Attention is currently required from: Sean Rhodes, Tarun Tuli, Subrata Banik.
Hello build bot (Jenkins), Nico Huber, Tarun Tuli, Subrata Banik, Michael Niewöhner,
https://review.coreboot.org/c/coreboot/+/74476
Change subject: soc/intel/tigerlake: Replace TcssD3ColdDisable with D3COLD_SUPPORT ......................................................................
Remove the `TcssD3ColdDisable` option in devicetree, as it exists in Kconfig. The setting is only used on `starlabs/starbook` which selects D3COLD_SUPPORT so the UPDs will not change.
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: I50e49e900c96748edd5b678765e47cc0e0d9b280 --- M src/mainboard/starlabs/starbook/variants/tgl/devicetree.cb M src/mainboard/starlabs/starbook/variants/tgl/devtree.c M src/soc/intel/tigerlake/chip.h M src/soc/intel/tigerlake/fsp_params.c 4 files changed, 15 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/76/74476/4
