Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18544
commit 17d90245949d4935a2e61043d4f033d1a3614fcf Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Mar 2 13:01:58 2017 +0200
Stage rules.h: Add ENV_LIBAGESA
Definition is required to enable use of printk() from AGESA proper.
Change-Id: I6666a003c91794490f670802d496321ffb965cd3 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/include/rules.h | 19 +++++++++++++++++++ src/vendorcode/amd/agesa/Makefile.inc | 1 + 2 files changed, 20 insertions(+)
diff --git a/src/include/rules.h b/src/include/rules.h index a632804..45622ea 100644 --- a/src/include/rules.h +++ b/src/include/rules.h @@ -27,6 +27,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "bootblock"
#elif defined(__ROMSTAGE__) @@ -37,6 +38,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "romstage"
#elif defined(__SMM__) @@ -47,6 +49,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "smm"
#elif defined(__VERSTAGE__) @@ -57,6 +60,7 @@ #define ENV_VERSTAGE 1 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "verstage"
#elif defined(__RAMSTAGE__) @@ -67,6 +71,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "ramstage"
#elif defined(__RMODULE__) @@ -77,6 +82,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 1 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "rmodule"
#elif defined(__POSTCAR__) @@ -87,8 +93,20 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 1 +#define ENV_LIBAGESA 0 #define ENV_STRING "postcar"
+#elif defined(__LIBAGESA__) +#define ENV_BOOTBLOCK 0 +#define ENV_ROMSTAGE 0 +#define ENV_RAMSTAGE 0 +#define ENV_SMM 0 +#define ENV_VERSTAGE 0 +#define ENV_RMODULE 0 +#define ENV_POSTCAR 0 +#define ENV_LIBAGESA 1 +#define ENV_STRING "libagesa" + #else /* * Default case of nothing set for random blob generation using @@ -103,6 +121,7 @@ #define ENV_VERSTAGE 0 #define ENV_RMODULE 0 #define ENV_POSTCAR 0 +#define ENV_LIBAGESA 0 #define ENV_STRING "UNKNOWN" #endif
diff --git a/src/vendorcode/amd/agesa/Makefile.inc b/src/vendorcode/amd/agesa/Makefile.inc index fab6f63..f2423d0 100644 --- a/src/vendorcode/amd/agesa/Makefile.inc +++ b/src/vendorcode/amd/agesa/Makefile.inc @@ -12,6 +12,7 @@ subdirs-y += common
classes-y += libagesa libagesa-y = +libagesa-generic-ccopts += -D__LIBAGESA__
ifeq ($(CONFIG_ARCH_ROMSTAGE_X86_32),y) $(eval $(call create_class_compiler,libagesa,x86_32))
