Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9171
commit 19081eacddc9898dfce85cc9e1da0f420aa169c4 Author: Aaron Durbin adurbin@chromium.org Date: Sun Mar 29 00:05:18 2015 -0500
fmap: add region based fmap API
Instead of being pointer based use the region infrastrucutre. Additionally, this removes the need for arch-specific compilation paths.
Change-Id: I436533a4f4a272837794ee00c90280602745edac Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/Kconfig | 9 +++ src/include/fmap.h | 35 ++++++++++ src/lib/Makefile.inc | 4 ++ src/lib/fmap.c | 121 +++++++++++++++++++++++++++++++++ src/vendorcode/google/chromeos/Kconfig | 8 --- 5 files changed, 169 insertions(+), 8 deletions(-)
diff --git a/src/Kconfig b/src/Kconfig index 2625266..0741275 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -219,6 +219,15 @@ config CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM The relocated ramstage is saved in an area specified by the by the board and/or chipset.
+config FLASHMAP_OFFSET + hex "Flash Map Offset" + default 0x00670000 if NORTHBRIDGE_INTEL_SANDYBRIDGE + default 0x00610000 if NORTHBRIDGE_INTEL_IVYBRIDGE + default CBFS_SIZE if !ARCH_X86 + default 0 + help + Offset of flash map in firmware image + choice prompt "Bootblock behaviour" default BOOTBLOCK_SIMPLE diff --git a/src/include/fmap.h b/src/include/fmap.h new file mode 100644 index 0000000..1128d2e --- /dev/null +++ b/src/include/fmap.h @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef _FMAP_H_ +#define _FMAP_H_ + +#include <region.h> + +/* Locate the named area in the fmap and fill in a region device representing + * that area. The region is a sub-region of the readonly boot media. Return + * 0 on success, < 0 on error. */ +int fmap_locate_area_as_rdev(const char *name, struct region_device *area); + +/* Locate the named area in the fmap and fill in a region with the + * offset and size of that area within the boot media. Return 0 on success, + * < 0 on error. */ +int fmap_locate_area(const char *name, struct region *r); + +#endif diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index bbab500..54fe420 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -28,11 +28,13 @@ bootblock-y += memchr.c bootblock-y += memcmp.c bootblock-y += mem_pool.c bootblock-y += region.c +bootblock-y += fmap.c
verstage-y += prog_ops.c verstage-y += delay.c verstage-y += cbfs.c verstage-y += cbfs_boot_props.c +verstage-y += fmap.c verstage-y += memcmp.c verstage-y += region.c verstage-$(CONFIG_CONSOLE_CBMEM) += cbmem_console.c @@ -46,6 +48,7 @@ romstage-y += memchr.c romstage-y += memcmp.c $(foreach arch,$(ARCH_SUPPORTED),\ $(eval rmodules_$(arch)-y += memcmp.c)) +romstage-y += fmap.c
romstage-$(CONFIG_I2C_TPM) += delay.c romstage-y += cbfs.c @@ -72,6 +75,7 @@ ramstage-y += hardwaremain.c ramstage-y += selfboot.c ramstage-y += coreboot_table.c ramstage-y += bootmem.c +ramstage-y += fmap.c ramstage-y += memchr.c ramstage-y += memcmp.c ramstage-y += malloc.c diff --git a/src/lib/fmap.c b/src/lib/fmap.c new file mode 100644 index 0000000..b50a186 --- /dev/null +++ b/src/lib/fmap.c @@ -0,0 +1,121 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2012-2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <boot_device.h> +#include <console/console.h> +#include <fmap.h> +#include <fmap_serialized.h> +#include <stddef.h> +#include <string.h> + +/* + * See http://code.google.com/p/flashmap/ for more information on FMAP. + */ + +static int find_fmap_directory(struct region_device *fmrd) +{ + const struct region_device *boot; + struct fmap *fmap; + size_t fmap_size; + size_t offset = CONFIG_FLASHMAP_OFFSET; + + boot = boot_device_ro(); + + if (boot == NULL) + return -1; + + fmap_size = sizeof(struct fmap); + + fmap = rdev_mmap(boot, offset, fmap_size); + + if (fmap == NULL) + return -1; + + if (memcmp(fmap->signature, FMAP_SIGNATURE, sizeof(fmap->signature))) { + printk(BIOS_DEBUG, "No FMAP found at %zx offset.\n", offset); + rdev_munmap(boot, fmap); + return -1; + } + + printk(BIOS_DEBUG, "FMAP: Found "%s" version %d.%d at %zx.\n", + fmap->name, fmap->ver_major, fmap->ver_minor, offset); + printk(BIOS_DEBUG, "FMAP: base = %llx size = %x #areas = %d\n", + (long long)fmap->base, fmap->size, fmap->nareas); + + fmap_size += fmap->nareas * sizeof(struct fmap_area); + + rdev_munmap(boot, fmap); + + return rdev_chain(fmrd, boot, offset, fmap_size); +} + +int fmap_locate_area_as_rdev(const char *name, struct region_device *area) +{ + const struct region_device *boot; + struct region ar; + + boot = boot_device_ro(); + + if (fmap_locate_area(name, &ar)) + return -1; + + return rdev_chain(area, boot, ar.offset, ar.size); +} + +int fmap_locate_area(const char *name, struct region *ar) +{ + struct region_device fmrd; + size_t offset; + + if (find_fmap_directory(&fmrd)) + return -1; + + /* Start reading the areas just after fmap header. */ + offset = sizeof(struct fmap); + + while (1) { + struct fmap_area *area; + + area = rdev_mmap(&fmrd, offset, sizeof(*area)); + + if (area == NULL) + return -1; + + if (strcmp((const char *)area->name, name)) { + rdev_munmap(&fmrd, area); + offset += sizeof(struct fmap_area); + continue; + } + + printk(BIOS_DEBUG, "FMAP: area %s found\n", name); + printk(BIOS_DEBUG, "FMAP: offset: %x\n", area->offset); + printk(BIOS_DEBUG, "FMAP: size: %d bytes\n", area->size); + + ar->offset = area->offset; + ar->size = area->size; + + rdev_munmap(&fmrd, area); + + return 0; + } + + printk(BIOS_DEBUG, "FMAP: area %s not found\n", name); + + return -1; +} diff --git a/src/vendorcode/google/chromeos/Kconfig b/src/vendorcode/google/chromeos/Kconfig index 8826a14..4259ad9 100644 --- a/src/vendorcode/google/chromeos/Kconfig +++ b/src/vendorcode/google/chromeos/Kconfig @@ -86,14 +86,6 @@ config CHROMEOS_RAMOOPS_RAM_SIZE default 0x00100000 depends on CHROMEOS_RAMOOPS
-config FLASHMAP_OFFSET - hex "Flash Map Offset" - default 0x00670000 if NORTHBRIDGE_INTEL_SANDYBRIDGE - default 0x00610000 if NORTHBRIDGE_INTEL_IVYBRIDGE - default 0 - help - Offset of flash map in firmware image - config VBOOT_VERIFY_FIRMWARE bool "Verify firmware with vboot." default n
