Stefan Reinauer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80435?usp=email )
Change subject: crossgcc: Add buildgcc support for Apple M1/M2 devices ......................................................................
GMP and IASL don't compile with the default compiler and linker flags: - GMP's check for the MacOS architecture hard coded x86_64 but it also needs to know about arm64. - iasl does some trickery on pointer alignment to save space(?), so we need to tell clang about it.
Change-Id: If4cca9d3e55051a6121d992e5320bee1df17af9f Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- M util/crossgcc/buildgcc 1 file changed, 5 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/35/80435/1
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index b294da5..54ab4e2 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -847,10 +847,11 @@ cd ../$IASL_DIR/generate/unix || exit 1 CFLAGS="$HOSTCFLAGS" HOST="_LINUX" - test "$UNAME" = "Darwin" && HOST="_APPLE" + test "$UNAME" = "Darwin" && HOST="_APPLE" && OPT_LDFLAGS="-Wl,-no_fixup_chains" test "$UNAME" = "FreeBSD" && HOST="_FreeBSD" test "$UNAME" = "Cygwin" && HOST="_CYGWIN" HOST="$HOST" CFLAGS="$CFLAGS" \ + OPT_LDFLAGS="$OPT_LDFLAGS" \ OPT_CFLAGS="-O -D_FORTIFY_SOURCE=2 -D COREBOOT_TOOLCHAIN_VERSION='"coreboot toolchain v$CROSSGCC_VERSION"' " \ $MAKE $JOBS CC="$(hostcc host)" iasl acpibin acpidump acpiexec acpihelp acpisrc acpixtract mkdir -p "$DESTDIR$TARGETDIR/bin/" @@ -1143,7 +1144,10 @@ # so we're setting the ABI explicitly here. if [ "$(sysctl -n hw.optional.x86_64 2>/dev/null)" -eq 1 ] 2>/dev/null; then OPTIONS="ABI=64" + elif [ "$(sysctl -n hw.optional.arm64 2>/dev/null)" -eq 1 ] 2>/dev/null; then + OPTIONS="ABI=64" else + echo "Select ABI=32" OPTIONS="ABI=32" fi
