma/C/LzmaEnc.c | 670 ++++++++++++++++++++--------------------- util/cbfstool/lzma/C/LzmaEnc.h | 14 +- util/cbfstool/lzma/C/Types.h | 66 +--- util/cbfstool/lzma/lzma.c | 6 +- 9 files changed, 592 insertions(+), 632 deletions(-)
diff --git a/util/cbfstool/lzma/C/LzFind.c b/util/cbfstool/lzma/C/LzFind.c index 8f204af..501c595 100644 --- a/util/cbfstool/lzma/C/LzFind.c +++ b/util/cbfstool/lzma/C/LzFind.c @@ -7,10 +7,10 @@ #include "LzHash.h"
#define kEmptyHashValue 0 -#define kMaxValForNormalize ((UInt32)0xFFFFFFFF) +#define kMaxValForNormalize ((uint32_t)0xFFFFFFFF) #define kNormalizeStepMin (1 << 10) /* it must be power of 2 */ #define kNormalizeMask (~(kNormalizeStepMin - 1)) -#define kMaxHistorySize ((UInt32)3 << 30) +#define kMaxHistorySize ((uint32_t)3 << 30)
#define kStartMaxLen 3
@@ -25,9 +25,9 @@ static void LzInWindow_Free(CMatchFinder *p, ISzAlloc *alloc)
/* keepSizeBefore + keepSizeAfter + keepSizeReserv must be < 4G) */
-static int LzInWindow_Create(CMatchFinder *p, UInt32 keepSizeReserv, ISzAlloc *alloc) +static int LzInWindow_Create(CMatchFinder *p, uint32_t keepSizeReserv, ISzAlloc *alloc) { - UInt32 blockSize = p->keepSizeBefore + p->keepSizeAfter + keepSizeReserv; + uint32_t blockSize = p->keepSizeBefore + p->keepSizeAfter + keepSizeReserv; if (p->directInput) { p->blockSize = blockSize; @@ -37,17 +37,17 @@ static int LzInWindow_Create(CMatchFinder *p, UInt32 keepSizeReserv, ISzAlloc *a { LzInWindow_Free(p, alloc); p->blockSize = blockSize; - p->bufferBase = (Byte *)alloc->Alloc(alloc, (size_t)blockSize); + p->bufferBase = (uint8_t *)alloc->Alloc(alloc, (size_t)blockSize); } return (p->bufferBase != 0); }
-Byte *MatchFinder_GetPointerToCurrentPos(CMatchFinder *p) { return p->buffer; } -static Byte MatchFinder_GetIndexByte(CMatchFinder *p, Int32 bindex) { return p->buffer[bindex]; } +uint8_t *MatchFinder_GetPointerToCurrentPos(CMatchFinder *p) { return p->buffer; } +static uint8_t MatchFinder_GetIndexuint8_t(CMatchFinder *p, int32_t bindex) { return p->buffer[bindex]; }
-static UInt32 MatchFinder_GetNumAvailableBytes(CMatchFinder *p) { return p->streamPos - p->pos; } +static uint32_t MatchFinder_GetNumAvailableuint8_ts(CMatchFinder *p) { return p->streamPos - p->pos; }
-void MatchFinder_ReduceOffsets(CMatchFinder *p, UInt32 subValue) +void MatchFinder_ReduceOffsets(CMatchFinder *p, uint32_t subValue) { p->posLimit -= subValue; p->pos -= subValue; @@ -60,9 +60,9 @@ static void MatchFinder_ReadBlock(CMatchFinder *p) return; if (p->directInput) { - UInt32 curSize = 0xFFFFFFFF - p->streamPos; + uint32_t curSize = 0xFFFFFFFF - p->streamPos; if (curSize > p->directInputRem) - curSize = (UInt32)p->directInputRem; + curSize = (uint32_t)p->directInputRem; p->directInputRem -= curSize; p->streamPos += curSize; if (p->directInputRem == 0) @@ -71,7 +71,7 @@ static void MatchFinder_ReadBlock(CMatchFinder *p) } for (;;) { - Byte *dest = p->buffer + (p->streamPos - p->pos); + uint8_t *dest = p->buffer + (p->streamPos - p->pos); size_t size = (p->bufferBase + p->blockSize - dest); if (size == 0) return; @@ -83,7 +83,7 @@ static void MatchFinder_ReadBlock(CMatchFinder *p) p->streamEndWasReached = 1; return; } - p->streamPos += (UInt32)size; + p->streamPos += (uint32_t)size; if (p->streamPos - p->pos > p->keepSizeAfter) return; } @@ -132,7 +132,7 @@ static void MatchFinder_SetDefaultSettings(CMatchFinder *p)
void MatchFinder_Construct(CMatchFinder *p) { - UInt32 i; + uint32_t i; p->bufferBase = 0; p->directInput = 0; p->hash = 0; @@ -140,7 +140,7 @@ void MatchFinder_Construct(CMatchFinder *p)
for (i = 0; i < 256; i++) { - UInt32 r = i; + uint32_t r = i; int j; for (j = 0; j < 8; j++) r = (r >> 1) ^ (kCrcPoly & ~((r & 1) - 1)); @@ -160,26 +160,26 @@ void MatchFinder_Free(CMatchFinder *p, ISzAlloc *alloc) LzInWindow_Free(p, alloc); }
-static CLzRef* AllocRefs(UInt32 num, ISzAlloc *alloc) +static CLzRef* AllocRefs(uint32_t num, ISzAlloc *alloc) { - size_t sizeInBytes = (size_t)num * sizeof(CLzRef); - if (sizeInBytes / sizeof(CLzRef) != num) + size_t sizeInuint8_ts = (size_t)num * sizeof(CLzRef); + if (sizeInuint8_ts / sizeof(CLzRef) != num) return 0; - return (CLzRef *)alloc->Alloc(alloc, sizeInBytes); + return (CLzRef *)alloc->Alloc(alloc, sizeInuint8_ts); }
-int MatchFinder_Create(CMatchFinder *p, UInt32 historySize, - UInt32 keepAddBufferBefore, UInt32 matchMaxLen, UInt32 keepAddBufferAfter, +int MatchFinder_Create(CMatchFinder *p, uint32_t historySize, + uint32_t keepAddBufferBefore, uint32_t matchMaxLen, uint32_t keepAddBufferAfter, ISzAlloc *alloc) { - UInt32 sizeReserv; + uint32_t sizeReserv; if (historySize > kMaxHistorySize) { MatchFinder_Free(p, alloc); return 0; } sizeReserv = historySize >> 1; - if (historySize > ((UInt32)2 << 30)) + if (historySize > ((uint32_t)2 << 30)) sizeReserv = historySize >> 2; sizeReserv += (keepAddBufferBefore + matchMaxLen + keepAddBufferAfter) / 2 + (1 << 19);
@@ -188,8 +188,8 @@ int MatchFinder_Create(CMatchFinder *p, UInt32 historySize, /* we need one additional byte, since we use MoveBlock after pos++ and before dictionary using */ if (LzInWindow_Create(p, sizeReserv, alloc)) { - UInt32 newCyclicBufferSize = historySize + 1; - UInt32 hs; + uint32_t newCyclicBufferSize = historySize + 1; + uint32_t hs; p->matchMaxLen = matchMaxLen; { p->fixedHashSize = 0; @@ -221,8 +221,8 @@ int MatchFinder_Create(CMatchFinder *p, UInt32 historySize, }
{ - UInt32 prevSize = p->hashSizeSum + p->numSons; - UInt32 newSize; + uint32_t prevSize = p->hashSizeSum + p->numSons; + uint32_t newSize; p->historySize = historySize; p->hashSizeSum = hs; p->cyclicBufferSize = newCyclicBufferSize; @@ -245,8 +245,8 @@ int MatchFinder_Create(CMatchFinder *p, UInt32 historySize,
static void MatchFinder_SetLimits(CMatchFinder *p) { - UInt32 limit = kMaxValForNormalize - p->pos; - UInt32 limit2 = p->cyclicBufferSize - p->cyclicBufferPos; + uint32_t limit = kMaxValForNormalize - p->pos; + uint32_t limit2 = p->cyclicBufferSize - p->cyclicBufferPos; if (limit2 < limit) limit = limit2; limit2 = p->streamPos - p->pos; @@ -260,7 +260,7 @@ static void MatchFinder_SetLimits(CMatchFinder *p) if (limit2 < limit) limit = limit2; { - UInt32 lenLimit = p->streamPos - p->pos; + uint32_t lenLimit = p->streamPos - p->pos; if (lenLimit > p->matchMaxLen) lenLimit = p->matchMaxLen; p->lenLimit = lenLimit; @@ -270,7 +270,7 @@ static void MatchFinder_SetLimits(CMatchFinder *p)
void MatchFinder_Init(CMatchFinder *p) { - UInt32 i; + uint32_t i; for (i = 0; i < p->hashSizeSum; i++) p->hash[i] = kEmptyHashValue; p->cyclicBufferPos = 0; @@ -282,17 +282,17 @@ void MatchFinder_Init(CMatchFinder *p) MatchFinder_SetLimits(p); }
-static UInt32 MatchFinder_GetSubValue(CMatchFinder *p) +static uint32_t MatchFinder_GetSubValue(CMatchFinder *p) { return (p->pos - p->historySize - 1) & kNormalizeMask; }
-void MatchFinder_Normalize3(UInt32 subValue, CLzRef *items, UInt32 numItems) +void MatchFinder_Normalize3(uint32_t subValue, CLzRef *items, uint32_t numItems) { - UInt32 i; + uint32_t i; for (i = 0; i < numItems; i++) { - UInt32 value = items[i]; + uint32_t value = items[i]; if (value <= subValue) value = kEmptyHashValue; else @@ -303,7 +303,7 @@ void MatchFinder_Normalize3(UInt32 subValue, CLzRef *items, UInt32 numItems)
static void MatchFinder_Normalize(CMatchFinder *p) { - UInt32 subValue = MatchFinder_GetSubValue(p); + uint32_t subValue = MatchFinder_GetSubValue(p); MatchFinder_Normalize3(subValue, p->hash, p->hashSizeSum + p->numSons); MatchFinder_ReduceOffsets(p, subValue); } @@ -319,22 +319,22 @@ static void MatchFinder_CheckLimits(CMatchFinder *p) MatchFinder_SetLimits(p); }
-static UInt32 * Hc_GetMatchesSpec(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byte *cur, CLzRef *son, - UInt32 _cyclicBufferPos, UInt32 _cyclicBufferSize, UInt32 cutValue, - UInt32 *distances, UInt32 maxLen) +static uint32_t * Hc_GetMatchesSpec(uint32_t lenLimit, uint32_t curMatch, uint32_t pos, const uint8_t *cur, CLzRef *son, + uint32_t _cyclicBufferPos, uint32_t _cyclicBufferSize, uint32_t cutValue, + uint32_t *distances, uint32_t maxLen) { son[_cyclicBufferPos] = curMatch; for (;;) { - UInt32 delta = pos - curMatch; + uint32_t delta = pos - curMatch; if (cutValue-- == 0 || delta >= _cyclicBufferSize) return distances; { - const Byte *pb = cur - delta; + const uint8_t *pb = cur - delta; curMatch = son[_cyclicBufferPos - delta + ((delta > _cyclicBufferPos) ? _cyclicBufferSize : 0)]; if (pb[maxLen] == cur[maxLen] && *pb == *cur) { - UInt32 len = 0; + uint32_t len = 0; while (++len != lenLimit) if (pb[len] != cur[len]) break; @@ -350,16 +350,16 @@ static UInt32 * Hc_GetMatchesSpec(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, } }
-UInt32 * GetMatchesSpec1(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byte *cur, CLzRef *son, - UInt32 _cyclicBufferPos, UInt32 _cyclicBufferSize, UInt32 cutValue, - UInt32 *distances, UInt32 maxLen) +uint32_t * GetMatchesSpec1(uint32_t lenLimit, uint32_t curMatch, uint32_t pos, const uint8_t *cur, CLzRef *son, + uint32_t _cyclicBufferPos, uint32_t _cyclicBufferSize, uint32_t cutValue, + uint32_t *distances, uint32_t maxLen) { CLzRef *ptr0 = son + (_cyclicBufferPos << 1) + 1; CLzRef *ptr1 = son + (_cyclicBufferPos << 1); - UInt32 len0 = 0, len1 = 0; + uint32_t len0 = 0, len1 = 0; for (;;) { - UInt32 delta = pos - curMatch; + uint32_t delta = pos - curMatch; if (cutValue-- == 0 || delta >= _cyclicBufferSize) { *ptr0 = *ptr1 = kEmptyHashValue; @@ -367,8 +367,8 @@ UInt32 * GetMatchesSpec1(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byt } { CLzRef *pair = son + ((_cyclicBufferPos - delta + ((delta > _cyclicBufferPos) ? _cyclicBufferSize : 0)) << 1); - const Byte *pb = cur - delta; - UInt32 len = (len0 < len1 ? len0 : len1); + const uint8_t *pb = cur - delta; + uint32_t len = (len0 < len1 ? len0 : len1); if (pb[len] == cur[len]) { if (++len != lenLimit && pb[len] == cur[len]) @@ -405,15 +405,15 @@ UInt32 * GetMatchesSpec1(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byt } }
-static void SkipMatchesSpec(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byte *cur, CLzRef *son, - UInt32 _cyclicBufferPos, UInt32 _cyclicBufferSize, UInt32 cutValue) +static void SkipMatchesSpec(uint32_t lenLimit, uint32_t curMatch, uint32_t pos, const uint8_t *cur, CLzRef *son, + uint32_t _cyclicBufferPos, uint32_t _cyclicBufferSize, uint32_t cutValue) { CLzRef *ptr0 = son + (_cyclicBufferPos << 1) + 1; CLzRef *ptr1 = son + (_cyclicBufferPos << 1); - UInt32 len0 = 0, len1 = 0; + uint32_t len0 = 0, len1 = 0; for (;;) { - UInt32 delta = pos - curMatch; + uint32_t delta = pos - curMatch; if (cutValue-- == 0 || delta >= _cyclicBufferSize) { *ptr0 = *ptr1 = kEmptyHashValue; @@ -421,8 +421,8 @@ static void SkipMatchesSpec(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const } { CLzRef *pair = son + ((_cyclicBufferPos - delta + ((delta > _cyclicBufferPos) ? _cyclicBufferSize : 0)) << 1); - const Byte *pb = cur - delta; - UInt32 len = (len0 < len1 ? len0 : len1); + const uint8_t *pb = cur - delta; + uint32_t len = (len0 < len1 ? len0 : len1); if (pb[len] == cur[len]) { while (++len != lenLimit) @@ -465,7 +465,7 @@ static void SkipMatchesSpec(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const static void MatchFinder_MovePos(CMatchFinder *p) { MOVE_POS; }
#define GET_MATCHES_HEADER2(minLen, ret_op) \ - UInt32 lenLimit; UInt32 hashValue; const Byte *cur; UInt32 curMatch; \ + uint32_t lenLimit; uint32_t hashValue; const uint8_t *cur; uint32_t curMatch; \ lenLimit = p->lenLimit; { if (lenLimit < minLen) { MatchFinder_MovePos(p); ret_op; }} \ cur = p->buffer;
@@ -475,15 +475,15 @@ static void MatchFinder_MovePos(CMatchFinder *p) { MOVE_POS; } #define MF_PARAMS(p) p->pos, p->buffer, p->son, p->cyclicBufferPos, p->cyclicBufferSize, p->cutValue
#define GET_MATCHES_FOOTER(offset, maxLen) \ - offset = (UInt32)(GetMatchesSpec1(lenLimit, curMatch, MF_PARAMS(p), \ + offset = (uint32_t)(GetMatchesSpec1(lenLimit, curMatch, MF_PARAMS(p), \ distances + offset, maxLen) - distances); MOVE_POS_RET;
#define SKIP_FOOTER \ SkipMatchesSpec(lenLimit, curMatch, MF_PARAMS(p)); MOVE_POS;
-static UInt32 Bt2_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +static uint32_t Bt2_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 offset; + uint32_t offset; GET_MATCHES_HEADER(2) HASH2_CALC; curMatch = p->hash[hashValue]; @@ -492,9 +492,9 @@ static UInt32 Bt2_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) GET_MATCHES_FOOTER(offset, 1) }
-UInt32 Bt3Zip_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +uint32_t Bt3Zip_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 offset; + uint32_t offset; GET_MATCHES_HEADER(3) HASH_ZIP_CALC; curMatch = p->hash[hashValue]; @@ -503,9 +503,9 @@ UInt32 Bt3Zip_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) GET_MATCHES_FOOTER(offset, 2) }
-static UInt32 Bt3_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +static uint32_t Bt3_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 hash2Value, delta2, maxLen, offset; + uint32_t hash2Value, delta2, maxLen, offset; GET_MATCHES_HEADER(3)
HASH3_CALC; @@ -536,9 +536,9 @@ static UInt32 Bt3_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) GET_MATCHES_FOOTER(offset, maxLen) }
-static UInt32 Bt4_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +static uint32_t Bt4_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 hash2Value, hash3Value, delta2, delta3, maxLen, offset; + uint32_t hash2Value, hash3Value, delta2, delta3, maxLen, offset; GET_MATCHES_HEADER(4)
HASH4_CALC; @@ -583,9 +583,9 @@ static UInt32 Bt4_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) GET_MATCHES_FOOTER(offset, maxLen) }
-static UInt32 Hc4_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +static uint32_t Hc4_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 hash2Value, hash3Value, delta2, delta3, maxLen, offset; + uint32_t hash2Value, hash3Value, delta2, delta3, maxLen, offset; GET_MATCHES_HEADER(4)
HASH4_CALC; @@ -627,24 +627,24 @@ static UInt32 Hc4_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) } if (maxLen < 3) maxLen = 3; - offset = (UInt32)(Hc_GetMatchesSpec(lenLimit, curMatch, MF_PARAMS(p), + offset = (uint32_t)(Hc_GetMatchesSpec(lenLimit, curMatch, MF_PARAMS(p), distances + offset, maxLen) - (distances)); MOVE_POS_RET }
-UInt32 Hc3Zip_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances) +uint32_t Hc3Zip_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances) { - UInt32 offset; + uint32_t offset; GET_MATCHES_HEADER(3) HASH_ZIP_CALC; curMatch = p->hash[hashValue]; p->hash[hashValue] = p->pos; - offset = (UInt32)(Hc_GetMatchesSpec(lenLimit, curMatch, MF_PARAMS(p), + offset = (uint32_t)(Hc_GetMatchesSpec(lenLimit, curMatch, MF_PARAMS(p), distances, 2) - (distances)); MOVE_POS_RET }
-static void Bt2_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +static void Bt2_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { @@ -657,7 +657,7 @@ static void Bt2_MatchFinder_Skip(CMatchFinder *p, UInt32 num) while (--num != 0); }
-void Bt3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +void Bt3Zip_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { @@ -670,11 +670,11 @@ void Bt3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num) while (--num != 0); }
-static void Bt3_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +static void Bt3_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { - UInt32 hash2Value; + uint32_t hash2Value; SKIP_HEADER(3) HASH3_CALC; curMatch = p->hash[kFix3HashSize + hashValue]; @@ -685,11 +685,11 @@ static void Bt3_MatchFinder_Skip(CMatchFinder *p, UInt32 num) while (--num != 0); }
-static void Bt4_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +static void Bt4_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { - UInt32 hash2Value, hash3Value; + uint32_t hash2Value, hash3Value; SKIP_HEADER(4) HASH4_CALC; curMatch = p->hash[kFix4HashSize + hashValue]; @@ -701,11 +701,11 @@ static void Bt4_MatchFinder_Skip(CMatchFinder *p, UInt32 num) while (--num != 0); }
-static void Hc4_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +static void Hc4_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { - UInt32 hash2Value, hash3Value; + uint32_t hash2Value, hash3Value; SKIP_HEADER(4) HASH4_CALC; curMatch = p->hash[kFix4HashSize + hashValue]; @@ -718,7 +718,7 @@ static void Hc4_MatchFinder_Skip(CMatchFinder *p, UInt32 num) while (--num != 0); }
-void Hc3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num) +void Hc3Zip_MatchFinder_Skip(CMatchFinder *p, uint32_t num) { do { @@ -735,8 +735,8 @@ void Hc3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num) void MatchFinder_CreateVTable(CMatchFinder *p, IMatchFinder *vTable) { vTable->Init = (Mf_Init_Func)MatchFinder_Init; - vTable->GetIndexByte = (Mf_GetIndexByte_Func)MatchFinder_GetIndexByte; - vTable->GetNumAvailableBytes = (Mf_GetNumAvailableBytes_Func)MatchFinder_GetNumAvailableBytes; + vTable->GetIndexuint8_t = (Mf_GetIndexByte_Func)MatchFinder_GetIndexuint8_t; + vTable->GetNumAvailableuint8_ts = (Mf_GetNumAvailableBytes_Func)MatchFinder_GetNumAvailableuint8_ts; vTable->GetPointerToCurrentPos = (Mf_GetPointerToCurrentPos_Func)MatchFinder_GetPointerToCurrentPos; if (!p->btMode) { diff --git a/util/cbfstool/lzma/C/LzFind.h b/util/cbfstool/lzma/C/LzFind.h index 010c4b9..11be938 100644 --- a/util/cbfstool/lzma/C/LzFind.h +++ b/util/cbfstool/lzma/C/LzFind.h @@ -10,53 +10,53 @@ extern "C" { #endif
-typedef UInt32 CLzRef; +typedef uint32_t CLzRef;
typedef struct _CMatchFinder { - Byte *buffer; - UInt32 pos; - UInt32 posLimit; - UInt32 streamPos; - UInt32 lenLimit; + uint8_t *buffer; + uint32_t pos; + uint32_t posLimit; + uint32_t streamPos; + uint32_t lenLimit;
- UInt32 cyclicBufferPos; - UInt32 cyclicBufferSize; /* it must be = (historySize + 1) */ + uint32_t cyclicBufferPos; + uint32_t cyclicBufferSize; /* it must be = (historySize + 1) */
- UInt32 matchMaxLen; + uint32_t matchMaxLen; CLzRef *hash; CLzRef *son; - UInt32 hashMask; - UInt32 cutValue; + uint32_t hashMask; + uint32_t cutValue;
- Byte *bufferBase; + uint8_t *bufferBase; ISeqInStream *stream; int streamEndWasReached;
- UInt32 blockSize; - UInt32 keepSizeBefore; - UInt32 keepSizeAfter; + uint32_t blockSize; + uint32_t keepSizeBefore; + uint32_t keepSizeAfter;
- UInt32 numHashBytes; + uint32_t numHashBytes; int directInput; size_t directInputRem; int btMode; int bigHash; - UInt32 historySize; - UInt32 fixedHashSize; - UInt32 hashSizeSum; - UInt32 numSons; + uint32_t historySize; + uint32_t fixedHashSize; + uint32_t hashSizeSum; + uint32_t numSons; SRes result; - UInt32 crc[256]; + uint32_t crc[256]; } CMatchFinder;
#define Inline_MatchFinder_GetPointerToCurrentPos(p) ((p)->buffer) -#define Inline_MatchFinder_GetIndexByte(p, index) ((p)->buffer[(Int32)(index)]) +#define Inline_MatchFinder_GetIndexuint8_t(p, index) ((p)->buffer[(int32_t)(index)])
-#define Inline_MatchFinder_GetNumAvailableBytes(p) ((p)->streamPos - (p)->pos) +#define Inline_MatchFinder_GetNumAvailableuint8_ts(p) ((p)->streamPos - (p)->pos)
int MatchFinder_NeedMove(CMatchFinder *p); -Byte *MatchFinder_GetPointerToCurrentPos(CMatchFinder *p); +uint8_t *MatchFinder_GetPointerToCurrentPos(CMatchFinder *p); void MatchFinder_MoveBlock(CMatchFinder *p); void MatchFinder_ReadIfRequired(CMatchFinder *p);
@@ -66,16 +66,16 @@ void MatchFinder_Construct(CMatchFinder *p); historySize <= 3 GB keepAddBufferBefore + matchMaxLen + keepAddBufferAfter < 511MB */ -int MatchFinder_Create(CMatchFinder *p, UInt32 historySize, - UInt32 keepAddBufferBefore, UInt32 matchMaxLen, UInt32 keepAddBufferAfter, +int MatchFinder_Create(CMatchFinder *p, uint32_t historySize, + uint32_t keepAddBufferBefore, uint32_t matchMaxLen, uint32_t keepAddBufferAfter, ISzAlloc *alloc); void MatchFinder_Free(CMatchFinder *p, ISzAlloc *alloc); -void MatchFinder_Normalize3(UInt32 subValue, CLzRef *items, UInt32 numItems); -void MatchFinder_ReduceOffsets(CMatchFinder *p, UInt32 subValue); +void MatchFinder_Normalize3(uint32_t subValue, CLzRef *items, uint32_t numItems); +void MatchFinder_ReduceOffsets(CMatchFinder *p, uint32_t subValue);
-UInt32 * GetMatchesSpec1(UInt32 lenLimit, UInt32 curMatch, UInt32 pos, const Byte *buffer, CLzRef *son, - UInt32 _cyclicBufferPos, UInt32 _cyclicBufferSize, UInt32 _cutValue, - UInt32 *distances, UInt32 maxLen); +uint32_t * GetMatchesSpec1(uint32_t lenLimit, uint32_t curMatch, uint32_t pos, const uint8_t *buffer, CLzRef *son, + uint32_t _cyclicBufferPos, uint32_t _cyclicBufferSize, uint32_t _cutValue, + uint32_t *distances, uint32_t maxLen);
/* Conditions: @@ -84,17 +84,17 @@ Conditions: */
typedef void (*Mf_Init_Func)(void *object); -typedef Byte (*Mf_GetIndexByte_Func)(void *object, Int32 index); -typedef UInt32 (*Mf_GetNumAvailableBytes_Func)(void *object); -typedef const Byte * (*Mf_GetPointerToCurrentPos_Func)(void *object); -typedef UInt32 (*Mf_GetMatches_Func)(void *object, UInt32 *distances); -typedef void (*Mf_Skip_Func)(void *object, UInt32); +typedef uint8_t (*Mf_GetIndexByte_Func)(void *object, int32_t index); +typedef uint32_t (*Mf_GetNumAvailableBytes_Func)(void *object); +typedef const uint8_t * (*Mf_GetPointerToCurrentPos_Func)(void *object); +typedef uint32_t (*Mf_GetMatches_Func)(void *object, uint32_t *distances); +typedef void (*Mf_Skip_Func)(void *object, uint32_t);
typedef struct _IMatchFinder { Mf_Init_Func Init; - Mf_GetIndexByte_Func GetIndexByte; - Mf_GetNumAvailableBytes_Func GetNumAvailableBytes; + Mf_GetIndexByte_Func GetIndexuint8_t; + Mf_GetNumAvailableBytes_Func GetNumAvailableuint8_ts; Mf_GetPointerToCurrentPos_Func GetPointerToCurrentPos; Mf_GetMatches_Func GetMatches; Mf_Skip_Func Skip; @@ -103,10 +103,10 @@ typedef struct _IMatchFinder void MatchFinder_CreateVTable(CMatchFinder *p, IMatchFinder *vTable);
void MatchFinder_Init(CMatchFinder *p); -UInt32 Bt3Zip_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances); -UInt32 Hc3Zip_MatchFinder_GetMatches(CMatchFinder *p, UInt32 *distances); -void Bt3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num); -void Hc3Zip_MatchFinder_Skip(CMatchFinder *p, UInt32 num); +uint32_t Bt3Zip_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances); +uint32_t Hc3Zip_MatchFinder_GetMatches(CMatchFinder *p, uint32_t *distances); +void Bt3Zip_MatchFinder_Skip(CMatchFinder *p, uint32_t num); +void Hc3Zip_MatchFinder_Skip(CMatchFinder *p, uint32_t num);
#ifdef __cplusplus } diff --git a/util/cbfstool/lzma/C/LzHash.h b/util/cbfstool/lzma/C/LzHash.h index f3e8996..cc01a3f 100644 --- a/util/cbfstool/lzma/C/LzHash.h +++ b/util/cbfstool/lzma/C/LzHash.h @@ -12,43 +12,43 @@ #define kFix4HashSize (kHash2Size + kHash3Size) #define kFix5HashSize (kHash2Size + kHash3Size + kHash4Size)
-#define HASH2_CALC hashValue = cur[0] | ((UInt32)cur[1] << 8); +#define HASH2_CALC hashValue = cur[0] | ((uint32_t)cur[1] << 8);
#define HASH3_CALC { \ - UInt32 temp = p->crc[cur[0]] ^ cur[1]; \ + uint32_t temp = p->crc[cur[0]] ^ cur[1]; \ hash2Value = temp & (kHash2Size - 1); \ - hashValue = (temp ^ ((UInt32)cur[2] << 8)) & p->hashMask; } + hashValue = (temp ^ ((uint32_t)cur[2] << 8)) & p->hashMask; }
#define HASH4_CALC { \ - UInt32 temp = p->crc[cur[0]] ^ cur[1]; \ + uint32_t temp = p->crc[cur[0]] ^ cur[1]; \ hash2Value = temp & (kHash2Size - 1); \ - hash3Value = (temp ^ ((UInt32)cur[2] << 8)) & (kHash3Size - 1); \ - hashValue = (temp ^ ((UInt32)cur[2] << 8) ^ (p->crc[cur[3]] << 5)) & p->hashMask; } + hash3Value = (temp ^ ((uint32_t)cur[2] << 8)) & (kHash3Size - 1); \ + hashValue = (temp ^ ((uint32_t)cur[2] << 8) ^ (p->crc[cur[3]] << 5)) & p->hashMask; }
#define HASH5_CALC { \ - UInt32 temp = p->crc[cur[0]] ^ cur[1]; \ + uint32_t temp = p->crc[cur[0]] ^ cur[1]; \ hash2Value = temp & (kHash2Size - 1); \ - hash3Value = (temp ^ ((UInt32)cur[2] << 8)) & (kHash3Size - 1); \ - hash4Value = (temp ^ ((UInt32)cur[2] << 8) ^ (p->crc[cur[3]] << 5)); \ + hash3Value = (temp ^ ((uint32_t)cur[2] << 8)) & (kHash3Size - 1); \ + hash4Value = (temp ^ ((uint32_t)cur[2] << 8) ^ (p->crc[cur[3]] << 5)); \ hashValue = (hash4Value ^ (p->crc[cur[4]] << 3)) & p->hashMask; \ hash4Value &= (kHash4Size - 1); }
-/* #define HASH_ZIP_CALC hashValue = ((cur[0] | ((UInt32)cur[1] << 8)) ^ p->crc[cur[2]]) & 0xFFFF; */ -#define HASH_ZIP_CALC hashValue = ((cur[2] | ((UInt32)cur[0] << 8)) ^ p->crc[cur[1]]) & 0xFFFF; +/* #define HASH_ZIP_CALC hashValue = ((cur[0] | ((uint32_t)cur[1] << 8)) ^ p->crc[cur[2]]) & 0xFFFF; */ +#define HASH_ZIP_CALC hashValue = ((cur[2] | ((uint32_t)cur[0] << 8)) ^ p->crc[cur[1]]) & 0xFFFF;
#define MT_HASH2_CALC \ hash2Value = (p->crc[cur[0]] ^ cur[1]) & (kHash2Size - 1);
#define MT_HASH3_CALC { \ - UInt32 temp = p->crc[cur[0]] ^ cur[1]; \ + uint32_t temp = p->crc[cur[0]] ^ cur[1]; \ hash2Value = temp & (kHash2Size - 1); \ - hash3Value = (temp ^ ((UInt32)cur[2] << 8)) & (kHash3Size - 1); } + hash3Value = (temp ^ ((uint32_t)cur[2] << 8)) & (kHash3Size - 1); }
#define MT_HASH4_CALC { \ - UInt32 temp = p->crc[cur[0]] ^ cur[1]; \ + uint32_t temp = p->crc[cur[0]] ^ cur[1]; \ hash2Value = temp & (kHash2Size - 1); \ - hash3Value = (temp ^ ((UInt32)cur[2] << 8)) & (kHash3Size - 1); \ - hash4Value = (temp ^ ((UInt32)cur[2] << 8) ^ (p->crc[cur[3]] << 5)) & (kHash4Size - 1); } + hash3Value = (temp ^ ((uint32_t)cur[2] << 8)) & (kHash3Size - 1); \ + hash4Value = (temp ^ ((uint32_t)cur[2] << 8) ^ (p->crc[cur[3]] << 5)) & (kHash4Size - 1); }
#endif diff --git a/util/cbfstool/lzma/C/LzmaDec.c b/util/cbfstool/lzma/C/LzmaDec.c index fd88cec..7ba32b9 100644 --- a/util/cbfstool/lzma/C/LzmaDec.c +++ b/util/cbfstool/lzma/C/LzmaDec.c @@ -6,7 +6,7 @@ #include <string.h>
#define kNumTopBits 24 -#define kTopValue ((UInt32)1 << kNumTopBits) +#define kTopValue ((uint32_t)1 << kNumTopBits)
#define kNumBitModelTotalBits 11 #define kBitModelTotal (1 << kNumBitModelTotalBits) @@ -107,7 +107,7 @@ #define LZMA_BASE_SIZE 1846 #define LZMA_LIT_SIZE 768
-#define LzmaProps_GetNumProbs(p) ((UInt32)LZMA_BASE_SIZE + (LZMA_LIT_SIZE << ((p)->lc + (p)->lp))) +#define LzmaProps_GetNumProbs(p) ((uint32_t)LZMA_BASE_SIZE + (LZMA_LIT_SIZE << ((p)->lc + (p)->lp)))
#if Literal != LZMA_BASE_SIZE StopCompilingDueBUG @@ -128,32 +128,32 @@ Out: = kMatchSpecLenStart + 2 : State Init Marker */
-static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const Byte *bufLimit) +static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, size_t limit_parm, const uint8_t *bufLimit) { CLzmaProb *probs = p->probs;
unsigned state = p->state; - UInt32 rep0 = p->reps[0], rep1 = p->reps[1], rep2 = p->reps[2], rep3 = p->reps[3]; + uint32_t rep0 = p->reps[0], rep1 = p->reps[1], rep2 = p->reps[2], rep3 = p->reps[3]; unsigned pbMask = ((unsigned)1 << (p->prop.pb)) - 1; unsigned lpMask = ((unsigned)1 << (p->prop.lp)) - 1; unsigned lc = p->prop.lc;
- Byte *dic = p->dic; - SizeT dicBufSize = p->dicBufSize; - SizeT dicPos = p->dicPos; + uint8_t *dic = p->dic; + size_t dicBufSize = p->dicBufSize; + size_t dicPos = p->dicPos;
- UInt32 processedPos = p->processedPos; - UInt32 checkDicSize = p->checkDicSize; + uint32_t processedPos = p->processedPos; + uint32_t checkDicSize = p->checkDicSize; unsigned len = 0;
- const Byte *buf = p->buf; - UInt32 range = p->range; - UInt32 code = p->code; + const uint8_t *buf = p->buf; + uint32_t range = p->range; + uint32_t code = p->code;
do { CLzmaProb *prob; - UInt32 bound; + uint32_t bound; unsigned ttt; unsigned posState = processedPos & pbMask;
@@ -175,7 +175,7 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const } else { - unsigned matchByte = p->dic[(dicPos - rep0) + ((dicPos < rep0) ? dicBufSize : 0)]; + unsigned matchuint8_t = p->dic[(dicPos - rep0) + ((dicPos < rep0) ? dicBufSize : 0)]; unsigned offs = 0x100; state -= (state < 10) ? 3 : 6; symbol = 1; @@ -183,14 +183,14 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const { unsigned bit; CLzmaProb *probLit; - matchByte <<= 1; - bit = (matchByte & offs); + matchuint8_t <<= 1; + bit = (matchuint8_t & offs); probLit = prob + offs + bit + symbol; GET_BIT2(probLit, symbol, offs &= ~bit, offs &= bit) } while (symbol < 0x100); } - dic[dicPos++] = (Byte)symbol; + dic[dicPos++] = (uint8_t)symbol; processedPos++; continue; } @@ -227,7 +227,7 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const } else { - UInt32 distance; + uint32_t distance; UPDATE_1(prob); prob = probs + IsRepG1 + state; IF_BIT_0(prob) @@ -293,7 +293,7 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const
if (state >= kNumStates) { - UInt32 distance; + uint32_t distance; prob = probs + PosSlot + ((len < kNumLenToPosStates ? len : kNumLenToPosStates - 1) << kNumPosSlotBits); TREE_6_DECODE(prob, distance); @@ -307,7 +307,7 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const distance <<= numDirectBits; prob = probs + SpecPos + distance - posSlot - 1; { - UInt32 mask = 1; + uint32_t mask = 1; unsigned i = 1; do { @@ -326,9 +326,9 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const range >>= 1;
{ - UInt32 t; + uint32_t t; code -= range; - t = (0 - ((UInt32)code >> 31)); /* (UInt32)((Int32)code >> 31) */ + t = (0 - ((uint32_t)code >> 31)); /* (uint32_t)((int32_t)code >> 31) */ distance = (distance << 1) + (t + 1); code += range & t; } @@ -351,7 +351,7 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const GET_BIT2(prob + i, i, ; , distance |= 4); GET_BIT2(prob + i, i, ; , distance |= 8); } - if (distance == (UInt32)0xFFFFFFFF) + if (distance == (uint32_t)0xFFFFFFFF) { len += kMatchSpecLenStart; state -= kNumStates; @@ -378,21 +378,21 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const if (limit_parm == dicPos) return SZ_ERROR_DATA; { - SizeT rem = limit_parm - dicPos; + size_t rem = limit_parm - dicPos; unsigned curLen = ((rem < len) ? (unsigned)rem : len); - SizeT pos = (dicPos - rep0) + ((dicPos < rep0) ? dicBufSize : 0); + size_t pos = (dicPos - rep0) + ((dicPos < rep0) ? dicBufSize : 0);
processedPos += curLen;
len -= curLen; if (pos + curLen <= dicBufSize) { - Byte *dest = dic + dicPos; + uint8_t *dest = dic + dicPos; ptrdiff_t src = (ptrdiff_t)pos - (ptrdiff_t)dicPos; - const Byte *lim = dest + curLen; + const uint8_t *lim = dest + curLen; dicPos += curLen; do - *(dest) = (Byte)*(dest + src); + *(dest) = (uint8_t)*(dest + src); while (++dest != lim); } else @@ -425,15 +425,15 @@ static int MY_FAST_CALL LzmaDec_DecodeReal(CLzmaDec *p, SizeT limit_parm, const return SZ_OK; }
-static void MY_FAST_CALL LzmaDec_WriteRem(CLzmaDec *p, SizeT limit) +static void MY_FAST_CALL LzmaDec_WriteRem(CLzmaDec *p, size_t limit) { if (p->remainLen != 0 && p->remainLen < kMatchSpecLenStart) { - Byte *dic = p->dic; - SizeT dicPos = p->dicPos; - SizeT dicBufSize = p->dicBufSize; + uint8_t *dic = p->dic; + size_t dicPos = p->dicPos; + size_t dicBufSize = p->dicBufSize; unsigned len = p->remainLen; - UInt32 rep0 = p->reps[0]; + uint32_t rep0 = p->reps[0]; if (limit - dicPos < len) len = (unsigned)(limit - dicPos);
@@ -451,14 +451,14 @@ static void MY_FAST_CALL LzmaDec_WriteRem(CLzmaDec *p, SizeT limit) } }
-static int MY_FAST_CALL LzmaDec_DecodeReal2(CLzmaDec *p, SizeT limit, const Byte *bufLimit) +static int MY_FAST_CALL LzmaDec_DecodeReal2(CLzmaDec *p, size_t limit, const uint8_t *bufLimit) { do { - SizeT limit2 = limit; + size_t limit2 = limit; if (p->checkDicSize == 0) { - UInt32 rem = p->prop.dicSize - p->processedPos; + uint32_t rem = p->prop.dicSize - p->processedPos; if (limit - p->dicPos > rem) limit2 = p->dicPos + rem; } @@ -484,18 +484,18 @@ typedef enum DUMMY_REP } ELzmaDummy;
-static ELzmaDummy LzmaDec_TryDummy(const CLzmaDec *p, const Byte *buf, SizeT inSize) +static ELzmaDummy LzmaDec_TryDummy(const CLzmaDec *p, const uint8_t *buf, size_t inSize) { - UInt32 range = p->range; - UInt32 code = p->code; - const Byte *bufLimit = buf + inSize; + uint32_t range = p->range; + uint32_t code = p->code; + const uint8_t *bufLimit = buf + inSize; CLzmaProb *probs = p->probs; unsigned state = p->state; ELzmaDummy res;
{ CLzmaProb *prob; - UInt32 bound; + uint32_t bound; unsigned ttt; unsigned posState = (p->processedPos) & ((1 << p->prop.pb) - 1);
@@ -519,7 +519,7 @@ static ELzmaDummy LzmaDec_TryDummy(const CLzmaDec *p, const Byte *buf, SizeT inS } else { - unsigned matchByte = p->dic[p->dicPos - p->reps[0] + + unsigned matchuint8_t = p->dic[p->dicPos - p->reps[0] + ((p->dicPos < p->reps[0]) ? p->dicBufSize : 0)]; unsigned offs = 0x100; unsigned symbol = 1; @@ -527,8 +527,8 @@ static ELzmaDummy LzmaDec_TryDummy(const CLzmaDec *p, const Byte *buf, SizeT inS { unsigned bit; CLzmaProb *probLit; - matchByte <<= 1; - bit = (matchByte & offs); + matchuint8_t <<= 1; + bit = (matchuint8_t & offs); probLit = prob + offs + bit + symbol; GET_BIT2_CHECK(probLit, symbol, offs &= ~bit, offs &= bit) } @@ -675,14 +675,14 @@ static ELzmaDummy LzmaDec_TryDummy(const CLzmaDec *p, const Byte *buf, SizeT inS }
-static void LzmaDec_InitRc(CLzmaDec *p, const Byte *data) +static void LzmaDec_InitRc(CLzmaDec *p, const uint8_t *data) { - p->code = ((UInt32)data[1] << 24) | ((UInt32)data[2] << 16) | ((UInt32)data[3] << 8) | ((UInt32)data[4]); + p->code = ((uint32_t)data[1] << 24) | ((uint32_t)data[2] << 16) | ((uint32_t)data[3] << 8) | ((uint32_t)data[4]); p->range = 0xFFFFFFFF; p->needFlush = 0; }
-static void LzmaDec_InitDicAndState(CLzmaDec *p, Bool initDic, Bool initState) +static void LzmaDec_InitDicAndState(CLzmaDec *p, bool initDic, bool initState) { p->needFlush = 1; p->remainLen = 0; @@ -701,13 +701,13 @@ static void LzmaDec_InitDicAndState(CLzmaDec *p, Bool initDic, Bool initState) void LzmaDec_Init(CLzmaDec *p) { p->dicPos = 0; - LzmaDec_InitDicAndState(p, True, True); + LzmaDec_InitDicAndState(p, true, true); }
static void LzmaDec_InitStateReal(CLzmaDec *p) { - UInt32 numProbs = Literal + ((UInt32)LZMA_LIT_SIZE << (p->prop.lc + p->prop.lp)); - UInt32 i; + uint32_t numProbs = Literal + ((uint32_t)LZMA_LIT_SIZE << (p->prop.lc + p->prop.lp)); + uint32_t i; CLzmaProb *probs = p->probs; for (i = 0; i < numProbs; i++) probs[i] = kBitModelTotal >> 1; @@ -716,10 +716,10 @@ static void LzmaDec_InitStateReal(CLzmaDec *p) p->needInitState = 0; }
-SRes LzmaDec_DecodeToDic(CLzmaDec *p, SizeT dicLimit, const Byte *src, SizeT *srcLen, +SRes LzmaDec_DecodeToDic(CLzmaDec *p, size_t dicLimit, const uint8_t *src, size_t *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status) { - SizeT inSize = *srcLen; + size_t inSize = *srcLen; (*srcLen) = 0; LzmaDec_WriteRem(p, dicLimit);
@@ -771,8 +771,8 @@ SRes LzmaDec_DecodeToDic(CLzmaDec *p, SizeT dicLimit, const Byte *src, SizeT *sr
if (p->tempBufSize == 0) { - SizeT processed; - const Byte *bufLimit; + size_t processed; + const uint8_t *bufLimit; if (inSize < LZMA_REQUIRED_INPUT_MAX || checkEndMarkNow) { int dummyRes = LzmaDec_TryDummy(p, src, inSize); @@ -796,7 +796,7 @@ SRes LzmaDec_DecodeToDic(CLzmaDec *p, SizeT dicLimit, const Byte *src, SizeT *sr p->buf = src; if (LzmaDec_DecodeReal2(p, dicLimit, bufLimit) != 0) return SZ_ERROR_DATA; - processed = (SizeT)(p->buf - src); + processed = (size_t)(p->buf - src); (*srcLen) += processed; src += processed; inSize -= processed; @@ -837,14 +837,14 @@ SRes LzmaDec_DecodeToDic(CLzmaDec *p, SizeT dicLimit, const Byte *src, SizeT *sr return (p->code == 0) ? SZ_OK : SZ_ERROR_DATA; }
-SRes LzmaDec_DecodeToBuf(CLzmaDec *p, Byte *dest, SizeT *destLen, const Byte *src, SizeT *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status) +SRes LzmaDec_DecodeToBuf(CLzmaDec *p, uint8_t *dest, size_t *destLen, const uint8_t *src, size_t *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status) { - SizeT outSize = *destLen; - SizeT inSize = *srcLen; + size_t outSize = *destLen; + size_t inSize = *srcLen; *srcLen = *destLen = 0; for (;;) { - SizeT inSizeCur = inSize, outSizeCur, dicPos; + size_t inSizeCur = inSize, outSizeCur, dicPos; ELzmaFinishMode curFinishMode; SRes res; if (p->dicPos == p->dicBufSize) @@ -895,15 +895,15 @@ void LzmaDec_Free(CLzmaDec *p, ISzAlloc *alloc) LzmaDec_FreeDict(p, alloc); }
-SRes LzmaProps_Decode(CLzmaProps *p, const Byte *data, unsigned size) +SRes LzmaProps_Decode(CLzmaProps *p, const uint8_t *data, unsigned size) { - UInt32 dicSize; - Byte d; + uint32_t dicSize; + uint8_t d;
if (size < LZMA_PROPS_SIZE) return SZ_ERROR_UNSUPPORTED; else - dicSize = data[1] | ((UInt32)data[2] << 8) | ((UInt32)data[3] << 16) | ((UInt32)data[4] << 24); + dicSize = data[1] | ((uint32_t)data[2] << 8) | ((uint32_t)data[3] << 16) | ((uint32_t)data[4] << 24);
if (dicSize < LZMA_DIC_MIN) dicSize = LZMA_DIC_MIN; @@ -923,7 +923,7 @@ SRes LzmaProps_Decode(CLzmaProps *p, const Byte *data, unsigned size)
static SRes LzmaDec_AllocateProbs2(CLzmaDec *p, const CLzmaProps *propNew, ISzAlloc *alloc) { - UInt32 numProbs = LzmaProps_GetNumProbs(propNew); + uint32_t numProbs = LzmaProps_GetNumProbs(propNew); if (p->probs == 0 || numProbs != p->numProbs) { LzmaDec_FreeProbs(p, alloc); @@ -935,7 +935,7 @@ static SRes LzmaDec_AllocateProbs2(CLzmaDec *p, const CLzmaProps *propNew, ISzAl return SZ_OK; }
-SRes LzmaDec_AllocateProbs(CLzmaDec *p, const Byte *props, unsigned propsSize, ISzAlloc *alloc) +SRes LzmaDec_AllocateProbs(CLzmaDec *p, const uint8_t *props, unsigned propsSize, ISzAlloc *alloc) { CLzmaProps propNew; RINOK(LzmaProps_Decode(&propNew, props, propsSize)); @@ -944,17 +944,17 @@ SRes LzmaDec_AllocateProbs(CLzmaDec *p, const Byte *props, unsigned propsSize, I return SZ_OK; }
-SRes LzmaDec_Allocate(CLzmaDec *p, const Byte *props, unsigned propsSize, ISzAlloc *alloc) +SRes LzmaDec_Allocate(CLzmaDec *p, const uint8_t *props, unsigned propsSize, ISzAlloc *alloc) { CLzmaProps propNew; - SizeT dicBufSize; + size_t dicBufSize; RINOK(LzmaProps_Decode(&propNew, props, propsSize)); RINOK(LzmaDec_AllocateProbs2(p, &propNew, alloc)); dicBufSize = propNew.dicSize; if (p->dic == 0 || dicBufSize != p->dicBufSize) { LzmaDec_FreeDict(p, alloc); - p->dic = (Byte *)alloc->Alloc(alloc, dicBufSize); + p->dic = (uint8_t *)alloc->Alloc(alloc, dicBufSize); if (p->dic == 0) { LzmaDec_FreeProbs(p, alloc); @@ -966,14 +966,14 @@ SRes LzmaDec_Allocate(CLzmaDec *p, const Byte *props, unsigned propsSize, ISzAll return SZ_OK; }
-SRes LzmaDecode(Byte *dest, SizeT *destLen, const Byte *src, SizeT *srcLen, - const Byte *propData, unsigned propSize, ELzmaFinishMode finishMode, +SRes LzmaDecode(uint8_t *dest, size_t *destLen, const uint8_t *src, size_t *srcLen, + const uint8_t *propData, unsigned propSize, ELzmaFinishMode finishMode, ELzmaStatus *status, ISzAlloc *alloc) { CLzmaDec p; SRes res; - SizeT inSize = *srcLen; - SizeT outSize = *destLen; + size_t inSize = *srcLen; + size_t outSize = *destLen; *srcLen = *destLen = 0; if (inSize < RC_INIT_SIZE) return SZ_ERROR_INPUT_EOF; diff --git a/util/cbfstool/lzma/C/LzmaDec.h b/util/cbfstool/lzma/C/LzmaDec.h index 7927acd..3d06b58 100644 --- a/util/cbfstool/lzma/C/LzmaDec.h +++ b/util/cbfstool/lzma/C/LzmaDec.h @@ -15,9 +15,9 @@ extern "C" { but memory usage for CLzmaDec::probs will be doubled in that case */
#ifdef _LZMA_PROB32 -#define CLzmaProb UInt32 +#define CLzmaProb uint32_t #else -#define CLzmaProb UInt16 +#define CLzmaProb uint16_t #endif
@@ -28,7 +28,7 @@ extern "C" { typedef struct _CLzmaProps { unsigned lc, lp, pb; - UInt32 dicSize; + uint32_t dicSize; } CLzmaProps;
/* LzmaProps_Decode - decodes properties @@ -37,7 +37,7 @@ Returns: SZ_ERROR_UNSUPPORTED - Unsupported properties */
-SRes LzmaProps_Decode(CLzmaProps *p, const Byte *data, unsigned size); +SRes LzmaProps_Decode(CLzmaProps *p, const uint8_t *data, unsigned size);
/* ---------- LZMA Decoder state ---------- */ @@ -51,21 +51,21 @@ typedef struct { CLzmaProps prop; CLzmaProb *probs; - Byte *dic; - const Byte *buf; - UInt32 range, code; - SizeT dicPos; - SizeT dicBufSize; - UInt32 processedPos; - UInt32 checkDicSize; + uint8_t *dic; + const uint8_t *buf; + uint32_t range, code; + size_t dicPos; + size_t dicBufSize; + uint32_t processedPos; + uint32_t checkDicSize; unsigned state; - UInt32 reps[4]; + uint32_t reps[4]; unsigned remainLen; int needFlush; int needInitState; - UInt32 numProbs; + uint32_t numProbs; unsigned tempBufSize; - Byte tempBuf[LZMA_REQUIRED_INPUT_MAX]; + uint8_t tempBuf[LZMA_REQUIRED_INPUT_MAX]; } CLzmaDec;
#define LzmaDec_Construct(p) { (p)->dic = 0; (p)->probs = 0; } @@ -131,10 +131,10 @@ LzmaDec_Allocate* can return: SZ_ERROR_UNSUPPORTED - Unsupported properties */
-SRes LzmaDec_AllocateProbs(CLzmaDec *p, const Byte *props, unsigned propsSize, ISzAlloc *alloc); +SRes LzmaDec_AllocateProbs(CLzmaDec *p, const uint8_t *props, unsigned propsSize, ISzAlloc *alloc); void LzmaDec_FreeProbs(CLzmaDec *p, ISzAlloc *alloc);
-SRes LzmaDec_Allocate(CLzmaDec *state, const Byte *prop, unsigned propsSize, ISzAlloc *alloc); +SRes LzmaDec_Allocate(CLzmaDec *state, const uint8_t *prop, unsigned propsSize, ISzAlloc *alloc); void LzmaDec_Free(CLzmaDec *state, ISzAlloc *alloc);
/* ---------- Dictionary Interface ---------- */ @@ -178,8 +178,8 @@ Returns: SZ_ERROR_DATA - Data error */
-SRes LzmaDec_DecodeToDic(CLzmaDec *p, SizeT dicLimit, - const Byte *src, SizeT *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status); +SRes LzmaDec_DecodeToDic(CLzmaDec *p, size_t dicLimit, + const uint8_t *src, size_t *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status);
/* ---------- Buffer Interface ---------- */ @@ -195,8 +195,8 @@ finishMode: LZMA_FINISH_END - Stream must be finished after (*destLen). */
-SRes LzmaDec_DecodeToBuf(CLzmaDec *p, Byte *dest, SizeT *destLen, - const Byte *src, SizeT *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status); +SRes LzmaDec_DecodeToBuf(CLzmaDec *p, uint8_t *dest, size_t *destLen, + const uint8_t *src, size_t *srcLen, ELzmaFinishMode finishMode, ELzmaStatus *status);
/* ---------- One Call Interface ---------- */ @@ -220,8 +220,8 @@ Returns: SZ_ERROR_INPUT_EOF - It needs more bytes in input buffer (src). */
-SRes LzmaDecode(Byte *dest, SizeT *destLen, const Byte *src, SizeT *srcLen, - const Byte *propData, unsigned propSize, ELzmaFinishMode finishMode, +SRes LzmaDecode(uint8_t *dest, size_t *destLen, const uint8_t *src, size_t *srcLen, + const uint8_t *propData, unsigned propSize, ELzmaFinishMode finishMode, ELzmaStatus *status, ISzAlloc *alloc);
#ifdef __cplusplus diff --git a/util/cbfstool/lzma/C/LzmaEnc.c b/util/cbfstool/lzma/C/LzmaEnc.c index a9a6813..9ac5362 100644 --- a/util/cbfstool/lzma/C/LzmaEnc.c +++ b/util/cbfstool/lzma/C/LzmaEnc.c @@ -31,7 +31,7 @@ static int ttt = 0; #define kNumMaxDirectBits (31)
#define kNumBitModelTotalBits 11 #define kBitModelTotal (1 << kNumBitModelTotalBits) @@ -73,7 +73,7 @@ void LzmaEncProps_Normalize(CLzmaEncProps *p) #endif }
-UInt32 LzmaEncProps_GetDictSize(const CLzmaEncProps *props2) +uint32_t LzmaEncProps_GetDictSize(const CLzmaEncProps *props2) { CLzmaEncProps props = *props2; LzmaEncProps_Normalize(&props); @@ -90,9 +90,9 @@ UInt32 LzmaEncProps_GetDictSize(const CLzmaEncProps *props2)
#define BSR2_RET(pos, res) { unsigned long i; _BitScanReverse(&i, (pos)); res = (i + i) + ((pos >> (i - 1)) & 1); }
-UInt32 GetPosSlot1(UInt32 pos) +uint32_t GetPosSlot1(uint32_t pos) { - UInt32 res; + uint32_t res; BSR2_RET(pos, res); return res; } @@ -104,7 +104,7 @@ UInt32 GetPosSlot1(UInt32 pos) #define kNumLogBits (9 + (int)sizeof(size_t) / 2) #define kDicLogSizeMaxCompress ((kNumLogBits - 1) * 2 + 7)
-static void LzmaEnc_FastPosInit(Byte *g_FastPos) +static void LzmaEnc_FastPosInit(uint8_t *g_FastPos) { int c = 2, slotFast; g_FastPos[0] = 0; @@ -112,15 +112,15 @@ static void LzmaEnc_FastPosInit(Byte *g_FastPos)
for (slotFast = 2; slotFast < kNumLogBits * 2; slotFast++) { - UInt32 k = (1 << ((slotFast >> 1) - 1)); - UInt32 j; + uint32_t k = (1 << ((slotFast >> 1) - 1)); + uint32_t j; for (j = 0; j < k; j++, c++) - g_FastPos[c] = (Byte)slotFast; + g_FastPos[c] = (uint8_t)slotFast; } }
-#define BSR2_RET(pos, res) { UInt32 i = 6 + ((kNumLogBits - 1) & \ - (0 - (((((UInt32)1 << (kNumLogBits + 6)) - 1) - pos) >> 31))); \ +#define BSR2_RET(pos, res) { uint32_t i = 6 + ((kNumLogBits - 1) & \ + (0 - (((((uint32_t)1 << (kNumLogBits + 6)) - 1) - pos) >> 31))); \ res = p->g_FastPos[pos >> i] + (i * 2); } /* #define BSR2_RET(pos, res) { res = (pos < (1 << (kNumLogBits + 6))) ? \ @@ -141,18 +141,18 @@ typedef unsigned CState;
typedef struct { - UInt32 price; + uint32_t price;
CState state; int prev1IsChar; int prev2;
- UInt32 posPrev2; - UInt32 backPrev2; + uint32_t posPrev2; + uint32_t backPrev2;
- UInt32 posPrev; - UInt32 backPrev; - UInt32 backs[LZMA_NUM_REPS]; + uint32_t posPrev; + uint32_t backPrev; + uint32_t backs[LZMA_NUM_REPS]; } COptimal;
#define kNumOpts (1 << 12) @@ -175,9 +175,9 @@ typedef struct #define kNumFullDistances (1 << (kEndPosModelIndex >> 1))
#define LZMA_PB_MAX 4 @@ -213,22 +213,22 @@ typedef struct typedef struct { CLenEnc p; - UInt32 prices[LZMA_NUM_PB_STATES_MAX][kLenNumSymbolsTotal]; - UInt32 tableSize; - UInt32 counters[LZMA_NUM_PB_STATES_MAX]; + uint32_t prices[LZMA_NUM_PB_STATES_MAX][kLenNumSymbolsTotal]; + uint32_t tableSize; + uint32_t counters[LZMA_NUM_PB_STATES_MAX]; } CLenPriceEnc;
typedef struct { - UInt32 range; - Byte cache; - UInt64 low; - UInt64 cacheSize; - Byte *buf; - Byte *bufLim; - Byte *bufBase; + uint32_t range; + uint8_t cache; + uint64_t low; + uint64_t cacheSize; + uint8_t *buf; + uint8_t *bufLim; + uint8_t *bufBase; ISeqOutStream *outStream; - UInt64 processed; + uint64_t processed; SRes res; } CRangeEnc;
@@ -250,8 +250,8 @@ typedef struct CLenPriceEnc lenEnc; CLenPriceEnc repLenEnc;
- UInt32 reps[LZMA_NUM_REPS]; - UInt32 state; + uint32_t reps[LZMA_NUM_REPS]; + uint32_t state; } CSaveState;
typedef struct @@ -260,41 +260,41 @@ typedef struct void *matchFinderObj;
#ifndef _7ZIP_ST - Bool mtMode; + bool mtMode; CMatchFinderMt matchFinderMt; #endif
CMatchFinder matchFinderBase;
#ifndef _7ZIP_ST - Byte pad[128]; + uint8_t pad[128]; #endif
- UInt32 optimumEndIndex; - UInt32 optimumCurrentIndex; + uint32_t optimumEndIndex; + uint32_t optimumCurrentIndex;
- UInt32 longestMatchLength; - UInt32 numPairs; - UInt32 numAvail; + uint32_t longestMatchLength; + uint32_t numPairs; + uint32_t numAvail; COptimal opt[kNumOpts];
#ifndef LZMA_LOG_BSR - Byte g_FastPos[1 << kNumLogBits]; + uint8_t g_FastPos[1 << kNumLogBits]; #endif
- UInt32 ProbPrices[kBitModelTotal >> kNumMoveReducingBits]; - UInt32 matches[LZMA_MATCH_LEN_MAX * 2 + 2 + 1]; - UInt32 numFastBytes; - UInt32 additionalOffset; - UInt32 reps[LZMA_NUM_REPS]; - UInt32 state; + uint32_t ProbPrices[kBitModelTotal >> kNumMoveReducingBits]; + uint32_t matches[LZMA_MATCH_LEN_MAX * 2 + 2 + 1]; + uint32_t numFastuint8_ts; + uint32_t additionalOffset; + uint32_t reps[LZMA_NUM_REPS]; + uint32_t state;
- UInt32 posSlotPrices[kNumLenToPosStates][kDistTableSizeMax]; - UInt32 distancesPrices[kNumLenToPosStates][kNumFullDistances]; - UInt32 alignPrices[kAlignTableSize]; - UInt32 alignPriceCount; + uint32_t posSlotPrices[kNumLenToPosStates][kDistTableSizeMax]; + uint32_t distancesPrices[kNumLenToPosStates][kNumFullDistances]; + uint32_t alignPrices[kAlignTableSize]; + uint32_t alignPriceCount;
- UInt32 distTableSize; + uint32_t distTableSize;
unsigned lc, lp, pb; unsigned lpMask, pbMask; @@ -317,19 +317,19 @@ typedef struct
unsigned lclp;
- Bool fastMode; + bool fastMode;
CRangeEnc rc;
- Bool writeEndMark; - UInt64 nowPos64; - UInt32 matchPriceCount; - Bool finished; - Bool multiThread; + bool writeEndMark; + uint64_t nowPos64; + uint32_t matchPriceCount; + bool finished; + bool multiThread;
SRes result; - UInt32 dictSize; - UInt32 matchFinderCycles; + uint32_t dictSize; + uint32_t matchFinderCycles;
int needInit;
@@ -405,7 +405,7 @@ SRes LzmaEnc_SetProps(CLzmaEncHandle pp, const CLzmaEncProps *props2) fb = 5; if (fb > LZMA_MATCH_LEN_MAX) fb = LZMA_MATCH_LEN_MAX; - p->numFastBytes = fb; + p->numFastuint8_ts = fb; } p->lc = props.lc; p->lp = props.lp; @@ -413,7 +413,7 @@ SRes LzmaEnc_SetProps(CLzmaEncHandle pp, const CLzmaEncProps *props2) p->fastMode = (props.algo == 0); p->matchFinderBase.btMode = props.btMode; { - UInt32 numHashBytes = 4; + uint32_t numHashBytes = 4; if (props.btMode) { if (props.numHashBytes < 2) @@ -466,7 +466,7 @@ static int RangeEnc_Alloc(CRangeEnc *p, ISzAlloc *alloc) { if (p->bufBase == 0) { - p->bufBase = (Byte *)alloc->Alloc(alloc, RC_BUF_SIZE); + p->bufBase = (uint8_t *)alloc->Alloc(alloc, RC_BUF_SIZE); if (p->bufBase == 0) return 0; p->bufLim = p->bufBase + RC_BUF_SIZE; @@ -508,23 +508,23 @@ static void RangeEnc_FlushStream(CRangeEnc *p)
static void MY_FAST_CALL RangeEnc_ShiftLow(CRangeEnc *p) { - if ((UInt32)p->low < (UInt32)0xFF000000 || (int)(p->low >> 32) != 0) + if ((uint32_t)p->low < (uint32_t)0xFF000000 || (int)(p->low >> 32) != 0) { - Byte temp = p->cache; + uint8_t temp = p->cache; do { - Byte *buf = p->buf; - *buf++ = (Byte)(temp + (Byte)(p->low >> 32)); + uint8_t *buf = p->buf; + *buf++ = (uint8_t)(temp + (uint8_t)(p->low >> 32)); p->buf = buf; if (buf == p->bufLim) RangeEnc_FlushStream(p); temp = 0xFF; } while (--p->cacheSize != 0); - p->cache = (Byte)((UInt32)p->low >> 24); + p->cache = (uint8_t)((uint32_t)p->low >> 24); } p->cacheSize++; - p->low = (UInt32)p->low << 8; + p->low = (uint32_t)p->low << 8; }
static void RangeEnc_FlushData(CRangeEnc *p) @@ -534,7 +534,7 @@ static void RangeEnc_FlushData(CRangeEnc *p) RangeEnc_ShiftLow(p); }
-static void RangeEnc_EncodeDirectBits(CRangeEnc *p, UInt32 value, int numBits) +static void RangeEnc_EncodeDirectBits(CRangeEnc *p, uint32_t value, int numBits) { do { @@ -549,10 +549,10 @@ static void RangeEnc_EncodeDirectBits(CRangeEnc *p, UInt32 value, int numBits) while (numBits != 0); }
-static void RangeEnc_EncodeBit(CRangeEnc *p, CLzmaProb *prob, UInt32 symbol) +static void RangeEnc_EncodeBit(CRangeEnc *p, CLzmaProb *prob, uint32_t symbol) { - UInt32 ttt = *prob; - UInt32 newBound = (p->range >> kNumBitModelTotalBits) * ttt; + uint32_t ttt = *prob; + uint32_t newBound = (p->range >> kNumBitModelTotalBits) * ttt; if (symbol == 0) { p->range = newBound; @@ -572,7 +572,7 @@ static void RangeEnc_EncodeBit(CRangeEnc *p, CLzmaProb *prob, UInt32 symbol) } }
-static void LitEnc_Encode(CRangeEnc *p, CLzmaProb *probs, UInt32 symbol) +static void LitEnc_Encode(CRangeEnc *p, CLzmaProb *probs, uint32_t symbol) { symbol |= 0x100; do @@ -583,34 +583,34 @@ static void LitEnc_Encode(CRangeEnc *p, CLzmaProb *probs, UInt32 symbol) while (symbol < 0x10000); }
-static void LitEnc_EncodeMatched(CRangeEnc *p, CLzmaProb *probs, UInt32 symbol, UInt32 matchByte) +static void LitEnc_EncodeMatched(CRangeEnc *p, CLzmaProb *probs, uint32_t symbol, uint32_t matchuint8_t) { - UInt32 offs = 0x100; + uint32_t offs = 0x100; symbol |= 0x100; do { - matchByte <<= 1; - RangeEnc_EncodeBit(p, probs + (offs + (matchByte & offs) + (symbol >> 8)), (symbol >> 7) & 1); + matchuint8_t <<= 1; + RangeEnc_EncodeBit(p, probs + (offs + (matchuint8_t & offs) + (symbol >> 8)), (symbol >> 7) & 1); symbol <<= 1; - offs &= ~(matchByte ^ symbol); + offs &= ~(matchuint8_t ^ symbol); } while (symbol < 0x10000); }
-static void LzmaEnc_InitPriceTables(UInt32 *ProbPrices) +static void LzmaEnc_InitPriceTables(uint32_t *ProbPrices) { - UInt32 i; + uint32_t i; for (i = (1 << kNumMoveReducingBits) / 2; i < kBitModelTotal; i += (1 << kNumMoveReducingBits)) { const int kCyclesBits = kNumBitPriceShiftBits; - UInt32 w = i; - UInt32 bitCount = 0; + uint32_t w = i; + uint32_t bitCount = 0; int j; for (j = 0; j < kCyclesBits; j++) { w = w * w; bitCount <<= 1; - while (w >= ((UInt32)1 << 16)) + while (w >= ((uint32_t)1 << 16)) { w >>= 1; bitCount++; @@ -633,9 +633,9 @@ static void LzmaEnc_InitPriceTables(UInt32 *ProbPrices) #define GET_PRICE_0a(prob) ProbPrices[(prob) >> kNumMoveReducingBits] #define GET_PRICE_1a(prob) ProbPrices[((prob) ^ (kBitModelTotal - 1)) >> kNumMoveReducingBits]
-static UInt32 LitEnc_GetPrice(const CLzmaProb *probs, UInt32 symbol, UInt32 *ProbPrices) +static uint32_t LitEnc_GetPrice(const CLzmaProb *probs, uint32_t symbol, uint32_t *ProbPrices) { - UInt32 price = 0; + uint32_t price = 0; symbol |= 0x100; do { @@ -646,30 +646,30 @@ static UInt32 LitEnc_GetPrice(const CLzmaProb *probs, UInt32 symbol, UInt32 *Pro return price; }
-static UInt32 LitEnc_GetPriceMatched(const CLzmaProb *probs, UInt32 symbol, UInt32 matchByte, UInt32 *ProbPrices) +static uint32_t LitEnc_GetPriceMatched(const CLzmaProb *probs, uint32_t symbol, uint32_t matchuint8_t, uint32_t *ProbPrices) { - UInt32 price = 0; - UInt32 offs = 0x100; + uint32_t price = 0; + uint32_t offs = 0x100; symbol |= 0x100; do { - matchByte <<= 1; - price += GET_PRICEa(probs[offs + (matchByte & offs) + (symbol >> 8)], (symbol >> 7) & 1); + matchuint8_t <<= 1; + price += GET_PRICEa(probs[offs + (matchuint8_t & offs) + (symbol >> 8)], (symbol >> 7) & 1); symbol <<= 1; - offs &= ~(matchByte ^ symbol); + offs &= ~(matchuint8_t ^ symbol); } while (symbol < 0x10000); return price; }
-static void RcTree_Encode(CRangeEnc *rc, CLzmaProb *probs, int numBitLevels, UInt32 symbol) +static void RcTree_Encode(CRangeEnc *rc, CLzmaProb *probs, int numBitLevels, uint32_t symbol) { - UInt32 m = 1; + uint32_t m = 1; int i; for (i = numBitLevels; i != 0;) { - UInt32 bit; + uint32_t bit; i--; bit = (symbol >> i) & 1; RangeEnc_EncodeBit(rc, probs + m, bit); @@ -677,22 +677,22 @@ static void RcTree_Encode(CRangeEnc *rc, CLzmaProb *probs, int numBitLevels, UIn } }
-static void RcTree_ReverseEncode(CRangeEnc *rc, CLzmaProb *probs, int numBitLevels, UInt32 symbol) +static void RcTree_ReverseEncode(CRangeEnc *rc, CLzmaProb *probs, int numBitLevels, uint32_t symbol) { - UInt32 m = 1; + uint32_t m = 1; int i; for (i = 0; i < numBitLevels; i++) { - UInt32 bit = symbol & 1; + uint32_t bit = symbol & 1; RangeEnc_EncodeBit(rc, probs + m, bit); m = (m << 1) | bit; symbol >>= 1; } }
-static UInt32 RcTree_GetPrice(const CLzmaProb *probs, int numBitLevels, UInt32 symbol, UInt32 *ProbPrices) +static uint32_t RcTree_GetPrice(const CLzmaProb *probs, int numBitLevels, uint32_t symbol, uint32_t *ProbPrices) { - UInt32 price = 0; + uint32_t price = 0; symbol |= (1 << numBitLevels); while (symbol != 1) { @@ -702,14 +702,14 @@ static UInt32 RcTree_GetPrice(const CLzmaProb *probs, int numBitLevels, UInt32 s return price; }
-static UInt32 RcTree_ReverseGetPrice(const CLzmaProb *probs, int numBitLevels, UInt32 symbol, UInt32 *ProbPrices) +static uint32_t RcTree_ReverseGetPrice(const CLzmaProb *probs, int numBitLevels, uint32_t symbol, uint32_t *ProbPrices) { - UInt32 price = 0; - UInt32 m = 1; + uint32_t price = 0; + uint32_t m = 1; int i; for (i = numBitLevels; i != 0; i--) { - UInt32 bit = symbol & 1; + uint32_t bit = symbol & 1; symbol >>= 1; price += GET_PRICEa(probs[m], bit); m = (m << 1) | bit; @@ -730,7 +730,7 @@ static void LenEnc_Init(CLenEnc *p) p->high[i] = kProbInitValue; }
-static void LenEnc_Encode(CLenEnc *p, CRangeEnc *rc, UInt32 symbol, UInt32 posState) +static void LenEnc_Encode(CLenEnc *p, CRangeEnc *rc, uint32_t symbol, uint32_t posState) { if (symbol < kLenNumLowSymbols) { @@ -753,13 +753,13 @@ static void LenEnc_Encode(CLenEnc *p, CRangeEnc *rc, UInt32 symbol, UInt32 posSt } }
-static void LenEnc_SetPrices(CLenEnc *p, UInt32 posState, UInt32 numSymbols, UInt32 *prices, UInt32 *ProbPrices) +static void LenEnc_SetPrices(CLenEnc *p, uint32_t posState, uint32_t numSymbols, uint32_t *prices, uint32_t *ProbPrices) { - UInt32 a0 = GET_PRICE_0a(p->choice); - UInt32 a1 = GET_PRICE_1a(p->choice); - UInt32 b0 = a1 + GET_PRICE_0a(p->choice2); - UInt32 b1 = a1 + GET_PRICE_1a(p->choice2); - UInt32 i = 0; + uint32_t a0 = GET_PRICE_0a(p->choice); + uint32_t a1 = GET_PRICE_1a(p->choice); + uint32_t b0 = a1 + GET_PRICE_0a(p->choice2); + uint32_t b1 = a1 + GET_PRICE_1a(p->choice2); + uint32_t i = 0; for (i = 0; i < kLenNumLowSymbols; i++) { if (i >= numSymbols) @@ -776,20 +776,20 @@ static void LenEnc_SetPrices(CLenEnc *p, UInt32 posState, UInt32 numSymbols, UIn prices[i] = b1 + RcTree_GetPrice(p->high, kLenNumHighBits, i - kLenNumLowSymbols - kLenNumMidSymbols, ProbPrices); }
-static void MY_FAST_CALL LenPriceEnc_UpdateTable(CLenPriceEnc *p, UInt32 posState, UInt32 *ProbPrices) +static void MY_FAST_CALL LenPriceEnc_UpdateTable(CLenPriceEnc *p, uint32_t posState, uint32_t *ProbPrices) { LenEnc_SetPrices(&p->p, posState, p->tableSize, p->prices[posState], ProbPrices); p->counters[posState] = p->tableSize; }
-static void LenPriceEnc_UpdateTables(CLenPriceEnc *p, UInt32 numPosStates, UInt32 *ProbPrices) +static void LenPriceEnc_UpdateTables(CLenPriceEnc *p, uint32_t numPosStates, uint32_t *ProbPrices) { - UInt32 posState; + uint32_t posState; for (posState = 0; posState < numPosStates; posState++) LenPriceEnc_UpdateTable(p, posState, ProbPrices); }
-static void LenEnc_Encode2(CLenPriceEnc *p, CRangeEnc *rc, UInt32 symbol, UInt32 posState, Bool updatePrice, UInt32 *ProbPrices) +static void LenEnc_Encode2(CLenPriceEnc *p, CRangeEnc *rc, uint32_t symbol, uint32_t posState, bool updatePrice, uint32_t *ProbPrices) { LenEnc_Encode(&p->p, rc, symbol, posState); if (updatePrice) @@ -800,7 +800,7 @@ static void LenEnc_Encode2(CLenPriceEnc *p, CRangeEnc *rc, UInt32 symbol, UInt32
-static void MovePos(CLzmaEnc *p, UInt32 num) +static void MovePos(CLzmaEnc *p, uint32_t num) { #ifdef SHOW_STAT ttt += num; @@ -813,16 +813,16 @@ static void MovePos(CLzmaEnc *p, UInt32 num) } }
-static UInt32 ReadMatchDistances(CLzmaEnc *p, UInt32 *numDistancePairsRes) +static uint32_t ReadMatchDistances(CLzmaEnc *p, uint32_t *numDistancePairsRes) { - UInt32 lenRes = 0, numPairs; - p->numAvail = p->matchFinder.GetNumAvailableBytes(p->matchFinderObj); + uint32_t lenRes = 0, numPairs; + p->numAvail = p->matchFinder.GetNumAvailableuint8_ts(p->matchFinderObj); numPairs = p->matchFinder.GetMatches(p->matchFinderObj, p->matches); #ifdef SHOW_STAT printf("\n i = %d numPairs = %d ", ttt, numPairs / 2); ttt++; { - UInt32 i; + uint32_t i; for (i = 0; i < numPairs; i += 2) printf("%2d %6d | ", p->matches[i], p->matches[i + 1]); } @@ -830,15 +830,15 @@ static UInt32 ReadMatchDistances(CLzmaEnc *p, UInt32 *numDistancePairsRes) if (numPairs > 0) { lenRes = p->matches[numPairs - 2]; - if (lenRes == p->numFastBytes) + if (lenRes == p->numFastuint8_ts) { - const Byte *pby = p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - 1; - UInt32 distance = p->matches[numPairs - 1] + 1; - UInt32 numAvail = p->numAvail; + const uint8_t *pby = p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - 1; + uint32_t distance = p->matches[numPairs - 1] + 1; + uint32_t numAvail = p->numAvail; if (numAvail > LZMA_MATCH_LEN_MAX) numAvail = LZMA_MATCH_LEN_MAX; { - const Byte *pby2 = pby - distance; + const uint8_t *pby2 = pby - distance; for (; lenRes < numAvail && pby[lenRes] == pby2[lenRes]; lenRes++); } } @@ -849,20 +849,20 @@ static UInt32 ReadMatchDistances(CLzmaEnc *p, UInt32 *numDistancePairsRes) }
-#define MakeAsChar(p) (p)->backPrev = (UInt32)(-1); (p)->prev1IsChar = False; -#define MakeAsShortRep(p) (p)->backPrev = 0; (p)->prev1IsChar = False; +#define MakeAsChar(p) (p)->backPrev = (uint32_t)(-1); (p)->prev1IsChar = false; +#define MakeAsShortRep(p) (p)->backPrev = 0; (p)->prev1IsChar = false; #define IsShortRep(p) ((p)->backPrev == 0)
-static UInt32 GetRepLen1Price(CLzmaEnc *p, UInt32 state, UInt32 posState) +static uint32_t GetRepLen1Price(CLzmaEnc *p, uint32_t state, uint32_t posState) { return GET_PRICE_0(p->isRepG0[state]) + GET_PRICE_0(p->isRep0Long[state][posState]); }
-static UInt32 GetPureRepPrice(CLzmaEnc *p, UInt32 repIndex, UInt32 state, UInt32 posState) +static uint32_t GetPureRepPrice(CLzmaEnc *p, uint32_t repIndex, uint32_t state, uint32_t posState) { - UInt32 price; + uint32_t price; if (repIndex == 0) { price = GET_PRICE_0(p->isRepG0[state]); @@ -882,16 +882,16 @@ static UInt32 GetPureRepPrice(CLzmaEnc *p, UInt32 repIndex, UInt32 state, UInt32 return price; }
-static UInt32 GetRepPrice(CLzmaEnc *p, UInt32 repIndex, UInt32 len, UInt32 state, UInt32 posState) +static uint32_t GetRepPrice(CLzmaEnc *p, uint32_t repIndex, uint32_t len, uint32_t state, uint32_t posState) { return p->repLenEnc.prices[posState][len - LZMA_MATCH_LEN_MIN] + GetPureRepPrice(p, repIndex, state, posState); }
-static UInt32 Backward(CLzmaEnc *p, UInt32 *backRes, UInt32 cur) +static uint32_t Backward(CLzmaEnc *p, uint32_t *backRes, uint32_t cur) { - UInt32 posMem = p->opt[cur].posPrev; - UInt32 backMem = p->opt[cur].backPrev; + uint32_t posMem = p->opt[cur].posPrev; + uint32_t backMem = p->opt[cur].backPrev; p->optimumEndIndex = cur; do { @@ -901,14 +901,14 @@ static UInt32 Backward(CLzmaEnc *p, UInt32 *backRes, UInt32 cur) p->opt[posMem].posPrev = posMem - 1; if (p->opt[cur].prev2) { - p->opt[posMem - 1].prev1IsChar = False; + p->opt[posMem - 1].prev1IsChar = false; p->opt[posMem - 1].posPrev = p->opt[cur].posPrev2; p->opt[posMem - 1].backPrev = p->opt[cur].backPrev2; } } { - UInt32 posPrev = posMem; - UInt32 backCur = backMem; + uint32_t posPrev = posMem; + uint32_t backCur = backMem;
backMem = p->opt[posPrev].backPrev; posMem = p->opt[posPrev].posPrev; @@ -924,20 +924,20 @@ static UInt32 Backward(CLzmaEnc *p, UInt32 *backRes, UInt32 cur) return p->optimumCurrentIndex; }
-#define LIT_PROBS(pos, prevByte) (p->litProbs + ((((pos) & p->lpMask) << p->lc) + ((prevByte) >> (8 - p->lc))) * 0x300) +#define LIT_PROBS(pos, prevuint8_t) (p->litProbs + ((((pos) & p->lpMask) << p->lc) + ((prevuint8_t) >> (8 - p->lc))) * 0x300)
-static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) +static uint32_t GetOptimum(CLzmaEnc *p, uint32_t position, uint32_t *backRes) { - UInt32 numAvail, mainLen, numPairs, repMaxIndex, i, posState, lenEnd, len, cur; - UInt32 matchPrice, repMatchPrice, normalMatchPrice; - UInt32 reps[LZMA_NUM_REPS], repLens[LZMA_NUM_REPS]; - UInt32 *matches; - const Byte *data; - Byte curByte, matchByte; + uint32_t numAvail, mainLen, numPairs, repMaxIndex, i, posState, lenEnd, len, cur; + uint32_t matchPrice, repMatchPrice, normalMatchPrice; + uint32_t reps[LZMA_NUM_REPS], repLens[LZMA_NUM_REPS]; + uint32_t *matches; + const uint8_t *data; + uint8_t curuint8_t, matchuint8_t; if (p->optimumEndIndex != p->optimumCurrentIndex) { const COptimal *opt = &p->opt[p->optimumCurrentIndex]; - UInt32 lenRes = opt->posPrev - p->optimumCurrentIndex; + uint32_t lenRes = opt->posPrev - p->optimumCurrentIndex; *backRes = opt->backPrev; p->optimumCurrentIndex = opt->posPrev; return lenRes; @@ -955,7 +955,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) numAvail = p->numAvail; if (numAvail < 2) { - *backRes = (UInt32)(-1); + *backRes = (uint32_t)(-1); return 1; } if (numAvail > LZMA_MATCH_LEN_MAX) @@ -965,8 +965,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) repMaxIndex = 0; for (i = 0; i < LZMA_NUM_REPS; i++) { - UInt32 lenTest; - const Byte *data2; + uint32_t lenTest; + const uint8_t *data2; reps[i] = p->reps[i]; data2 = data - (reps[i] + 1); if (data[0] != data2[0] || data[1] != data2[1]) @@ -979,9 +979,9 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) if (lenTest > repLens[repMaxIndex]) repMaxIndex = i; } - if (repLens[repMaxIndex] >= p->numFastBytes) + if (repLens[repMaxIndex] >= p->numFastuint8_ts) { - UInt32 lenRes; + uint32_t lenRes; *backRes = repMaxIndex; lenRes = repLens[repMaxIndex]; MovePos(p, lenRes - 1); @@ -989,18 +989,18 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) }
matches = p->matches; - if (mainLen >= p->numFastBytes) + if (mainLen >= p->numFastuint8_ts) { *backRes = matches[numPairs - 1] + LZMA_NUM_REPS; MovePos(p, mainLen - 1); return mainLen; } - curByte = *data; - matchByte = *(data - (reps[0] + 1)); + curuint8_t = *data; + matchuint8_t = *(data - (reps[0] + 1));
- if (mainLen < 2 && curByte != matchByte && repLens[repMaxIndex] < 2) + if (mainLen < 2 && curuint8_t != matchuint8_t && repLens[repMaxIndex] < 2) { - *backRes = (UInt32)-1; + *backRes = (uint32_t)-1; return 1; }
@@ -1012,8 +1012,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) const CLzmaProb *probs = LIT_PROBS(position, *(data - 1)); p->opt[1].price = GET_PRICE_0(p->isMatch[p->state][posState]) + (!IsCharState(p->state) ? - LitEnc_GetPriceMatched(probs, curByte, matchByte, p->ProbPrices) : - LitEnc_GetPrice(probs, curByte, p->ProbPrices)); + LitEnc_GetPriceMatched(probs, curuint8_t, matchuint8_t, p->ProbPrices) : + LitEnc_GetPrice(probs, curuint8_t, p->ProbPrices)); }
MakeAsChar(&p->opt[1]); @@ -1021,9 +1021,9 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) matchPrice = GET_PRICE_1(p->isMatch[p->state][posState]); repMatchPrice = matchPrice + GET_PRICE_1(p->isRep[p->state]);
- if (matchByte == curByte) + if (matchuint8_t == curuint8_t) { - UInt32 shortRepPrice = repMatchPrice + GetRepLen1Price(p, p->state, posState); + uint32_t shortRepPrice = repMatchPrice + GetRepLen1Price(p, p->state, posState); if (shortRepPrice < p->opt[1].price) { p->opt[1].price = shortRepPrice; @@ -1049,21 +1049,21 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
for (i = 0; i < LZMA_NUM_REPS; i++) { - UInt32 repLen = repLens[i]; - UInt32 price; + uint32_t repLen = repLens[i]; + uint32_t price; if (repLen < 2) continue; price = repMatchPrice + GetPureRepPrice(p, i, p->state, posState); do { - UInt32 curAndLenPrice = price + p->repLenEnc.prices[posState][repLen - 2]; + uint32_t curAndLenPrice = price + p->repLenEnc.prices[posState][repLen - 2]; COptimal *opt = &p->opt[repLen]; if (curAndLenPrice < opt->price) { opt->price = curAndLenPrice; opt->posPrev = 0; opt->backPrev = i; - opt->prev1IsChar = False; + opt->prev1IsChar = false; } } while (--repLen >= 2); @@ -1074,21 +1074,21 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) len = ((repLens[0] >= 2) ? repLens[0] + 1 : 2); if (len <= mainLen) { - UInt32 offs = 0; + uint32_t offs = 0; while (len > matches[offs]) offs += 2; for (; ; len++) { COptimal *opt; - UInt32 distance = matches[offs + 1]; + uint32_t distance = matches[offs + 1];
- UInt32 curAndLenPrice = normalMatchPrice + p->lenEnc.prices[posState][len - LZMA_MATCH_LEN_MIN]; - UInt32 lenToPosState = GetLenToPosState(len); + uint32_t curAndLenPrice = normalMatchPrice + p->lenEnc.prices[posState][len - LZMA_MATCH_LEN_MIN]; + uint32_t lenToPosState = GetLenToPosState(len); if (distance < kNumFullDistances) curAndLenPrice += p->distancesPrices[lenToPosState][distance]; else { - UInt32 slot; + uint32_t slot; GetPosSlot2(distance, slot); curAndLenPrice += p->alignPrices[distance & kAlignMask] + p->posSlotPrices[lenToPosState][slot]; } @@ -1098,7 +1098,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) opt->price = curAndLenPrice; opt->posPrev = 0; opt->backPrev = distance + LZMA_NUM_REPS; - opt->prev1IsChar = False; + opt->prev1IsChar = false; } if (len == matches[offs]) { @@ -1123,11 +1123,11 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
for (;;) { - UInt32 numAvailFull, newLen, numPairs, posPrev, state, posState, startLen; - UInt32 curPrice, curAnd1Price, matchPrice, repMatchPrice; - Bool nextIsChar; - Byte curByte, matchByte; - const Byte *data; + uint32_t numAvailFull, newLen, numPairs, posPrev, state, posState, startLen; + uint32_t curPrice, curAnd1Price, matchPrice, repMatchPrice; + bool nextIsChar; + uint8_t curuint8_t, matchuint8_t; + const uint8_t *data; COptimal *curOpt; COptimal *nextOpt;
@@ -1136,7 +1136,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) return Backward(p, backRes, cur);
newLen = ReadMatchDistances(p, &numPairs); - if (newLen >= p->numFastBytes) + if (newLen >= p->numFastuint8_ts) { p->numPairs = numPairs; p->longestMatchLength = newLen; @@ -1171,7 +1171,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) } else { - UInt32 pos; + uint32_t pos; const COptimal *prevOpt; if (curOpt->prev1IsChar && curOpt->prev2) { @@ -1190,7 +1190,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) prevOpt = &p->opt[posPrev]; if (pos < LZMA_NUM_REPS) { - UInt32 i; + uint32_t i; reps[0] = prevOpt->backs[pos]; for (i = 1; i <= pos; i++) reps[i] = prevOpt->backs[i - 1]; @@ -1199,7 +1199,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) } else { - UInt32 i; + uint32_t i; reps[0] = (pos - LZMA_NUM_REPS); for (i = 1; i < LZMA_NUM_REPS; i++) reps[i] = prevOpt->backs[i - 1]; @@ -1213,10 +1213,10 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) curOpt->backs[3] = reps[3];
curPrice = curOpt->price; - nextIsChar = False; + nextIsChar = false; data = p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - 1; - curByte = *data; - matchByte = *(data - (reps[0] + 1)); + curuint8_t = *data; + matchuint8_t = *(data - (reps[0] + 1));
posState = (position & p->pbMask);
@@ -1225,8 +1225,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) const CLzmaProb *probs = LIT_PROBS(position, *(data - 1)); curAnd1Price += (!IsCharState(state) ? - LitEnc_GetPriceMatched(probs, curByte, matchByte, p->ProbPrices) : - LitEnc_GetPrice(probs, curByte, p->ProbPrices)); + LitEnc_GetPriceMatched(probs, curuint8_t, matchuint8_t, p->ProbPrices) : + LitEnc_GetPrice(probs, curuint8_t, p->ProbPrices)); }
nextOpt = &p->opt[cur + 1]; @@ -1236,41 +1236,41 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) nextOpt->price = curAnd1Price; nextOpt->posPrev = cur; MakeAsChar(nextOpt); - nextIsChar = True; + nextIsChar = true; }
matchPrice = curPrice + GET_PRICE_1(p->isMatch[state][posState]); repMatchPrice = matchPrice + GET_PRICE_1(p->isRep[state]);
- if (matchByte == curByte && !(nextOpt->posPrev < cur && nextOpt->backPrev == 0)) + if (matchuint8_t == curuint8_t && !(nextOpt->posPrev < cur && nextOpt->backPrev == 0)) { - UInt32 shortRepPrice = repMatchPrice + GetRepLen1Price(p, state, posState); + uint32_t shortRepPrice = repMatchPrice + GetRepLen1Price(p, state, posState); if (shortRepPrice <= nextOpt->price) { nextOpt->price = shortRepPrice; nextOpt->posPrev = cur; MakeAsShortRep(nextOpt); - nextIsChar = True; + nextIsChar = true; } } numAvailFull = p->numAvail; { - UInt32 temp = kNumOpts - 1 - cur; + uint32_t temp = kNumOpts - 1 - cur; if (temp < numAvailFull) numAvailFull = temp; }
if (numAvailFull < 2) continue; - numAvail = (numAvailFull <= p->numFastBytes ? numAvailFull : p->numFastBytes); + numAvail = (numAvailFull <= p->numFastuint8_ts ? numAvailFull : p->numFastuint8_ts);
- if (!nextIsChar && matchByte != curByte) /* speed optimization */ + if (!nextIsChar && matchuint8_t != curuint8_t) /* speed optimization */ { /* try Literal + rep0 */ - UInt32 temp; - UInt32 lenTest2; - const Byte *data2 = data - (reps[0] + 1); - UInt32 limit = p->numFastBytes + 1; + uint32_t temp; + uint32_t lenTest2; + const uint8_t *data2 = data - (reps[0] + 1); + uint32_t limit = p->numFastuint8_ts + 1; if (limit > numAvailFull) limit = numAvailFull;
@@ -1278,16 +1278,16 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) lenTest2 = temp - 1; if (lenTest2 >= 2) { - UInt32 state2 = kLiteralNextStates[state]; - UInt32 posStateNext = (position + 1) & p->pbMask; - UInt32 nextRepMatchPrice = curAnd1Price + + uint32_t state2 = kLiteralNextStates[state]; + uint32_t posStateNext = (position + 1) & p->pbMask; + uint32_t nextRepMatchPrice = curAnd1Price + GET_PRICE_1(p->isMatch[state2][posStateNext]) + GET_PRICE_1(p->isRep[state2]); /* for (; lenTest2 >= 2; lenTest2--) */ { - UInt32 curAndLenPrice; + uint32_t curAndLenPrice; COptimal *opt; - UInt32 offset = cur + 1 + lenTest2; + uint32_t offset = cur + 1 + lenTest2; while (lenEnd < offset) p->opt[++lenEnd].price = kInfinityPrice; curAndLenPrice = nextRepMatchPrice + GetRepPrice(p, 0, lenTest2, state2, posStateNext); @@ -1297,8 +1297,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) opt->price = curAndLenPrice; opt->posPrev = cur + 1; opt->backPrev = 0; - opt->prev1IsChar = True; - opt->prev2 = False; + opt->prev1IsChar = true; + opt->prev2 = false; } } } @@ -1306,13 +1306,13 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
startLen = 2; /* speed optimization */ { - UInt32 repIndex; + uint32_t repIndex; for (repIndex = 0; repIndex < LZMA_NUM_REPS; repIndex++) { - UInt32 lenTest; - UInt32 lenTestTemp; - UInt32 price; - const Byte *data2 = data - (reps[repIndex] + 1); + uint32_t lenTest; + uint32_t lenTestTemp; + uint32_t price; + const uint8_t *data2 = data - (reps[repIndex] + 1); if (data[0] != data2[0] || data[1] != data2[1]) continue; for (lenTest = 2; lenTest < numAvail && data[lenTest] == data2[lenTest]; lenTest++); @@ -1322,14 +1322,14 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) price = repMatchPrice + GetPureRepPrice(p, repIndex, state, posState); do { - UInt32 curAndLenPrice = price + p->repLenEnc.prices[posState][lenTest - 2]; + uint32_t curAndLenPrice = price + p->repLenEnc.prices[posState][lenTest - 2]; COptimal *opt = &p->opt[cur + lenTest]; if (curAndLenPrice < opt->price) { opt->price = curAndLenPrice; opt->posPrev = cur; opt->backPrev = repIndex; - opt->prev1IsChar = False; + opt->prev1IsChar = false; } } while (--lenTest >= 2); @@ -1340,18 +1340,18 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
/* if (_maxMode) */ { - UInt32 lenTest2 = lenTest + 1; - UInt32 limit = lenTest2 + p->numFastBytes; - UInt32 nextRepMatchPrice; + uint32_t lenTest2 = lenTest + 1; + uint32_t limit = lenTest2 + p->numFastuint8_ts; + uint32_t nextRepMatchPrice; if (limit > numAvailFull) limit = numAvailFull; for (; lenTest2 < limit && data[lenTest2] == data2[lenTest2]; lenTest2++); lenTest2 -= lenTest + 1; if (lenTest2 >= 2) { - UInt32 state2 = kRepNextStates[state]; - UInt32 posStateNext = (position + lenTest) & p->pbMask; - UInt32 curAndLenCharPrice = + uint32_t state2 = kRepNextStates[state]; + uint32_t posStateNext = (position + lenTest) & p->pbMask; + uint32_t curAndLenCharPrice = price + p->repLenEnc.prices[posState][lenTest - 2] + GET_PRICE_0(p->isMatch[state2][posStateNext]) + LitEnc_GetPriceMatched(LIT_PROBS(position + lenTest, data[lenTest - 1]), @@ -1364,9 +1364,9 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
/* for (; lenTest2 >= 2; lenTest2--) */ { - UInt32 curAndLenPrice; + uint32_t curAndLenPrice; COptimal *opt; - UInt32 offset = cur + lenTest + 1 + lenTest2; + uint32_t offset = cur + lenTest + 1 + lenTest2; while (lenEnd < offset) p->opt[++lenEnd].price = kInfinityPrice; curAndLenPrice = nextRepMatchPrice + GetRepPrice(p, 0, lenTest2, state2, posStateNext); @@ -1376,8 +1376,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) opt->price = curAndLenPrice; opt->posPrev = cur + lenTest + 1; opt->backPrev = 0; - opt->prev1IsChar = True; - opt->prev2 = True; + opt->prev1IsChar = true; + opt->prev2 = true; opt->posPrev2 = cur; opt->backPrev2 = repIndex; } @@ -1386,7 +1386,7 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) } } } - /* for (UInt32 lenTest = 2; lenTest <= newLen; lenTest++) */ + /* for (uint32_t lenTest = 2; lenTest <= newLen; lenTest++) */ if (newLen > numAvail) { newLen = numAvail; @@ -1396,9 +1396,9 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) } if (newLen >= startLen) { - UInt32 normalMatchPrice = matchPrice + GET_PRICE_0(p->isRep[state]); - UInt32 offs, curBack, posSlot; - UInt32 lenTest; + uint32_t normalMatchPrice = matchPrice + GET_PRICE_0(p->isRep[state]); + uint32_t offs, curBack, posSlot; + uint32_t lenTest; while (lenEnd < cur + newLen) p->opt[++lenEnd].price = kInfinityPrice;
@@ -1409,8 +1409,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) GetPosSlot2(curBack, posSlot); for (lenTest = /*2*/ startLen; ; lenTest++) { - UInt32 curAndLenPrice = normalMatchPrice + p->lenEnc.prices[posState][lenTest - LZMA_MATCH_LEN_MIN]; - UInt32 lenToPosState = GetLenToPosState(lenTest); + uint32_t curAndLenPrice = normalMatchPrice + p->lenEnc.prices[posState][lenTest - LZMA_MATCH_LEN_MIN]; + uint32_t lenToPosState = GetLenToPosState(lenTest); COptimal *opt; if (curBack < kNumFullDistances) curAndLenPrice += p->distancesPrices[lenToPosState][curBack]; @@ -1423,25 +1423,25 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) opt->price = curAndLenPrice; opt->posPrev = cur; opt->backPrev = curBack + LZMA_NUM_REPS; - opt->prev1IsChar = False; + opt->prev1IsChar = false; }
if (/*_maxMode && */lenTest == matches[offs]) { /* Try Match + Literal + Rep0 */ - const Byte *data2 = data - (curBack + 1); - UInt32 lenTest2 = lenTest + 1; - UInt32 limit = lenTest2 + p->numFastBytes; - UInt32 nextRepMatchPrice; + const uint8_t *data2 = data - (curBack + 1); + uint32_t lenTest2 = lenTest + 1; + uint32_t limit = lenTest2 + p->numFastuint8_ts; + uint32_t nextRepMatchPrice; if (limit > numAvailFull) limit = numAvailFull; for (; lenTest2 < limit && data[lenTest2] == data2[lenTest2]; lenTest2++); lenTest2 -= lenTest + 1; if (lenTest2 >= 2) { - UInt32 state2 = kMatchNextStates[state]; - UInt32 posStateNext = (position + lenTest) & p->pbMask; - UInt32 curAndLenCharPrice = curAndLenPrice + + uint32_t state2 = kMatchNextStates[state]; + uint32_t posStateNext = (position + lenTest) & p->pbMask; + uint32_t curAndLenCharPrice = curAndLenPrice + GET_PRICE_0(p->isMatch[state2][posStateNext]) + LitEnc_GetPriceMatched(LIT_PROBS(position + lenTest, data[lenTest - 1]), data[lenTest], data2[lenTest], p->ProbPrices); @@ -1453,8 +1453,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
/* for (; lenTest2 >= 2; lenTest2--) */ { - UInt32 offset = cur + lenTest + 1 + lenTest2; - UInt32 curAndLenPrice; + uint32_t offset = cur + lenTest + 1 + lenTest2; + uint32_t curAndLenPrice; COptimal *opt; while (lenEnd < offset) p->opt[++lenEnd].price = kInfinityPrice; @@ -1465,8 +1465,8 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes) opt->price = curAndLenPrice; opt->posPrev = cur + lenTest + 1; opt->backPrev = 0; - opt->prev1IsChar = True; - opt->prev2 = True; + opt->prev1IsChar = true; + opt->prev2 = true; opt->posPrev2 = cur; opt->backPrev2 = curBack + LZMA_NUM_REPS; } @@ -1486,11 +1486,11 @@ static UInt32 GetOptimum(CLzmaEnc *p, UInt32 position, UInt32 *backRes)
#define ChangePair(smallDist, bigDist) (((bigDist) >> 7) > (smallDist))
-static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) +static uint32_t GetOptimumFast(CLzmaEnc *p, uint32_t *backRes) { - UInt32 numAvail, mainLen, mainDist, numPairs, repIndex, repLen, i; - const Byte *data; - const UInt32 *matches; + uint32_t numAvail, mainLen, mainDist, numPairs, repIndex, repLen, i; + const uint8_t *data; + const uint32_t *matches;
if (p->additionalOffset == 0) mainLen = ReadMatchDistances(p, &numPairs); @@ -1501,7 +1501,7 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) }
numAvail = p->numAvail; - *backRes = (UInt32)-1; + *backRes = (uint32_t)-1; if (numAvail < 2) return 1; if (numAvail > LZMA_MATCH_LEN_MAX) @@ -1511,12 +1511,12 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) repLen = repIndex = 0; for (i = 0; i < LZMA_NUM_REPS; i++) { - UInt32 len; - const Byte *data2 = data - (p->reps[i] + 1); + uint32_t len; + const uint8_t *data2 = data - (p->reps[i] + 1); if (data[0] != data2[0] || data[1] != data2[1]) continue; for (len = 2; len < numAvail && data[len] == data2[len]; len++); - if (len >= p->numFastBytes) + if (len >= p->numFastuint8_ts) { *backRes = i; MovePos(p, len - 1); @@ -1530,7 +1530,7 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) }
matches = p->matches; - if (mainLen >= p->numFastBytes) + if (mainLen >= p->numFastuint8_ts) { *backRes = matches[numPairs - 1] + LZMA_NUM_REPS; MovePos(p, mainLen - 1); @@ -1569,7 +1569,7 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) p->longestMatchLength = ReadMatchDistances(p, &p->numPairs); if (p->longestMatchLength >= 2) { - UInt32 newDistance = matches[p->numPairs - 1]; + uint32_t newDistance = matches[p->numPairs - 1]; if ((p->longestMatchLength >= mainLen && newDistance < mainDist) || (p->longestMatchLength == mainLen + 1 && !ChangePair(mainDist, newDistance)) || (p->longestMatchLength > mainLen + 1) || @@ -1580,8 +1580,8 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) data = p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - 1; for (i = 0; i < LZMA_NUM_REPS; i++) { - UInt32 len, limit; - const Byte *data2 = data - (p->reps[i] + 1); + uint32_t len, limit; + const uint8_t *data2 = data - (p->reps[i] + 1); if (data[0] != data2[0] || data[1] != data2[1]) continue; limit = mainLen - 1; @@ -1594,16 +1594,16 @@ static UInt32 GetOptimumFast(CLzmaEnc *p, UInt32 *backRes) return mainLen; }
-static void WriteEndMarker(CLzmaEnc *p, UInt32 posState) +static void WriteEndMarker(CLzmaEnc *p, uint32_t posState) { - UInt32 len; + uint32_t len; RangeEnc_EncodeBit(&p->rc, &p->isMatch[p->state][posState], 1); RangeEnc_EncodeBit(&p->rc, &p->isRep[p->state], 0); p->state = kMatchNextStates[p->state]; len = LZMA_MATCH_LEN_MIN; LenEnc_Encode2(&p->lenEnc, &p->rc, len - LZMA_MATCH_LEN_MIN, posState, !p->fastMode, p->ProbPrices); RcTree_Encode(&p->rc, p->posSlotEncoder[GetLenToPosState(len)], kNumPosSlotBits, (1 << kNumPosSlotBits) - 1); - RangeEnc_EncodeDirectBits(&p->rc, (((UInt32)1 << 30) - 1) >> kNumAlignBits, 30 - kNumAlignBits); + RangeEnc_EncodeDirectBits(&p->rc, (((uint32_t)1 << 30) - 1) >> kNumAlignBits, 30 - kNumAlignBits); RcTree_ReverseEncode(&p->rc, p->posAlignEncoder, kNumAlignBits, kAlignMask); }
@@ -1616,14 +1616,14 @@ static SRes CheckErrors(CLzmaEnc *p) if (p->matchFinderBase.result != SZ_OK) p->result = SZ_ERROR_READ; if (p->result != SZ_OK) - p->finished = True; + p->finished = true; return p->result; }
-static SRes Flush(CLzmaEnc *p, UInt32 nowPos) +static SRes Flush(CLzmaEnc *p, uint32_t nowPos) { /* ReleaseMFStream(); */ - p->finished = True; + p->finished = true; if (p->writeEndMark) WriteEndMarker(p, nowPos & p->pbMask); RangeEnc_FlushData(&p->rc); @@ -1633,7 +1633,7 @@ static SRes Flush(CLzmaEnc *p, UInt32 nowPos)
static void FillAlignPrices(CLzmaEnc *p) { - UInt32 i; + uint32_t i; for (i = 0; i < kAlignTableSize; i++) p->alignPrices[i] = RcTree_ReverseGetPrice(p->posAlignEncoder, kNumAlignBits, i, p->ProbPrices); p->alignPriceCount = 0; @@ -1641,29 +1641,29 @@ static void FillAlignPrices(CLzmaEnc *p)
static void FillDistancesPrices(CLzmaEnc *p) { - UInt32 tempPrices[kNumFullDistances]; - UInt32 i, lenToPosState; + uint32_t tempPrices[kNumFullDistances]; + uint32_t i, lenToPosState; for (i = kStartPosModelIndex; i < kNumFullDistances; i++) { - UInt32 posSlot = GetPosSlot1(i); - UInt32 footerBits = ((posSlot >> 1) - 1); - UInt32 base = ((2 | (posSlot & 1)) << footerBits); + uint32_t posSlot = GetPosSlot1(i); + uint32_t footerBits = ((posSlot >> 1) - 1); + uint32_t base = ((2 | (posSlot & 1)) << footerBits); tempPrices[i] = RcTree_ReverseGetPrice(p->posEncoders + base - posSlot - 1, footerBits, i - base, p->ProbPrices); }
for (lenToPosState = 0; lenToPosState < kNumLenToPosStates; lenToPosState++) { - UInt32 posSlot; + uint32_t posSlot; const CLzmaProb *encoder = p->posSlotEncoder[lenToPosState]; - UInt32 *posSlotPrices = p->posSlotPrices[lenToPosState]; + uint32_t *posSlotPrices = p->posSlotPrices[lenToPosState]; for (posSlot = 0; posSlot < p->distTableSize; posSlot++) posSlotPrices[posSlot] = RcTree_GetPrice(encoder, kNumPosSlotBits, posSlot, p->ProbPrices); for (posSlot = kEndPosModelIndex; posSlot < p->distTableSize; posSlot++) posSlotPrices[posSlot] += ((((posSlot >> 1) - 1) - kNumAlignBits) << kNumBitPriceShiftBits);
{ - UInt32 *distancesPrices = p->distancesPrices[lenToPosState]; - UInt32 i; + uint32_t *distancesPrices = p->distancesPrices[lenToPosState]; + uint32_t i; for (i = 0; i < kStartPosModelIndex; i++) distancesPrices[i] = posSlotPrices[i]; for (; i < kNumFullDistances; i++) @@ -1730,9 +1730,9 @@ void LzmaEnc_Destroy(CLzmaEncHandle p, ISzAlloc *alloc, ISzAlloc *allocBig) alloc->Free(alloc, p); }
-static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize, UInt32 maxUnpackSize) +static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, bool useLimits, uint32_t maxPackSize, uint32_t maxUnpackSize) { - UInt32 nowPos32, startPos32; + uint32_t nowPos32, startPos32; if (p->needInit) { p->matchFinder.Init(p->matchFinderObj); @@ -1743,28 +1743,28 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize return p->result; RINOK(CheckErrors(p));
- nowPos32 = (UInt32)p->nowPos64; + nowPos32 = (uint32_t)p->nowPos64; startPos32 = nowPos32;
if (p->nowPos64 == 0) { - UInt32 numPairs; - Byte curByte; - if (p->matchFinder.GetNumAvailableBytes(p->matchFinderObj) == 0) + uint32_t numPairs; + uint8_t curuint8_t; + if (p->matchFinder.GetNumAvailableuint8_ts(p->matchFinderObj) == 0) return Flush(p, nowPos32); ReadMatchDistances(p, &numPairs); RangeEnc_EncodeBit(&p->rc, &p->isMatch[p->state][0], 0); p->state = kLiteralNextStates[p->state]; - curByte = p->matchFinder.GetIndexByte(p->matchFinderObj, 0 - p->additionalOffset); - LitEnc_Encode(&p->rc, p->litProbs, curByte); + curuint8_t = p->matchFinder.GetIndexuint8_t(p->matchFinderObj, 0 - p->additionalOffset); + LitEnc_Encode(&p->rc, p->litProbs, curuint8_t); p->additionalOffset--; nowPos32++; }
- if (p->matchFinder.GetNumAvailableBytes(p->matchFinderObj) != 0) + if (p->matchFinder.GetNumAvailableuint8_ts(p->matchFinderObj) != 0) for (;;) { - UInt32 pos, len, posState; + uint32_t pos, len, posState;
if (p->fastMode) len = GetOptimumFast(p, &pos); @@ -1776,20 +1776,20 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize #endif
posState = nowPos32 & p->pbMask; - if (len == 1 && pos == (UInt32)-1) + if (len == 1 && pos == (uint32_t)-1) { - Byte curByte; + uint8_t curuint8_t; CLzmaProb *probs; - const Byte *data; + const uint8_t *data;
RangeEnc_EncodeBit(&p->rc, &p->isMatch[p->state][posState], 0); data = p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - p->additionalOffset; - curByte = *data; + curuint8_t = *data; probs = LIT_PROBS(nowPos32, *(data - 1)); if (IsCharState(p->state)) - LitEnc_Encode(&p->rc, probs, curByte); + LitEnc_Encode(&p->rc, probs, curuint8_t); else - LitEnc_EncodeMatched(&p->rc, probs, curByte, *(data - p->reps[0] - 1)); + LitEnc_EncodeMatched(&p->rc, probs, curuint8_t, *(data - p->reps[0] - 1)); p->state = kLiteralNextStates[p->state]; } else @@ -1805,7 +1805,7 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize } else { - UInt32 distance = p->reps[pos]; + uint32_t distance = p->reps[pos]; RangeEnc_EncodeBit(&p->rc, &p->isRepG0[p->state], 1); if (pos == 1) RangeEnc_EncodeBit(&p->rc, &p->isRepG1[p->state], 0); @@ -1830,7 +1830,7 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize } else { - UInt32 posSlot; + uint32_t posSlot; RangeEnc_EncodeBit(&p->rc, &p->isRep[p->state], 0); p->state = kMatchNextStates[p->state]; LenEnc_Encode2(&p->lenEnc, &p->rc, len - LZMA_MATCH_LEN_MIN, posState, !p->fastMode, p->ProbPrices); @@ -1840,9 +1840,9 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize
if (posSlot >= kStartPosModelIndex) { - UInt32 footerBits = ((posSlot >> 1) - 1); - UInt32 base = ((2 | (posSlot & 1)) << footerBits); - UInt32 posReduced = pos - base; + uint32_t footerBits = ((posSlot >> 1) - 1); + uint32_t base = ((2 | (posSlot & 1)) << footerBits); + uint32_t posReduced = pos - base;
if (posSlot < kEndPosModelIndex) RcTree_ReverseEncode(&p->rc, p->posEncoders + base - posSlot - 1, footerBits, posReduced); @@ -1864,7 +1864,7 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize nowPos32 += len; if (p->additionalOffset == 0) { - UInt32 processed; + uint32_t processed; if (!p->fastMode) { if (p->matchPriceCount >= (1 << 7)) @@ -1872,7 +1872,7 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize if (p->alignPriceCount >= kAlignTableSize) FillAlignPrices(p); } - if (p->matchFinder.GetNumAvailableBytes(p->matchFinderObj) == 0) + if (p->matchFinder.GetNumAvailableuint8_ts(p->matchFinderObj) == 0) break; processed = nowPos32 - startPos32; if (useLimits) @@ -1892,13 +1892,13 @@ static SRes LzmaEnc_CodeOneBlock(CLzmaEnc *p, Bool useLimits, UInt32 maxPackSize return Flush(p, nowPos32); }
-#define kBigHashDicLimit ((UInt32)1 << 24) +#define kBigHashDicLimit ((uint32_t)1 << 24)
-static SRes LzmaEnc_Alloc(CLzmaEnc *p, UInt32 keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) +static SRes LzmaEnc_Alloc(CLzmaEnc *p, uint32_t keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) { - UInt32 beforeSize = kNumOpts; + uint32_t beforeSize = kNumOpts; #ifndef _7ZIP_ST - Bool btMode; + bool btMode; #endif if (!RangeEnc_Alloc(&p->rc, alloc)) return SZ_ERROR_MEM; @@ -1931,14 +1931,14 @@ static SRes LzmaEnc_Alloc(CLzmaEnc *p, UInt32 keepWindowSize, ISzAlloc *alloc, I #ifndef _7ZIP_ST if (p->mtMode) { - RINOK(MatchFinderMt_Create(&p->matchFinderMt, p->dictSize, beforeSize, p->numFastBytes, LZMA_MATCH_LEN_MAX, allocBig)); + RINOK(MatchFinderMt_Create(&p->matchFinderMt, p->dictSize, beforeSize, p->numFastuint8_ts, LZMA_MATCH_LEN_MAX, allocBig)); p->matchFinderObj = &p->matchFinderMt; MatchFinderMt_CreateVTable(&p->matchFinderMt, &p->matchFinder); } else #endif { - if (!MatchFinder_Create(&p->matchFinderBase, p->dictSize, beforeSize, p->numFastBytes, LZMA_MATCH_LEN_MAX, allocBig)) + if (!MatchFinder_Create(&p->matchFinderBase, p->dictSize, beforeSize, p->numFastuint8_ts, LZMA_MATCH_LEN_MAX, allocBig)) return SZ_ERROR_MEM; p->matchFinderObj = &p->matchFinderBase; MatchFinder_CreateVTable(&p->matchFinderBase, &p->matchFinder); @@ -1948,7 +1948,7 @@ static SRes LzmaEnc_Alloc(CLzmaEnc *p, UInt32 keepWindowSize, ISzAlloc *alloc, I
static void LzmaEnc_Init(CLzmaEnc *p) { - UInt32 i; + uint32_t i; p->state = 0; for (i = 0 ; i < LZMA_NUM_REPS; i++) p->reps[i] = 0; @@ -1958,7 +1958,7 @@ static void LzmaEnc_Init(CLzmaEnc *p)
for (i = 0; i < kNumStates; i++) { - UInt32 j; + uint32_t j; for (j = 0; j < LZMA_NUM_PB_STATES_MAX; j++) { p->isMatch[i][j] = kProbInitValue; @@ -1971,7 +1971,7 @@ static void LzmaEnc_Init(CLzmaEnc *p) }
{ - UInt32 num = 0x300 << (p->lp + p->lc); + uint32_t num = 0x300 << (p->lp + p->lc); for (i = 0; i < num; i++) p->litProbs[i] = kProbInitValue; } @@ -1980,7 +1980,7 @@ static void LzmaEnc_Init(CLzmaEnc *p) for (i = 0; i < kNumLenToPosStates; i++) { CLzmaProb *probs = p->posSlotEncoder[i]; - UInt32 j; + uint32_t j; for (j = 0; j < (1 << kNumPosSlotBits); j++) probs[j] = kProbInitValue; } @@ -2014,20 +2014,20 @@ static void LzmaEnc_InitPrices(CLzmaEnc *p)
p->lenEnc.tableSize = p->repLenEnc.tableSize = - p->numFastBytes + 1 - LZMA_MATCH_LEN_MIN; + p->numFastuint8_ts + 1 - LZMA_MATCH_LEN_MIN; LenPriceEnc_UpdateTables(&p->lenEnc, 1 << p->pb, p->ProbPrices); LenPriceEnc_UpdateTables(&p->repLenEnc, 1 << p->pb, p->ProbPrices); }
-static SRes LzmaEnc_AllocAndInit(CLzmaEnc *p, UInt32 keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) +static SRes LzmaEnc_AllocAndInit(CLzmaEnc *p, uint32_t keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) { - UInt32 i; - for (i = 0; i < (UInt32)kDicLogSizeMaxCompress; i++) - if (p->dictSize <= ((UInt32)1 << i)) + uint32_t i; + for (i = 0; i < (uint32_t)kDicLogSizeMaxCompress; i++) + if (p->dictSize <= ((uint32_t)1 << i)) break; p->distTableSize = i * 2;
- p->finished = False; + p->finished = false; p->result = SZ_OK; RINOK(LzmaEnc_Alloc(p, keepWindowSize, alloc, allocBig)); LzmaEnc_Init(p); @@ -2047,7 +2047,7 @@ static SRes LzmaEnc_Prepare(CLzmaEncHandle pp, ISeqOutStream *outStream, ISeqInS }
/*static SRes LzmaEnc_PrepareForLzma2(CLzmaEncHandle pp, - ISeqInStream *inStream, UInt32 keepWindowSize, + ISeqInStream *inStream, uint32_t keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) { CLzmaEnc *p = (CLzmaEnc *)pp; @@ -2056,15 +2056,15 @@ static SRes LzmaEnc_Prepare(CLzmaEncHandle pp, ISeqOutStream *outStream, ISeqInS return LzmaEnc_AllocAndInit(p, keepWindowSize, alloc, allocBig); }*/
-static void LzmaEnc_SetInputBuf(CLzmaEnc *p, const Byte *src, SizeT srcLen) +static void LzmaEnc_SetInputBuf(CLzmaEnc *p, const uint8_t *src, size_t srcLen) { p->matchFinderBase.directInput = 1; - p->matchFinderBase.bufferBase = (Byte *)src; + p->matchFinderBase.bufferBase = (uint8_t *)src; p->matchFinderBase.directInputRem = srcLen; }
-static SRes LzmaEnc_MemPrepare(CLzmaEncHandle pp, const Byte *src, SizeT srcLen, - UInt32 keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) +static SRes LzmaEnc_MemPrepare(CLzmaEncHandle pp, const uint8_t *src, size_t srcLen, + uint32_t keepWindowSize, ISzAlloc *alloc, ISzAlloc *allocBig) { CLzmaEnc *p = (CLzmaEnc *)pp; LzmaEnc_SetInputBuf(p, src, srcLen); @@ -2087,9 +2087,9 @@ static void LzmaEnc_Finish(CLzmaEncHandle pp) typedef struct { ISeqOutStream funcTable; - Byte *data; - SizeT rem; - Bool overflow; + uint8_t *data; + size_t rem; + bool overflow; } CSeqOutStreamBuf;
static size_t MyWrite(void *pp, const void *data, size_t size) @@ -2098,7 +2098,7 @@ static size_t MyWrite(void *pp, const void *data, size_t size) if (p->rem < size) { size = p->rem; - p->overflow = True; + p->overflow = true; } memcpy(p->data, data, size); p->rem -= size; @@ -2107,33 +2107,33 @@ static size_t MyWrite(void *pp, const void *data, size_t size) }
-/*static UInt32 LzmaEnc_GetNumAvailableBytes(CLzmaEncHandle pp) +/*static uint32_t LzmaEnc_GetNumAvailableuint8_ts(CLzmaEncHandle pp) { const CLzmaEnc *p = (CLzmaEnc *)pp; - return p->matchFinder.GetNumAvailableBytes(p->matchFinderObj); + return p->matchFinder.GetNumAvailableuint8_ts(p->matchFinderObj); }*/
-/*static const Byte *LzmaEnc_GetCurBuf(CLzmaEncHandle pp) +/*static const uint8_t *LzmaEnc_GetCurBuf(CLzmaEncHandle pp) { const CLzmaEnc *p = (CLzmaEnc *)pp; return p->matchFinder.GetPointerToCurrentPos(p->matchFinderObj) - p->additionalOffset; }*/
-/*static SRes LzmaEnc_CodeOneMemBlock(CLzmaEncHandle pp, Bool reInit, - Byte *dest, size_t *destLen, UInt32 desiredPackSize, UInt32 *unpackSize) +/*static SRes LzmaEnc_CodeOneMemBlock(CLzmaEncHandle pp, bool reInit, + uint8_t *dest, size_t *destLen, uint32_t desiredPackSize, uint32_t *unpackSize) { CLzmaEnc *p = (CLzmaEnc *)pp; - UInt64 nowPos64; + uint64_t nowPos64; SRes res; CSeqOutStreamBuf outStream;
outStream.funcTable.Write = MyWrite; outStream.data = dest; outStream.rem = *destLen; - outStream.overflow = False; + outStream.overflow = false;
- p->writeEndMark = False; - p->finished = False; + p->writeEndMark = false; + p->finished = false; p->result = SZ_OK;
if (reInit) @@ -2143,9 +2143,9 @@ static size_t MyWrite(void *pp, const void *data, size_t size) RangeEnc_Init(&p->rc); p->rc.outStream = &outStream.funcTable;
- res = LzmaEnc_CodeOneBlock(p, True, desiredPackSize, *unpackSize); + res = LzmaEnc_CodeOneBlock(p, true, desiredPackSize, *unpackSize);
- *unpackSize = (UInt32)(p->nowPos64 - nowPos64); + *unpackSize = (uint32_t)(p->nowPos64 - nowPos64); *destLen -= outStream.rem; if (outStream.overflow) return SZ_ERROR_OUTPUT_EOF; @@ -2158,15 +2158,15 @@ static SRes LzmaEnc_Encode2(CLzmaEnc *p, ICompressProgress *progress) SRes res = SZ_OK;
#ifndef _7ZIP_ST - Byte allocaDummy[0x300]; + uint8_t allocaDummy[0x300]; int i = 0; for (i = 0; i < 16; i++) - allocaDummy[i] = (Byte)i; + allocaDummy[i] = (uint8_t)i; #endif
for (;;) { - res = LzmaEnc_CodeOneBlock(p, False, 0, 0); + res = LzmaEnc_CodeOneBlock(p, false, 0, 0); if (res != SZ_OK || p->finished != 0) break; if (progress != 0) @@ -2190,24 +2190,24 @@ SRes LzmaEnc_Encode(CLzmaEncHandle pp, ISeqOutStream *outStream, ISeqInStream *i return LzmaEnc_Encode2((CLzmaEnc *)pp, progress); }
-SRes LzmaEnc_WriteProperties(CLzmaEncHandle pp, Byte *props, SizeT *size) +SRes LzmaEnc_WriteProperties(CLzmaEncHandle pp, uint8_t *props, size_t *size) { CLzmaEnc *p = (CLzmaEnc *)pp; int i; - UInt32 dictSize = p->dictSize; + uint32_t dictSize = p->dictSize; if (*size < LZMA_PROPS_SIZE) return SZ_ERROR_PARAM; *size = LZMA_PROPS_SIZE; - props[0] = (Byte)((p->pb * 5 + p->lp) * 9 + p->lc); + props[0] = (uint8_t)((p->pb * 5 + p->lp) * 9 + p->lc);
for (i = 11; i <= 30; i++) { - if (dictSize <= ((UInt32)2 << i)) + if (dictSize <= ((uint32_t)2 << i)) { dictSize = (2 << i); break; } - if (dictSize <= ((UInt32)3 << i)) + if (dictSize <= ((uint32_t)3 << i)) { dictSize = (3 << i); break; @@ -2215,11 +2215,11 @@ SRes LzmaEnc_WriteProperties(CLzmaEncHandle pp, Byte *props, SizeT *size) }
for (i = 0; i < 4; i++) - props[1 + i] = (Byte)(dictSize >> (8 * i)); + props[1 + i] = (uint8_t)(dictSize >> (8 * i)); return SZ_OK; }
-SRes LzmaEnc_MemEncode(CLzmaEncHandle pp, Byte *dest, SizeT *destLen, const Byte *src, SizeT srcLen, +SRes LzmaEnc_MemEncode(CLzmaEncHandle pp, uint8_t *dest, size_t *destLen, const uint8_t *src, size_t srcLen, int writeEndMark, ICompressProgress *progress, ISzAlloc *alloc, ISzAlloc *allocBig) { SRes res; @@ -2232,7 +2232,7 @@ SRes LzmaEnc_MemEncode(CLzmaEncHandle pp, Byte *dest, SizeT *destLen, const Byte outStream.funcTable.Write = MyWrite; outStream.data = dest; outStream.rem = *destLen; - outStream.overflow = False; + outStream.overflow = false;
p->writeEndMark = writeEndMark;
@@ -2247,8 +2247,8 @@ SRes LzmaEnc_MemEncode(CLzmaEncHandle pp, Byte *dest, SizeT *destLen, const Byte return res; }
-SRes LzmaEncode(Byte *dest, SizeT *destLen, const Byte *src, SizeT srcLen, - const CLzmaEncProps *props, Byte *propsEncoded, SizeT *propsSize, int writeEndMark, +SRes LzmaEncode(uint8_t *dest, size_t *destLen, const uint8_t *src, size_t srcLen, + const CLzmaEncProps *props, uint8_t *propsEncoded, size_t *propsSize, int writeEndMark, ICompressProgress *progress, ISzAlloc *alloc, ISzAlloc *allocBig) { CLzmaEnc *p = (CLzmaEnc *)LzmaEnc_Create(alloc); diff --git a/util/cbfstool/lzma/C/LzmaEnc.h b/util/cbfstool/lzma/C/LzmaEnc.h index 200d60e..7a6cb59 100644 --- a/util/cbfstool/lzma/C/LzmaEnc.h +++ b/util/cbfstool/lzma/C/LzmaEnc.h @@ -15,7 +15,7 @@ extern "C" { typedef struct _CLzmaEncProps { int level; /* 0 <= level <= 9 */ - UInt32 dictSize; /* (1 << 12) <= dictSize <= (1 << 27) for 32-bit version + uint32_t dictSize; /* (1 << 12) <= dictSize <= (1 << 27) for 32-bit version (1 << 12) <= dictSize <= (1 << 30) for 64-bit version default = (1 << 24) */ int lc; /* 0 <= lc <= 8, default = 3 */ @@ -25,14 +25,14 @@ typedef struct _CLzmaEncProps int fb; /* 5 <= fb <= 273, default = 32 */ int btMode; /* 0 - hashChain Mode, 1 - binTree mode - normal, default = 1 */ int numHashBytes; /* 2, 3 or 4, default = 4 */ - UInt32 mc; /* 1 <= mc <= (1 << 30), default = 32 */ + uint32_t mc; /* 1 <= mc <= (1 << 30), default = 32 */ unsigned writeEndMark; /* 0 - do not write EOPM, 1 - write EOPM, default = 0 */ int numThreads; /* 1 or 2, default = 2 */ } CLzmaEncProps;
void LzmaEncProps_Init(CLzmaEncProps *p); void LzmaEncProps_Normalize(CLzmaEncProps *p); -UInt32 LzmaEncProps_GetDictSize(const CLzmaEncProps *props2); +uint32_t LzmaEncProps_GetDictSize(const CLzmaEncProps *props2);
/* ---------- CLzmaEncHandle Interface ---------- */ @@ -52,10 +52,10 @@ typedef void * CLzmaEncHandle; CLzmaEncHandle LzmaEnc_Create(ISzAlloc *alloc); void LzmaEnc_Destroy(CLzmaEncHandle p, ISzAlloc *alloc, ISzAlloc *allocBig); SRes LzmaEnc_SetProps(CLzmaEncHandle p, const CLzmaEncProps *props); -SRes LzmaEnc_WriteProperties(CLzmaEncHandle p, Byte *properties, SizeT *size); +SRes LzmaEnc_WriteProperties(CLzmaEncHandle p, uint8_t *properties, size_t *size); SRes LzmaEnc_Encode(CLzmaEncHandle p, ISeqOutStream *outStream, ISeqInStream *inStream, ICompressProgress *progress, ISzAlloc *alloc, ISzAlloc *allocBig); -SRes LzmaEnc_MemEncode(CLzmaEncHandle p, Byte *dest, SizeT *destLen, const Byte *src, SizeT srcLen, +SRes LzmaEnc_MemEncode(CLzmaEncHandle p, uint8_t *dest, size_t *destLen, const uint8_t *src, size_t srcLen, int writeEndMark, ICompressProgress *progress, ISzAlloc *alloc, ISzAlloc *allocBig);
/* ---------- One Call Interface ---------- */ @@ -69,8 +69,8 @@ Return code: SZ_ERROR_THREAD - errors in multithreading functions (only for Mt version) */
-SRes LzmaEncode(Byte *dest, SizeT *destLen, const Byte *src, SizeT srcLen, - const CLzmaEncProps *props, Byte *propsEncoded, SizeT *propsSize, int writeEndMark, +SRes LzmaEncode(uint8_t *dest, size_t *destLen, const uint8_t *src, size_t srcLen, + const CLzmaEncProps *props, uint8_t *propsEncoded, size_t *propsSize, int writeEndMark, ICompressProgress *progress, ISzAlloc *alloc, ISzAlloc *allocBig);
#ifdef __cplusplus diff --git a/util/cbfstool/lzma/C/Types.h b/util/cbfstool/lzma/C/Types.h index d7bc78d..c4e6ccf 100644 --- a/util/cbfstool/lzma/C/Types.h +++ b/util/cbfstool/lzma/C/Types.h @@ -5,6 +5,8 @@ #define __7Z_TYPES_H
#include <stddef.h> +#include <stdint.h> +#include <stdbool.h>
#ifdef _WIN32 #include <windows.h> @@ -52,48 +54,6 @@ typedef int WRes; #define RINOK(x) { int __result__ = (x); if (__result__ != 0) return __result__; } #endif
-typedef unsigned char Byte; -typedef short Int16; -typedef unsigned short UInt16; - -#ifdef _LZMA_UINT32_IS_ULONG -typedef long Int32; -typedef unsigned long UInt32; -#else -typedef int Int32; -typedef unsigned int UInt32; -#endif - -#ifdef _SZ_NO_INT_64 - -/* define _SZ_NO_INT_64, if your compiler doesn't support 64-bit integers. - NOTES: Some code will work incorrectly in that case! */ - -typedef long Int64; -typedef unsigned long UInt64; - -#else - -#if defined(_MSC_VER) || defined(__BORLANDC__) -typedef __int64 Int64; -typedef unsigned __int64 UInt64; -#else -typedef long long int Int64; -typedef unsigned long long int UInt64; -#endif - -#endif - -#ifdef _LZMA_NO_SYSTEM_SIZE_T -typedef UInt32 SizeT; -#else -typedef size_t SizeT; -#endif - -typedef int Bool; -#define True 1 -#define False 0 -
#ifdef _WIN32 #define MY_STD_CALL __stdcall @@ -124,13 +84,13 @@ typedef int Bool;
typedef struct { - Byte (*Read)(void *p); /* reads one byte, returns 0 in case of EOF or error */ -} IByteIn; + uint8_t (*Read)(void *p); /* reads one byte, returns 0 in case of EOF or error */ +} Iuint8_tIn;
typedef struct { - void (*Write)(void *p, Byte b); -} IByteOut; + void (*Write)(void *p, uint8_t b); +} Iuint8_tOut;
typedef struct ISeqInStream { @@ -145,7 +105,7 @@ typedef struct ISeqInStream /* it can return SZ_ERROR_INPUT_EOF */ SRes SeqInStream_Read(ISeqInStream *stream, void *buf, size_t size); SRes SeqInStream_Read2(ISeqInStream *stream, void *buf, size_t size, SRes errorType); -SRes SeqInStream_ReadByte(ISeqInStream *stream, Byte *buf); +SRes SeqInStream_Readuint8_t(ISeqInStream *stream, uint8_t *buf);
typedef struct ISeqOutStream { @@ -167,7 +127,7 @@ typedef enum typedef struct { SRes (*Read)(void *p, void *buf, size_t *size); /* same as ISeqInStream::Read */ - SRes (*Seek)(void *p, Int64 *pos, ESzSeek origin); + SRes (*Seek)(void *p, int64_t *pos, ESzSeek origin); } ISeekInStream;
typedef struct @@ -181,11 +141,11 @@ typedef struct
SRes (*Read)(void *p, void *buf, size_t *size); /* reads directly (without buffer). It's same as ISeqInStream::Read */ - SRes (*Seek)(void *p, Int64 *pos, ESzSeek origin); + SRes (*Seek)(void *p, int64_t *pos, ESzSeek origin); } ILookInStream;
SRes LookInStream_LookRead(ILookInStream *stream, void *buf, size_t *size); -SRes LookInStream_SeekTo(ILookInStream *stream, UInt64 offset); +SRes LookInStream_SeekTo(ILookInStream *stream, uint64_t offset);
/* reads via ILookInStream::Read */ SRes LookInStream_Read2(ILookInStream *stream, void *buf, size_t size, SRes errorType); @@ -199,7 +159,7 @@ typedef struct ISeekInStream *realStream; size_t pos; size_t size; - Byte buf[LookToRead_BUF_SIZE]; + uint8_t buf[LookToRead_BUF_SIZE]; } CLookToRead;
void LookToRead_CreateVTable(CLookToRead *p, int lookahead); @@ -223,9 +183,9 @@ void SecToRead_CreateVTable(CSecToRead *p);
typedef struct { - SRes (*Progress)(void *p, UInt64 inSize, UInt64 outSize); + SRes (*Progress)(void *p, uint64_t inSize, uint64_t outSize); /* Returns: result. (result != SZ_OK) means break. - Value (UInt64)(Int64)-1 for size means unknown value. */ + Value (uint64_t)(int64_t)-1 for size means unknown value. */ } ICompressProgress;
typedef struct diff --git a/util/cbfstool/lzma/lzma.c b/util/cbfstool/lzma/lzma.c index 579784e..f889946 100644 --- a/util/cbfstool/lzma/lzma.c +++ b/util/cbfstool/lzma/lzma.c @@ -186,9 +186,9 @@ void do_lzma_uncompress(char *dst, int dst_len, char *src, int src_len) size_t destlen = out_sizemax; size_t srclen = src_len - (LZMA_PROPS_SIZE + 8);
- int res = LzmaDecode((Byte *) dst, &destlen, - (Byte *) &src[LZMA_PROPS_SIZE + 8], &srclen, - (Byte *) &src[0], LZMA_PROPS_SIZE, + int res = LzmaDecode((uint8_t *) dst, &destlen, + (uint8_t *) &src[LZMA_PROPS_SIZE + 8], &srclen, + (uint8_t *) &src[0], LZMA_PROPS_SIZE, LZMA_FINISH_END, &status, &LZMAalloc);
