Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47968 )
Change subject: cpu/x86: Link reset16.inc ......................................................................
Change-Id: If2caab67286cf77e37928e03be4f581070e771d8 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/arch/x86/bootblock_crt0.S M src/cpu/x86/Makefile.inc R src/cpu/x86/reset16.S 3 files changed, 1 insertion(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/47968/1
diff --git a/src/arch/x86/bootblock_crt0.S b/src/arch/x86/bootblock_crt0.S index a457978..d151feb 100644 --- a/src/arch/x86/bootblock_crt0.S +++ b/src/arch/x86/bootblock_crt0.S @@ -16,7 +16,6 @@ * Include the old code for reset vector and protected mode entry. That code has * withstood the test of time. */ -#include <cpu/x86/16bit/reset16.inc> #include <cpu/x86/32bit/entry32.inc>
#if CONFIG(BOOTBLOCK_DEBUG_SPINLOOP) diff --git a/src/cpu/x86/Makefile.inc b/src/cpu/x86/Makefile.inc index 8862e87..f1bca0e 100644 --- a/src/cpu/x86/Makefile.inc +++ b/src/cpu/x86/Makefile.inc @@ -6,6 +6,7 @@ subdirs-$(CONFIG_CPU_INTEL_COMMON_SMM) += ../intel/smm
bootblock-y += entry16.S +bootblock-y += reset16.S
additional-dirs += $(obj)/cpu/x86
diff --git a/src/cpu/x86/16bit/reset16.inc b/src/cpu/x86/reset16.S similarity index 97% rename from src/cpu/x86/16bit/reset16.inc rename to src/cpu/x86/reset16.S index b5abb3d..3858014 100644 --- a/src/cpu/x86/16bit/reset16.inc +++ b/src/cpu/x86/reset16.S @@ -12,4 +12,3 @@ * instead of the weird 16 bit relocations that binutils does not * handle consistently between versions because they are used so rarely. */ - .previous
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47968 )
Patch Set 8: Code-Review+2
Kyösti Mälkki has submitted this change. ( https://review.coreboot.org/c/coreboot/+/47968 )
Change-Id: If2caab67286cf77e37928e03be4f581070e771d8 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/47968 Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/arch/x86/bootblock_crt0.S M src/cpu/x86/Makefile.inc R src/cpu/x86/reset16.S 3 files changed, 1 insertion(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/arch/x86/bootblock_crt0.S b/src/arch/x86/bootblock_crt0.S index 3e9065b..16daed1 100644 --- a/src/arch/x86/bootblock_crt0.S +++ b/src/arch/x86/bootblock_crt0.S @@ -16,7 +16,6 @@ * Include the old code for reset vector and protected mode entry. That code has * withstood the test of time. */ -#include <cpu/x86/16bit/reset16.inc> #include <cpu/x86/32bit/entry32.inc>
#if CONFIG(BOOTBLOCK_DEBUG_SPINLOOP) diff --git a/src/cpu/x86/Makefile.inc b/src/cpu/x86/Makefile.inc index 393506b..9112ddb 100644 --- a/src/cpu/x86/Makefile.inc +++ b/src/cpu/x86/Makefile.inc @@ -9,6 +9,7 @@ subdirs-$(CONFIG_CPU_INTEL_COMMON_SMM) += ../intel/smm
