Attention is currently required from: Elyes Haouas, Jason Glenesk, Martin L Roth.
Nicholas Chin has posted comments on this change by Nicholas Chin. ( https://review.coreboot.org/c/coreboot/+/83976?usp=email )
Change subject: Docs: Fix broken header references ......................................................................
Patch Set 1:
File Documentation/mainboard/lenovo/Ivy_Bridge_series.md:
https://review.coreboot.org/c/coreboot/+/83976/comment/14d79b08_837b36c5?usp... : PS1, Line 84: : [split the resulting coreboot ROM](#splitting-the-corebootrom) and then write
shouldn't be: […]
No. As per https://myst-parser.readthedocs.io/en/latest/syntax/optional.html#anchor-slu...:
" The anchor “slugs” created aim to follow the GitHub implementation: - lower-case text - remove punctuation - replace spaces with - - enforce uniqueness via suffix enumeration -1
MyST includes a utility called `myst-anchors` which shows the actual references that are generated for a particular file, and that output corebootrom.
