Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12276
commit dc0f164aad9981fc851b696b5fe12869725fe81a Author: Patrick Georgi pgeorgi@chromium.org Date: Fri Oct 30 23:49:32 2015 +0100
abuild: change compile_target interface
It only takes a single argument now, which is the directory below the coreboot-builds directory. Preparation for future work.
The only visible change is in console output.
Change-Id: I4b0fe268ccfb69a0403fa5f8b23444c07843386f Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- util/abuild/abuild | 19 +++++++++---------- 1 file changed, 9 insertions(+), 10 deletions(-)
diff --git a/util/abuild/abuild b/util/abuild/abuild index 40d4b41..d513dce 100755 --- a/util/abuild/abuild +++ b/util/abuild/abuild @@ -216,43 +216,42 @@ function create_buildenv
function compile_target { - VENDOR=$1 - MAINBOARD=$2 + local MAINBOARD=$1
- if [ "$quiet" == "false" ]; then printf " Compiling $VENDOR/$MAINBOARD image$cpuconfig...\n"; fi + if [ "$quiet" == "false" ]; then printf " Compiling $MAINBOARD image$cpuconfig...\n"; fi
CURR=$( pwd ) #stime=`perl -e 'print time();' 2>/dev/null || date +%s` - build_dir=$TARGET/${VENDOR}_${MAINBOARD} + build_dir=$TARGET/${MAINBOARD} eval $BUILDPREFIX $MAKE $silent DOTCONFIG=${build_dir}/config.build obj=${build_dir} objutil=$TARGET/sharedutils \ &> ${build_dir}/make.log ret=$? cp .xcompile ${build_dir}/xcompile.build - cd $TARGET/${VENDOR}_${MAINBOARD} + cd $TARGET/${MAINBOARD}
etime=`perl -e 'print time();' 2>/dev/null || date +%s` duration=$(( $etime - $stime )) - junit " <testcase classname='board${testclass/#/.}' name='$VENDOR/$MAINBOARD' time='$duration' >" + junit " <testcase classname='board${testclass/#/.}' name='$MAINBOARD' time='$duration' >"
if [ $ret -eq 0 ]; then junit "<system-out>" junitfile make.log junit "</system-out>" printf "ok\n" > compile.status - printf "$VENDOR/$MAINBOARD built successfully. (took ${duration}s)\n" + printf "$MAINBOARD built successfully. (took ${duration}s)\n" else ret=1 junit "<failure type='BuildFailed'>" junitfile make.log junit "</failure>" printf "failed\n" > compile.status - printf "$VENDOR/$MAINBOARD build FAILED after ${duration}s!\nLog excerpt:\n" + printf "$MAINBOARD build FAILED after ${duration}s!\nLog excerpt:\n" tail -n $CONTEXT make.log 2> /dev/null || tail -$CONTEXT make.log failed=1 fi cd $CURR if [ $clean_work = "true" ]; then - rm -rf $TARGET/${VENDOR}_${MAINBOARD} + rm -rf $TARGET/${MAINBOARD} fi return $ret } @@ -305,7 +304,7 @@ function build_target rm -rf ${scanbuild_out} BUILDPREFIX="scan-build -o ${scanbuild_out}tmp" fi - compile_target $VENDOR $MAINBOARD + compile_target ${VENDOR}_${MAINBOARD} if [ "$scanbuild" = "true" ]; then mv ${scanbuild_out}tmp/* ${scanbuild_out} rmdir ${scanbuild_out}tmp
