guang li (liguangbz@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3214
commit c9639bb9fc69174ee7d99f217d0b56fd49149577 Author: liguang liguangbz@gmail.com Date: Tue May 7 19:24:00 2013 +0800
mips32: add dummy Kconfig files
Change-Id: I593d628bc580958d118a5ca5746f6450c2060565 Signed-off-by: liguang liguangbz@gmail.com --- src/Kconfig | 8 ++++++++ src/arch/mips32/Kconfig | 3 +++ src/cpu/loongson/Kconfig | 9 +++++++++ src/cpu/loongson/loongson2e/Kconfig | 0 4 files changed, 20 insertions(+)
diff --git a/src/Kconfig b/src/Kconfig index ce7f400..c07b944 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -226,6 +226,10 @@ config ARCH_ARMV7 bool default n
+config ARCH_MIPS32 + bool + default n + # Warning: The file is included whether or not the if is here. # but the if controls how the evaluation occurs. if ARCH_X86 @@ -236,6 +240,10 @@ if ARCH_ARMV7 source src/arch/armv7/Kconfig endif
+if ARCH_MIPS32 +source src/arch/mips32/Kconfig +endif + menu "Chipset"
comment "CPU" diff --git a/src/arch/mips32/Kconfig b/src/arch/mips32/Kconfig new file mode 100644 index 0000000..a0d3daa --- /dev/null +++ b/src/arch/mips32/Kconfig @@ -0,0 +1,3 @@ +menu "Architecture (mips32)" + +endmenu diff --git a/src/cpu/loongson/Kconfig b/src/cpu/loongson/Kconfig new file mode 100644 index 0000000..a997ff6 --- /dev/null +++ b/src/cpu/loongson/Kconfig @@ -0,0 +1,9 @@ +config CPU_LOONGSON_2E + depends on ARCH_MIPS32 + bool + default n + +if CPU_LOONGSON_2E +source src/cpu/loongson/loongson2e/Kconfig +endif + diff --git a/src/cpu/loongson/loongson2e/Kconfig b/src/cpu/loongson/loongson2e/Kconfig new file mode 100644 index 0000000..e69de29
