Yu-Ping Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/59540 )
Change subject: drivers/analogix/anx7625: Fix edid_read() ......................................................................
The current implementations of edid_read() and segments_edid_read() have a few problems:
1. The type of variable `c` ic incorrect, not matching the return type of sp_tx_aux_rd(). In addition, the meaning of `c` is unknown. 2. It is pointless to do `cnt++` when sp_tx_aux_rd() fails. 3. These two functions ignore the return value of anx7625_reg_block_read(). 4. In segments_edid_read(), anx7625_reg_write() might return a positive value on failure.
Fix all of the 4 issues, and modify the code to be closer to kernel's implementation (drivers/gpu/drm/bridge/analogix/anx7625.c). Note that, however, unlike in kernel, anx7625_reg_block_read() here doesn't return the number of bytes. On success, 0 is returned instead.
In addition, change the return value to -1 for edid_read() and segments_edid_read() on failure.
BUG=b:207055969 TEST=emerge-asurada coreboot BRANCH=none
Change-Id: Ife9d7d97df2926b4581ba519a152c9efed8cd969 Signed-off-by: Yu-Ping Wu yupingso@chromium.org --- M src/drivers/analogix/anx7625/anx7625.c 1 file changed, 26 insertions(+), 30 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/40/59540/1
diff --git a/src/drivers/analogix/anx7625/anx7625.c b/src/drivers/analogix/anx7625/anx7625.c index 5fbcf20..638e793 100644 --- a/src/drivers/analogix/anx7625/anx7625.c +++ b/src/drivers/analogix/anx7625/anx7625.c @@ -558,34 +558,32 @@
static int edid_read(uint8_t bus, uint8_t offset, uint8_t *pblock_buf) { - uint8_t c, cnt = 0; + int ret, cnt;
- c = 0; for (cnt = 0; cnt < 3; cnt++) { sp_tx_aux_wr(bus, offset); /* set I2C read com 0x01 mot = 0 and read 16 bytes */ - c = sp_tx_aux_rd(bus, 0xf1); + ret = sp_tx_aux_rd(bus, 0xf1);
- if (c == 1) { + if (ret) { sp_tx_rst_aux(bus); ANXERROR("edid read failed, reset!\n"); - cnt++; } else { - anx7625_reg_block_read(bus, RX_P0_ADDR, - AP_AUX_BUFF_START, - MAX_DPCD_BUFFER_SIZE, pblock_buf); - return 0; + if (anx7625_reg_block_read(bus, RX_P0_ADDR, + AP_AUX_BUFF_START, + MAX_DPCD_BUFFER_SIZE, + pblock_buf) == 0) + return 0; } }
- return 1; + return -1; }
static int segments_edid_read(uint8_t bus, uint8_t segment, uint8_t *buf, uint8_t offset) { - uint8_t c, cnt = 0; - int ret; + int ret, cnt;
/* write address only */ ret = anx7625_reg_write(bus, RX_P0_ADDR, AP_AUX_ADDR_7_0, 0x30); @@ -599,7 +597,7 @@ /* data read */ ret |= anx7625_reg_write(bus, RX_P0_ADDR, AP_AUX_ADDR_7_0, 0x50);
- if (ret < 0) { + if (ret) { ANXERROR("IO error: aux initial failed.\n"); return ret; } @@ -607,21 +605,21 @@ for (cnt = 0; cnt < 3; cnt++) { sp_tx_aux_wr(bus, offset); /* set I2C read com 0x01 mot = 0 and read 16 bytes */ - c = sp_tx_aux_rd(bus, 0xf1); + ret = sp_tx_aux_rd(bus, 0xf1);
- if (c == 1) { - ret = sp_tx_rst_aux(bus); + if (ret) { + sp_tx_rst_aux(bus); ANXERROR("segment read failed, reset!\n"); - cnt++; } else { - ret = anx7625_reg_block_read(bus, RX_P0_ADDR, - AP_AUX_BUFF_START, - MAX_DPCD_BUFFER_SIZE, buf); - return ret; + if (anx7625_reg_block_read(bus, RX_P0_ADDR, + AP_AUX_BUFF_START, + MAX_DPCD_BUFFER_SIZE, + buf) == 0) + return 0; } }
- return ret; + return -1; }
static int sp_tx_edid_read(uint8_t bus, uint8_t *pedid_blocks_buf, @@ -630,9 +628,7 @@ uint8_t offset, edid_pos; int count, blocks_num; uint8_t pblock_buf[MAX_DPCD_BUFFER_SIZE]; - uint8_t i; - uint8_t g_edid_break = 0; - int ret; + int i, ret, g_edid_break = 0;
/* address initial */ ret = anx7625_reg_write(bus, RX_P0_ADDR, AP_AUX_ADDR_7_0, 0x50); @@ -656,10 +652,10 @@ case 1: for (i = 0; i < 8; i++) { offset = (i + count * 8) * MAX_DPCD_BUFFER_SIZE; - g_edid_break = edid_read(bus, offset, - pblock_buf); + g_edid_break = !!edid_read(bus, offset, + pblock_buf);
- if (g_edid_break == 1) + if (g_edid_break) break;
if (offset <= size - MAX_DPCD_BUFFER_SIZE) @@ -677,11 +673,11 @@ edid_pos = (i + count * 8) * MAX_DPCD_BUFFER_SIZE;
segments_edid_read(bus, count / 2, - pblock_buf, offset); + pblock_buf, offset); if (edid_pos <= size - MAX_DPCD_BUFFER_SIZE) memcpy(&pedid_blocks_buf[edid_pos], pblock_buf,
