Boon Tiong Teo (boon.tiong.teo@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16519
commit 332d01f7d015784e5ff16aec680484a020587e48 Author: bteo1 boon.tiong.teo@intel.com Date: Mon Sep 5 16:00:07 2016 +0800
Added superio/nuvoton/nct6776
Change-Id: I546879285ad8336e81798d0fbdf94f72e1fa61a2 Signed-off-by: bteo1 boon.tiong.teo@intel.com --- src/superio/nuvoton/Makefile.inc | 1 + src/superio/nuvoton/common/early_serial.c | 3 + src/superio/nuvoton/nct6776/Kconfig | 23 +++++++ src/superio/nuvoton/nct6776/Makefile.inc | 18 ++++++ src/superio/nuvoton/nct6776/nct6776.h | 58 ++++++++++++++++++ src/superio/nuvoton/nct6776/superio.c | 99 +++++++++++++++++++++++++++++++ 6 files changed, 202 insertions(+)
diff --git a/src/superio/nuvoton/Makefile.inc b/src/superio/nuvoton/Makefile.inc index 94cc6b7..e2e178b 100644 --- a/src/superio/nuvoton/Makefile.inc +++ b/src/superio/nuvoton/Makefile.inc @@ -19,5 +19,6 @@ romstage-$(CONFIG_SUPERIO_NUVOTON_COMMON_ROMSTAGE) += common/early_serial.c subdirs-$(CONFIG_SUPERIO_NUVOTON_WPCM450) += wpcm450 subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT5104D) += nct5104d subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT5572D) += nct5572d +subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT6776) += nct6776 subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT6779D) += nct6779d subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT6791D) += nct6791d diff --git a/src/superio/nuvoton/common/early_serial.c b/src/superio/nuvoton/common/early_serial.c index fca5ed6..966b8e1 100644 --- a/src/superio/nuvoton/common/early_serial.c +++ b/src/superio/nuvoton/common/early_serial.c @@ -63,6 +63,9 @@ static void pnp_exit_conf_state(pnp_devfn_t dev) void nuvoton_enable_serial(pnp_devfn_t dev, u16 iobase) { pnp_enter_conf_state(dev); +if (IS_ENABLED(CONFIG_SUPERIO_NUVOTON_NCT6776_COM_A)) + /* Route GPIO8 pin group to COM A */ + pnp_write_config(dev, 0x2a, 0x40); pnp_set_logical_device(dev); pnp_set_enable(dev, 0); pnp_set_iobase(dev, PNP_IDX_IO0, iobase); diff --git a/src/superio/nuvoton/nct6776/Kconfig b/src/superio/nuvoton/nct6776/Kconfig new file mode 100644 index 0000000..cf0fe21 --- /dev/null +++ b/src/superio/nuvoton/nct6776/Kconfig @@ -0,0 +1,23 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2011 - 2012 Advanced Micro Devices, Inc. +## Copyright (C) 2014 Felix Held felix-coreboot@felixheld.de +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +config SUPERIO_NUVOTON_NCT6776 + bool + select SUPERIO_NUVOTON_COMMON_ROMSTAGE + +config SUPERIO_NUVOTON_NCT6776_COM_A + bool + default n diff --git a/src/superio/nuvoton/nct6776/Makefile.inc b/src/superio/nuvoton/nct6776/Makefile.inc new file mode 100644 index 0000000..13fe527 --- /dev/null +++ b/src/superio/nuvoton/nct6776/Makefile.inc @@ -0,0 +1,18 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2011 - 2012 Advanced Micro Devices, Inc. +## Copyright (C) 2014 Felix Held felix-coreboot@felixheld.de +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; either version 2 of the License, or +## (at your option) any later version. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +ramstage-$(CONFIG_SUPERIO_NUVOTON_NCT6776) += superio.c diff --git a/src/superio/nuvoton/nct6776/nct6776.h b/src/superio/nuvoton/nct6776/nct6776.h new file mode 100644 index 0000000..520401e --- /dev/null +++ b/src/superio/nuvoton/nct6776/nct6776.h @@ -0,0 +1,58 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Felix Held felix-coreboot@felixheld.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Both NCT6776D and NCT6776F package variants are supported. */ + +#ifndef SUPERIO_NUVOTON_NCT6776_H +#define SUPERIO_NUVOTON_NCT6776_H + +/* Logical Device Numbers (LDN). */ +#define NCT6776_FDC 0x00 /* Floppy */ +#define NCT6776_PP 0x01 /* Parallel port */ +#define NCT6776_SP1 0x02 /* Com1 */ +#define NCT6776_SP2 0x03 /* Com2 & IR */ +#define NCT6776_KBC 0x05 /* PS/2 keyboard and mouse */ +#define NCT6776_CIR 0x06 +#define NCT6776_GPIO6789_V 0x07 +#define NCT6776_WDT1_GPIO01A_V 0x08 +#define NCT6776_GPIO1234567_V 0x09 +#define NCT6776_ACPI 0x0A +#define NCT6776_HWM_FPLED 0x0B /* Hardware monitor & front LED */ +#define NCT6776_VID 0x0D +#define NCT6776_CIRWKUP 0x0E /* CIR wakeup */ +#define NCT6776_GPIO_PP_OD 0x0F /* GPIO Push-Pull/Open drain select */ +#define NCT6776_SVID 0x14 +#define NCT6776_DSLP 0x16 /* Deep sleep */ +#define NCT6776_GPIOA_LDN 0x17 + +/* virtual LDN for GPIO and WDT */ +#define NCT6776_WDT1 ((0 << 8) | NCT6776_WDT1_GPIO01A_V) + +#define NCT6776_GPIOBASE ((0 << 8) | NCT6776_WDT1_GPIO01A_V) //? + +#define NCT6776_GPIO0 ((1 << 8) | NCT6776_WDT1_GPIO01A_V) +#define NCT6776_GPIO1 ((1 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO2 ((2 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO3 ((3 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO4 ((4 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO5 ((5 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO6 ((6 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO7 ((7 << 8) | NCT6776_GPIO1234567_V) +#define NCT6776_GPIO8 ((0 << 8) | NCT6776_GPIO6789_V) +#define NCT6776_GPIO9 ((1 << 8) | NCT6776_GPIO6789_V) +#define NCT6776_GPIOA ((2 << 8) | NCT6776_WDT1_GPIO01A_V) + +#endif /* SUPERIO_NUVOTON_NCT6776_H */ diff --git a/src/superio/nuvoton/nct6776/superio.c b/src/superio/nuvoton/nct6776/superio.c new file mode 100644 index 0000000..85f52cf --- /dev/null +++ b/src/superio/nuvoton/nct6776/superio.c @@ -0,0 +1,99 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2011 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Felix Held felix-coreboot@felixheld.de + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/io.h> +#include <device/device.h> +#include <device/pnp.h> +#include <pc80/keyboard.h> +#include <stdlib.h> +#include <superio/conf_mode.h> + +#include "nct6776.h" + +/* Both NCT6776D and NCT6776F package variants are supported. */ + +static void nct6776_init(struct device *dev) +{ + if (!dev->enabled) + return; + + switch (dev->path.pnp.device) { + /* TODO: Might potentially need code for HWM or FDC etc. */ + case NCT6776_KBC: + pc_keyboard_init(NO_AUX_DEVICE); + break; + } +} + +static struct device_operations ops = { + .read_resources = pnp_read_resources, + .set_resources = pnp_set_resources, + .enable_resources = pnp_enable_resources, + .enable = pnp_alt_enable, + .init = nct6776_init, + .ops_pnp_mode = &pnp_conf_mode_8787_aa, +}; + +static struct pnp_info pnp_dev_info[] = { + { &ops, NCT6776_FDC, PNP_IO0 | PNP_IRQ0 | PNP_DRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_PP, PNP_IO0 | PNP_IRQ0 | PNP_DRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_SP1, PNP_IO0 | PNP_IRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_SP2, PNP_IO0 | PNP_IRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_KBC, PNP_IO0 | PNP_IO1 | PNP_IRQ0 | PNP_IRQ1, + {0x0fff, 0}, {0x0fff, 4}, }, + { &ops, NCT6776_CIR, PNP_IO0 | PNP_IRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_ACPI}, + { &ops, NCT6776_HWM_FPLED, PNP_IO0 | PNP_IO1 | PNP_IRQ0, + {0x0ffe, 0}, {0x0ffe, 4}, }, + { &ops, NCT6776_VID}, + { &ops, NCT6776_CIRWKUP, PNP_IO0 | PNP_IRQ0, + {0x0ff8, 0}, }, + { &ops, NCT6776_GPIO_PP_OD}, + { &ops, NCT6776_SVID}, + { &ops, NCT6776_DSLP}, + { &ops, NCT6776_GPIOA_LDN}, + { &ops, NCT6776_WDT1}, + { &ops, NCT6776_GPIOBASE, PNP_IO0, + {0x0ff8, 0}, }, + { &ops, NCT6776_GPIO0}, + { &ops, NCT6776_GPIO1}, + { &ops, NCT6776_GPIO2}, + { &ops, NCT6776_GPIO3}, + { &ops, NCT6776_GPIO4}, + { &ops, NCT6776_GPIO5}, + { &ops, NCT6776_GPIO6}, + { &ops, NCT6776_GPIO7}, + { &ops, NCT6776_GPIO8}, + { &ops, NCT6776_GPIO9}, + { &ops, NCT6776_GPIOA}, +}; + +static void enable_dev(struct device *dev) +{ + pnp_enable_devices(dev, &ops, ARRAY_SIZE(pnp_dev_info), pnp_dev_info); +} + +struct chip_operations superio_nuvoton_nct6776_ops = { + CHIP_NAME("NUVOTON NCT6776 Super I/O") + .enable_dev = enable_dev, +};
