Attention is currently required from: Arthur Heymans, Benjamin Doron, Kyösti Mälkki, Lance Zhao, Lean Sheng Tan, Nico Huber, Tim Wawrzynczak.
Hello Benjamin Doron, Kyösti Mälkki, Lance Zhao, Lean Sheng Tan, Nico Huber, Tim Wawrzynczak, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/75677?usp=email
Change subject: acpi: Add a debug option to print out tables in ACPICA compatible hex ......................................................................
Sometimes systems don't boot to the OS due to wrong ACPI tables. Printing the tables in an ACPICA compatible format makes analysis of ACPI tables easier.
The ACPICA format (acpidump, acpixtract) is the following: " FACS @ 0x0000000000000000 0000: 46 41 43 53 40 00 00 00 E8 24 00 00 00 00 00 00 FACS@....$...... 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
To achieve analyze ACPI tables capture the coreboot log between "Printing ACPI in ACPICA compatible table" and "Done printing ACPI in ACPICA compatible table". Remove the prefix "[SPEW ] " and then call 'acpixtract -a dump' to extract all the tables. Then use 'iasl -d' on the .dat files to decompile the tables.
Signed-off-by: Arthur Heymans arthur@aheymans.xyz Change-Id: I7b5d879014563f7a2e1f70c45cf871ba72f142dc --- M src/Kconfig M src/acpi/acpi.c 2 files changed, 93 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/77/75677/5
