HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16852
commit 83e6d05718ab4019c156db27b7260a1e3368e51f Author: Elyes HAOUAS ehaouas@noos.fr Date: Sun Oct 2 12:30:06 2016 +0200
src/southbridge: Remove unnecessary whitespace
Change-Id: Ibcac5dd60dc7da82bbeeb89ac445a5a1aa56ed3d Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/southbridge/amd/amd8111/ide.c | 2 +- src/southbridge/amd/cimx/sb700/bootblock.c | 4 ++-- src/southbridge/amd/cimx/sb700/smbus_spd.c | 2 +- src/southbridge/amd/cimx/sb800/bootblock.c | 2 +- src/southbridge/amd/cimx/sb800/fan.c | 24 ++++++++++++------------ src/southbridge/amd/cimx/sb900/bootblock.c | 4 ++-- src/southbridge/amd/rs780/gfx.c | 2 +- src/southbridge/amd/sb600/early_setup.c | 4 ++-- src/southbridge/amd/sb700/early_setup.c | 2 +- src/southbridge/amd/sb800/early_setup.c | 2 +- src/southbridge/ricoh/rl5c476/rl5c476.c | 2 +- src/southbridge/sis/sis966/ide.c | 2 +- src/southbridge/sis/sis966/nic.c | 6 +++--- src/southbridge/via/vt8237r/early_smbus.c | 2 +- src/southbridge/via/vt8237r/lpc.c | 4 ++-- 15 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/src/southbridge/amd/amd8111/ide.c b/src/southbridge/amd/amd8111/ide.c index a7eee35..fec424d 100644 --- a/src/southbridge/amd/amd8111/ide.c +++ b/src/southbridge/amd/amd8111/ide.c @@ -33,7 +33,7 @@ static void ide_init(struct device *dev) pci_write_config16(dev, 0x40, word);
- byte = 0x20 ; // Latency: 64-->32 + byte = 0x20; // Latency: 64-->32 pci_write_config8(dev, 0xd, byte);
word = 0x0f; diff --git a/src/southbridge/amd/cimx/sb700/bootblock.c b/src/southbridge/amd/cimx/sb700/bootblock.c index 2f67a36..e10bb05 100644 --- a/src/southbridge/amd/cimx/sb700/bootblock.c +++ b/src/southbridge/amd/cimx/sb700/bootblock.c @@ -29,7 +29,7 @@ static void sb700_enable_rom(void) * BIT30: Port Enable for ACPI Micro-Controller port 0x66 and 0x62 */ dword = pci_io_read_config32(dev, 0x44); - //dword |= (1<<6) | (1<<29) | (1<<30) ; + //dword |= (1<<6) | (1<<29) | (1<<30); /*Turn on all of LPC IO Port decode enable */ dword = 0xffffffff; pci_io_write_config32(dev, 0x44, dword); @@ -42,7 +42,7 @@ static void sb700_enable_rom(void) * BIT21: Port Enable for Port 0x80 */ dword = pci_io_read_config32(dev, 0x48); - dword |= (1<<0) | (1<<1) | (1<<4) | (1<<6) | (1<<21) ; + dword |= (1<<0) | (1<<1) | (1<<4) | (1<<6) | (1<<21); pci_io_write_config32(dev, 0x48, dword);
/* Enable 4MB ROM access at 0xFFE00000 - 0xFFFFFFFF */ diff --git a/src/southbridge/amd/cimx/sb700/smbus_spd.c b/src/southbridge/amd/cimx/sb700/smbus_spd.c index 281279b..7b07db1 100644 --- a/src/southbridge/amd/cimx/sb700/smbus_spd.c +++ b/src/southbridge/amd/cimx/sb700/smbus_spd.c @@ -120,7 +120,7 @@ static void setupFch(UINT16 ioBase)
/* Enable SMBus MMIO. */ PciAddress.AddressValue = MAKE_SBDFO (0, 0, 20, 0, 0xD2); - LibAmdPciRead(AccessWidth8, PciAddress, &PciData8, &StdHeader); ; + LibAmdPciRead(AccessWidth8, PciAddress, &PciData8, &StdHeader);; PciData8 |= BIT0; LibAmdPciWrite(AccessWidth8, PciAddress, &PciData8, &StdHeader);
diff --git a/src/southbridge/amd/cimx/sb800/bootblock.c b/src/southbridge/amd/cimx/sb800/bootblock.c index 89e56b6..008a19b 100644 --- a/src/southbridge/amd/cimx/sb800/bootblock.c +++ b/src/southbridge/amd/cimx/sb800/bootblock.c @@ -28,7 +28,7 @@ static void enable_rom(void) * BIT30: Port Enable for ACPI Micro-Controller port 0x66 and 0x62 */ dword = pci_io_read_config32(dev, 0x44); - //dword |= (1<<6) | (1<<29) | (1<<30) ; + //dword |= (1<<6) | (1<<29) | (1<<30); /* Turn on all of LPC IO Port decode enable */ dword = 0xffffffff; pci_io_write_config32(dev, 0x44, dword); diff --git a/src/southbridge/amd/cimx/sb800/fan.c b/src/southbridge/amd/cimx/sb800/fan.c index e37fc3d..5925330 100644 --- a/src/southbridge/amd/cimx/sb800/fan.c +++ b/src/southbridge/amd/cimx/sb800/fan.c @@ -102,7 +102,7 @@ if (sb_chip->imc_fan_zone0_enabled) { sb_config.Pecstruct.MSGFun81zone0MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun81zone0MSGREG1 = IMC_ZONE0; message_ptr = &sb_config.Pecstruct.MSGFun81zone0MSGREG2; - for (i = 0; i < IMC_FAN_CONFIG_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_CONFIG_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone0_config_vals[i];
/* EC LDN9 function 83 zone 0 - Temperature Thresholds */ @@ -110,14 +110,14 @@ if (sb_chip->imc_fan_zone0_enabled) { sb_config.Pecstruct.MSGFun83zone0MSGREG1 = IMC_ZONE0; sb_config.Pecstruct.MSGFun83zone0MSGREGB = 0x00; message_ptr = &sb_config.Pecstruct.MSGFun83zone0MSGREG2; - for (i = 0; i < IMC_FAN_THRESHOLD_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_THRESHOLD_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone0_thresholds[i];
/*EC LDN9 function 85 zone 0 - Fan Speeds */ sb_config.Pecstruct.MSGFun85zone0MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun85zone0MSGREG1 = IMC_ZONE0; message_ptr = &sb_config.Pecstruct.MSGFun85zone0MSGREG2; - for (i = 0; i < IMC_FAN_SPEED_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_SPEED_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone0_fanspeeds[i];
} @@ -133,7 +133,7 @@ if (sb_chip->imc_fan_zone1_enabled) { sb_config.Pecstruct.MSGFun81zone1MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun81zone1MSGREG1 = IMC_ZONE1; message_ptr = &sb_config.Pecstruct.MSGFun81zone1MSGREG2; - for (i = 0; i < IMC_FAN_CONFIG_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_CONFIG_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone1_config_vals[i];
/* EC LDN9 function 83 zone 1 - Temperature Thresholds */ @@ -141,14 +141,14 @@ if (sb_chip->imc_fan_zone1_enabled) { sb_config.Pecstruct.MSGFun83zone1MSGREG1 = IMC_ZONE1; sb_config.Pecstruct.MSGFun83zone1MSGREGB = 0x00; message_ptr = &sb_config.Pecstruct.MSGFun83zone1MSGREG2; - for (i = 0; i < IMC_FAN_THRESHOLD_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_THRESHOLD_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone1_thresholds[i];
/* EC LDN9 function 85 zone 1 - Fan Speeds */ sb_config.Pecstruct.MSGFun85zone1MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun85zone1MSGREG1 = IMC_ZONE1; message_ptr = &sb_config.Pecstruct.MSGFun85zone1MSGREG2; - for (i = 0; i < IMC_FAN_SPEED_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_SPEED_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone1_fanspeeds[i];
} @@ -165,7 +165,7 @@ if (sb_chip->imc_fan_zone2_enabled) { sb_config.Pecstruct.MSGFun81zone2MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun81zone2MSGREG1 = IMC_ZONE2; message_ptr = &sb_config.Pecstruct.MSGFun81zone2MSGREG2; - for (i = 0; i < IMC_FAN_CONFIG_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_CONFIG_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone2_config_vals[i];
/* EC LDN9 function 83 zone 2 */ @@ -173,14 +173,14 @@ if (sb_chip->imc_fan_zone2_enabled) { sb_config.Pecstruct.MSGFun83zone2MSGREG1 = IMC_ZONE2; sb_config.Pecstruct.MSGFun83zone2MSGREGB = 0x00; message_ptr = &sb_config.Pecstruct.MSGFun83zone2MSGREG2; - for (i = 0; i < IMC_FAN_THRESHOLD_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_THRESHOLD_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone2_thresholds[i];
/* EC LDN9 function 85 zone 2 */ sb_config.Pecstruct.MSGFun85zone2MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun85zone2MSGREG1 = IMC_ZONE2; message_ptr = &sb_config.Pecstruct.MSGFun85zone2MSGREG2; - for (i = 0; i < IMC_FAN_SPEED_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_SPEED_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone2_fanspeeds[i];
} @@ -197,7 +197,7 @@ if (sb_chip->imc_fan_zone3_enabled) { sb_config.Pecstruct.MSGFun81zone3MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun81zone3MSGREG1 = IMC_ZONE3; message_ptr = &sb_config.Pecstruct.MSGFun81zone3MSGREG2; - for (i = 0; i < IMC_FAN_CONFIG_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_CONFIG_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone3_config_vals[i];
/* EC LDN9 function 83 zone 3 */ @@ -205,14 +205,14 @@ if (sb_chip->imc_fan_zone3_enabled) { sb_config.Pecstruct.MSGFun83zone3MSGREG1 = IMC_ZONE3; sb_config.Pecstruct.MSGFun83zone3MSGREGB = 0x00; message_ptr = &sb_config.Pecstruct.MSGFun83zone3MSGREG2; - for (i = 0; i < IMC_FAN_THRESHOLD_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_THRESHOLD_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone3_thresholds[i];
/* EC LDN9 function 85 zone 3 */ sb_config.Pecstruct.MSGFun85zone3MSGREG0 = 0x00; sb_config.Pecstruct.MSGFun85zone3MSGREG1 = IMC_ZONE3; message_ptr = &sb_config.Pecstruct.MSGFun85zone3MSGREG2; - for (i = 0; i < IMC_FAN_SPEED_COUNT ; i++ ) + for (i = 0; i < IMC_FAN_SPEED_COUNT; i++ ) *(message_ptr + i) = sb_chip->imc_zone3_fanspeeds[i];
} diff --git a/src/southbridge/amd/cimx/sb900/bootblock.c b/src/southbridge/amd/cimx/sb900/bootblock.c index 50d3087..a069463 100644 --- a/src/southbridge/amd/cimx/sb900/bootblock.c +++ b/src/southbridge/amd/cimx/sb900/bootblock.c @@ -28,7 +28,7 @@ static void sb900_enable_rom(void) * BIT30: Port Enable for ACPI Micro-Controller port 0x66 and 0x62 */ dword = pci_io_read_config32(dev, 0x44); - //dword |= (1<<6) | (1<<29) | (1<<30) ; + //dword |= (1<<6) | (1<<29) | (1<<30); /*Turn on all of LPC IO Port decode enable */ dword = 0xffffffff; pci_io_write_config32(dev, 0x44, dword); @@ -41,7 +41,7 @@ static void sb900_enable_rom(void) * BIT21: Port Enable for Port 0x80 */ dword = pci_io_read_config32(dev, 0x48); - dword |= (1<<0) | (1<<1) | (1<<4) | (1<<6) | (1<<21) ; + dword |= (1<<0) | (1<<1) | (1<<4) | (1<<6) | (1<<21); pci_io_write_config32(dev, 0x48, dword);
/* Enable 4MB ROM access at 0xFFE00000 - 0xFFFFFFFF */ diff --git a/src/southbridge/amd/rs780/gfx.c b/src/southbridge/amd/rs780/gfx.c index c2b3d3a..52bc071 100644 --- a/src/southbridge/amd/rs780/gfx.c +++ b/src/southbridge/amd/rs780/gfx.c @@ -302,7 +302,7 @@ static void poweron_ddi_lanes(device_t nb_dev)
ddi_pads = ~(nbpcie_ind_read_index(nb_dev, 0x65)); /* save original setting */ gfx_cfg = nbmisc_read_index(nb_dev, 0x74); - for (i = 0; i < 3 ; i++) { + for (i = 0; i < 3; i++) { if (gfx_cfg & GFX_CONFIG_DDI) { ddi_pads |= (3 << (i * 2)); } diff --git a/src/southbridge/amd/sb600/early_setup.c b/src/southbridge/amd/sb600/early_setup.c index 2caa28b..2445310 100644 --- a/src/southbridge/amd/sb600/early_setup.c +++ b/src/southbridge/amd/sb600/early_setup.c @@ -370,13 +370,13 @@ static void sb600_devices_por_init(void) printk(BIOS_INFO, "sb600_devices_por_init(): P2P Bridge, BDF:0-20-4\n"); dev = pci_locate_device(PCI_ID(0x1002, 0x4384), 0); /* I don't know why CIM tried to write into a read-only reg! */ - /*pci_write_config8(dev, 0x0c, 0x20) */ ; + /*pci_write_config8(dev, 0x0c, 0x20); */
/* Arbiter enable. */ pci_write_config8(dev, 0x43, 0xff);
/* Set PCDMA request into height priority list. */ - /* pci_write_config8(dev, 0x49, 0x1) */ ; + /* pci_write_config8(dev, 0x49, 0x1); */
pci_write_config8(dev, 0x40, 0x26);
diff --git a/src/southbridge/amd/sb700/early_setup.c b/src/southbridge/amd/sb700/early_setup.c index ea7eb27..e549e8a 100644 --- a/src/southbridge/amd/sb700/early_setup.c +++ b/src/southbridge/amd/sb700/early_setup.c @@ -520,7 +520,7 @@ static void sb700_devices_por_init(void) pci_write_config8(dev, 0x43, 0xff);
diff --git a/src/southbridge/amd/sb800/early_setup.c b/src/southbridge/amd/sb800/early_setup.c index 1096159..82ad621 100644 --- a/src/southbridge/amd/sb800/early_setup.c +++ b/src/southbridge/amd/sb800/early_setup.c @@ -468,7 +468,7 @@ static void sb800_devices_por_init(void) pci_write_config8(dev, 0x43, 0xff);
diff --git a/src/southbridge/ricoh/rl5c476/rl5c476.c b/src/southbridge/ricoh/rl5c476/rl5c476.c index 8284ec8..78561cc 100644 --- a/src/southbridge/ricoh/rl5c476/rl5c476.c +++ b/src/southbridge/ricoh/rl5c476/rl5c476.c @@ -184,7 +184,7 @@ static void rl5c476_set_resources(device_t dev) if ( enable_cf_boot && (PCI_FUNC(dev->path.pci.devfn) == 1)){ resource = find_resource(dev,1); if ( !(resource->flags & IORESOURCE_STORED) ){ - resource->flags |= IORESOURCE_STORED ; + resource->flags |= IORESOURCE_STORED; printk(BIOS_DEBUG, "%s 1 ==> %llx\n", dev_path(dev), resource->base); cf_base = resource->base; } diff --git a/src/southbridge/sis/sis966/ide.c b/src/southbridge/sis/sis966/ide.c index 5686227..6c7c7fe 100644 --- a/src/southbridge/sis/sis966/ide.c +++ b/src/southbridge/sis/sis966/ide.c @@ -133,7 +133,7 @@ printk(BIOS_DEBUG, "IDE_INIT:---------->\n"); pci_write_config16(dev, 0x50, word);
dword = pci_read_config32(dev, 0xf8); diff --git a/src/southbridge/sis/sis966/nic.c b/src/southbridge/sis/sis966/nic.c index a167848..448514b 100644 --- a/src/southbridge/sis/sis966/nic.c +++ b/src/southbridge/sis/sis966/nic.c @@ -73,7 +73,7 @@ static void readApcMacAddr(void) outl((inl(0xcfc) & 0xfffffffd),0xcfc ); // enable IO78/79h for APC Index/Data
printk(BIOS_DEBUG, "MAC addr in APC = "); - for (i = 0x9 ; i <=0xe ; i++) { + for (i = 0x9; i <=0xe; i++) { printk(BIOS_DEBUG, "%2.2x",readApcByte(i)); } printk(BIOS_DEBUG, "\n"); @@ -97,7 +97,7 @@ static void set_apc(struct device *dev) outl(0x80001048,0xcf8); outl((inl(0xcfc) & 0xfffffffd),0xcfc ); // enable IO78/79h for APC Index/Data
- for (i = 0 ; i <3; i++) { + for (i = 0; i <3; i++) { addr=0x9+2*i; writeApcByte(addr,(u8)(MacAddr[i]&0xFF)); writeApcByte(addr+1L,(u8)((MacAddr[i]>>8)&0xFF)); @@ -139,7 +139,7 @@ static unsigned long ReadEEprom( struct device *dev, u8 *base, u32 Reg)
mdelay(10);
- for (i=0 ; i <= LoopNum; i++) { + for (i=0; i <= LoopNum; i++) { ulValue=read32(base + 0x3c);
if (!(ulValue & 0x0080)) //BIT_7 diff --git a/src/southbridge/via/vt8237r/early_smbus.c b/src/southbridge/via/vt8237r/early_smbus.c index 23f5928..96a5c1b 100644 --- a/src/southbridge/via/vt8237r/early_smbus.c +++ b/src/southbridge/via/vt8237r/early_smbus.c @@ -347,7 +347,7 @@ int acpi_get_sleep_type(void) tmp = inw(VT8237R_ACPI_IO_BASE + 0x04);
printk(BIOS_DEBUG, "%02x", tmp); - return ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0 ; + return ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0; }
#if defined(__GNUC__) diff --git a/src/southbridge/via/vt8237r/lpc.c b/src/southbridge/via/vt8237r/lpc.c index dd3bcae..9d91749 100644 --- a/src/southbridge/via/vt8237r/lpc.c +++ b/src/southbridge/via/vt8237r/lpc.c @@ -51,7 +51,7 @@ static unsigned char *pin_to_irq(const unsigned char *pin) { static unsigned char Irqs[4]; int i; - for (i = 0 ; i < 4 ; i++) + for (i = 0; i < 4; i++) Irqs[i] = pciIrqs[ pin[i] - 'A' ];
return Irqs; @@ -253,7 +253,7 @@ static void setup_pm(device_t dev) int acpi_get_sleep_type(void) { u16 tmp = inw(VT8237R_ACPI_IO_BASE + 0x04); - return ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0 ; + return ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0; }
static void vt8237r_init(struct device *dev)
