Attention is currently required from: Subrata Banik, Tim Wawrzynczak, Paul Menzel, Eric Lai, Angel Pons, Patrick Rudolph, EricR Lai. John Zhao has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/62723 )
Change subject: soc/intel/common: Configure TCSS access through IOE P2SB ......................................................................
Patch Set 9:
File src/soc/intel/common/block/tcss/tcss.c:
https://review.coreboot.org/c/coreboot/+/62723/comment/548c057f_e45ed2c7 PS5, Line 371: static void ioe_tcss_configure_aux_bias_pads_sbi( : const struct typec_aux_bias_pads *pads) : { : for (size_t i = 0; i < MAX_TYPE_C_PORTS; i++) { : if (pads[i].pad_auxn_dc && pads[i].pad_auxp_dc) { : ioe_p2sb_sbi_write(PID_IOM, IOM_AUX_BIAS_CTRL_PULLUP_OFFSET(i), : calc_bias_ctrl_reg_value(pads[i].pad_auxp_dc)); : ioe_p2sb_sbi_write(PID_IOM, IOM_AUX_BIAS_CTRL_PULLDOWN_OFFSET(i), : calc_bias_ctrl_reg_value(pads[i].pad_auxn_dc)); : } : } : } : : static void tcss_configure_aux_bias_pads( : const struct typec_aux_bias_pads *pads) : { : if (CONFIG(SOC_INTEL_COMMON_BLOCK_TCSS_REG_ACCESS_REGBAR)) : tcss_configure_aux_bias_pads_regbar(pads); : else if (CONFIG(SOC_INTEL_COMMON_BLOCK_TCSS_REG_ACCESS_SBI)) { : if (CONFIG(SOC_INTEL_COMMON_BLOCK_IOE_P2SB)) : ioe_tcss_configure_aux_bias_pads_sbi(pads); : } : else : printk(BIOS_ERR, "%s: Error: No TCSS configuration method is selected!\n", : __func__); : } : : const struct tcss_port_map *tcss_get_port_info(size_t *num_ports) : { : static struct tcss_port_map port_map[MAX_TYPE_C_PORTS]; : size_t active_ports = 0; : size_t port; : : for (port = 0; port < MAX_TYPE_C_PORTS; port++) { : const struct device_path conn_path[] = { : {.type = DEVICE_PATH_PCI, .pci.devfn = PCH_DEVFN_PMC}, : {.type = DEVICE_PATH_GENERIC, .generic.id = 0, .generic.subid = 0}, : {.type = DEVICE_PATH_GENERIC, .generic.id = port}, : }; : const struct device *conn = find_dev_nested_path(pci_root_bus(), conn_path, : ARRAY_SIZE(conn_path)); : unsigned int usb2_port, usb3_port; : : if (!conn) : continue; : : if (CONFIG(DRIVERS_INTEL_PMC) && : intel_pmc_mux_conn_get_ports(conn, &usb2_port, &usb3_port)) { : port_map[active_ports].usb2_port = usb2_port; : port_map[active_ports].usb3_port = usb3_port; : ++active_ports; : } : } : : *num_ports = active_ports; : return port_map; : } : : void tcss_configure(const struct typec_aux_bias_pads aux_bias_pads[MAX_TYPE_C_PORTS]) : { : const struct tcss_port_map *port_map; : size_t num_ports; : size_t i; : : port_map = tcss_get_port_info(&num_ports); : if (port_map == NULL) : return; : : for (i = 0; i < num_ports; i++) : tcss_init_mux(i, &port_map[i]); : : /* This should be performed before alternate modes are entered */ : tcss_configure_aux_bias_pads(aux_bias_pads); : : if (CONFIG(ENABLE_TCSS_DISPLAY_DETECTION)) : tcss_configure_dp_mode(port_map, num_ports); : } : : uint32_t tcss_valid_tbt_auth(void) : { : if (CONFIG(SOC_INTEL_COMMON_BLOCK_TCSS_REG_ACCESS_REGBAR)) { : return REGBAR32(PID_IOM, IOM_CSME_IMR_TBT_STATUS) & TBT_VALID_AUTHENTICATION; : } else if (CONFIG(SOC_INTEL_COMMON_BLOCK_TCSS_REG_ACCESS_SBI)) { : if (CONFIG(SOC_INTEL_COMMON_BLOCK_IOE_P2SB)) : return (ioe_p2sb_sbi_read(PID_IOM, IOM_CSME_IMR_TBT_STATUS) & : TBT_VALID_AUTHENTICATION); : } : : printk(BIOS_ERR, "%s: Error: No validation for Thunderbolt authentication!\n", : __func__); : return 0; : }
I vote soc_tcss_ops. Very objective way like other chips driver.
Ack
