Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/81955?usp=email )
Change subject: mb/google/nissa/var/glassway: Add SPD IDs for two new memory parts ......................................................................
Support Memory for Hynix H58G66AK6BX070 and Samsung K3KL9L90CM-MGCT in mem_parts_used list, and generate SPD ID for these parts.
DRAM Part Name ID to assign H58G66AK6BX070 4 (0100) K3KL9L90CM-MGCT 5 (0101)
BUG=b:335341310 BRANCH=firmware-nissa-15217.B TEST=Run command "go run ./util/spd_tools/src/part_id_gen/\ part_id_gen.go ADL lp5 \ src/mainboard/google/brya/variants/glassway/memory/ \ src/mainboard/google/brya/variants/glassway/memory/\ mem_parts_used.txt"
Change-Id: Ic07ec36a8015ce6433196a93e894b818a515b954 Signed-off-by: Daniel_Peng Daniel_Peng@pegatron.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/81955 Reviewed-by: Kapil Porwal kapilporwal@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Eric Lai ericllai@google.com Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Daniel Peng daniel_peng@pegatron.corp-partner.google.com --- M src/mainboard/google/brya/variants/glassway/memory/Makefile.mk M src/mainboard/google/brya/variants/glassway/memory/dram_id.generated.txt M src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt 3 files changed, 8 insertions(+), 2 deletions(-)
Approvals: Eric Lai: Looks good to me, approved Daniel Peng: Looks good to me, but someone else must approve Kapil Porwal: Looks good to me, approved build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/glassway/memory/Makefile.mk b/src/mainboard/google/brya/variants/glassway/memory/Makefile.mk index b4d82e9..3104c19 100644 --- a/src/mainboard/google/brya/variants/glassway/memory/Makefile.mk +++ b/src/mainboard/google/brya/variants/glassway/memory/Makefile.mk @@ -1,10 +1,12 @@ # SPDX-License-Identifier: GPL-2.0-or-later # This is an auto-generated file. Do not edit!! # Generated by: -# /tmp/go-build472300524/b001/exe/part_id_gen ADL lp5 src/mainboard/google/brya/variants/glassway/memory/ src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt +# /tmp/go-build486926698/b001/exe/part_id_gen ADL lp5 src/mainboard/google/brya/variants/glassway/memory/ src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt
SPD_SOURCES = SPD_SOURCES += spd/lp5/set-0/spd-7.hex # ID = 0(0b0000) Parts = K3KL8L80CM-MGCT SPD_SOURCES += spd/lp5/set-0/spd-9.hex # ID = 1(0b0001) Parts = K3KL6L60GM-MGCT SPD_SOURCES += spd/lp5/set-0/spd-3.hex # ID = 2(0b0010) Parts = H58G56AK6BX069 SPD_SOURCES += spd/lp5/set-0/spd-1.hex # ID = 3(0b0011) Parts = H9JCNNNBK3MLYR-N6E +SPD_SOURCES += spd/lp5/set-0/spd-6.hex # ID = 4(0b0100) Parts = H58G66AK6BX070 +SPD_SOURCES += spd/lp5/set-0/spd-8.hex # ID = 5(0b0101) Parts = K3KL9L90CM-MGCT diff --git a/src/mainboard/google/brya/variants/glassway/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/glassway/memory/dram_id.generated.txt index 866132d3..ca68f99 100644 --- a/src/mainboard/google/brya/variants/glassway/memory/dram_id.generated.txt +++ b/src/mainboard/google/brya/variants/glassway/memory/dram_id.generated.txt @@ -1,10 +1,12 @@ # SPDX-License-Identifier: GPL-2.0-or-later # This is an auto-generated file. Do not edit!! # Generated by: -# /tmp/go-build472300524/b001/exe/part_id_gen ADL lp5 src/mainboard/google/brya/variants/glassway/memory/ src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt +# /tmp/go-build486926698/b001/exe/part_id_gen ADL lp5 src/mainboard/google/brya/variants/glassway/memory/ src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt
DRAM Part Name ID to assign K3KL8L80CM-MGCT 0 (0000) K3KL6L60GM-MGCT 1 (0001) H58G56AK6BX069 2 (0010) H9JCNNNBK3MLYR-N6E 3 (0011) +H58G66AK6BX070 4 (0100) +K3KL9L90CM-MGCT 5 (0101) diff --git a/src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt index deeb000..f742b0b 100644 --- a/src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt +++ b/src/mainboard/google/brya/variants/glassway/memory/mem_parts_used.txt @@ -13,3 +13,5 @@ K3KL6L60GM-MGCT H58G56AK6BX069 H9JCNNNBK3MLYR-N6E +H58G66AK6BX070 +K3KL9L90CM-MGCT
