Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43703 )
Change subject: arch/x86/smbios: Fix type4 for EDK2 ......................................................................
Mark the CPU as enabled and the socket as poulated. EDK2 tests this flags before further reading this structure.
Change-Id: Ic545bb47c502cb9d2352ba6d43eaed8c97229c02 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/arch/x86/smbios.c M src/include/smbios.h 2 files changed, 7 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/43703/1
diff --git a/src/arch/x86/smbios.c b/src/arch/x86/smbios.c index 61b6aa2..375f318 100644 --- a/src/arch/x86/smbios.c +++ b/src/arch/x86/smbios.c @@ -734,6 +734,8 @@ t->l2_cache_handle = 0xffff; t->l3_cache_handle = 0xffff; t->serial_number = smbios_add_string(t->eos, smbios_processor_serial_number()); + t->status = SMBIOS_PROCESSOR_STATUS_CPU_ENABLED | + SMBIOS_PROCESSOR_STATUS_POPULATED; t->processor_upgrade = get_socket_type(); len = t->length + smbios_string_table_len(t->eos); if (cpu_have_cpuid() && cpuid_get_max_func() >= 0x16) { diff --git a/src/include/smbios.h b/src/include/smbios.h index 8cdd58a..45c550a 100644 --- a/src/include/smbios.h +++ b/src/include/smbios.h @@ -405,6 +405,11 @@ u8 eos[2]; } __packed;
+/* defines for smbios_type4 */ + +#define SMBIOS_PROCESSOR_STATUS_POPULATED (1 << 6) +#define SMBIOS_PROCESSOR_STATUS_CPU_ENABLED (1 << 0) + /* defines for supported_sram_type/current_sram_type */
#define SMBIOS_CACHE_SRAM_TYPE_OTHER (1 << 0)
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43703 )
Patch Set 1: Code-Review+1
(2 comments)
https://review.coreboot.org/c/coreboot/+/43703/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43703/1//COMMIT_MSG@9 PS1, Line 9: poulated po*p*ulated
https://review.coreboot.org/c/coreboot/+/43703/1//COMMIT_MSG@10 PS1, Line 10: this these
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43703 )
Patch Set 1:
(2 comments)
po*p*ulated
Done
these
Done
Hello Philipp Deppenwiese, build bot (Jenkins), Christian Walter, Angel Pons, Marcello Sylvester Bauer,
Mark the CPU as enabled and the socket as populated. EDK2 tests these flags before further reading this structure.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/43703/2
Patch Set 2: Code-Review+2
With this and the parent, an old CorebootPayloadPkg tianocore payload on Asrock B85M Pro4 correctly says there are 8192 MB of RAM (two 4 GiB sticks).
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43703 )
Change-Id: Ic545bb47c502cb9d2352ba6d43eaed8c97229c02 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43703 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/arch/x86/smbios.c M src/include/smbios.h 2 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/src/arch/x86/smbios.c b/src/arch/x86/smbios.c index c38c369..070c7ea 100644 --- a/src/arch/x86/smbios.c +++ b/src/arch/x86/smbios.c @@ -734,6 +734,8 @@ t->l2_cache_handle = 0xffff; t->l3_cache_handle = 0xffff; t->serial_number = smbios_add_string(t->eos, smbios_processor_serial_number()); + t->status = SMBIOS_PROCESSOR_STATUS_CPU_ENABLED | + SMBIOS_PROCESSOR_STATUS_POPULATED; t->processor_upgrade = get_socket_type(); len = t->length + smbios_string_table_len(t->eos); if (cpu_have_cpuid() && cpuid_get_max_func() >= 0x16) { diff --git a/src/include/smbios.h b/src/include/smbios.h index 8cdd58a..45c550a 100644 --- a/src/include/smbios.h +++ b/src/include/smbios.h @@ -405,6 +405,11 @@ u8 eos[2]; } __packed;
