Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/71697 )
Change subject: mb/google/brya/var/gladios: Update RTL8168 LAN LED config ......................................................................
Adjust LAN LED config to 0x060f.
BUG=b:239513596 TEST=emerge-brask coreboot
Change-Id: I17b844b89569fb7653454fd08782fc961c715817 Signed-off-by: Robert Chen robert.chen@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/71697 Reviewed-by: Kevin Chiu kevin.chiu.17802@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Ricky Chang rickytlchang@google.com --- M src/mainboard/google/brya/variants/gladios/overridetree.cb 1 file changed, 20 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Kevin Chiu: Looks good to me, approved Ricky Chang: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/brya/variants/gladios/overridetree.cb b/src/mainboard/google/brya/variants/gladios/overridetree.cb index 86e4b69..6a21f2a 100644 --- a/src/mainboard/google/brya/variants/gladios/overridetree.cb +++ b/src/mainboard/google/brya/variants/gladios/overridetree.cb @@ -187,9 +187,7 @@ device ref pcie_rp7 on chip drivers/net register "wake" = "GPE0_DW0_07" - register "led_feature" = "0xe0" - register "customized_led0" = "0x23f" - register "customized_led2" = "0x028" + register "customized_leds" = "0x060f" register "enable_aspm_l1_2" = "1" register "add_acpi_dma_property" = "true" device pci 00.0 on end
