Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9573
commit 11b2a0522bc1792314425e7021ca1b2fcebed1d9 Author: Vadim Bendebury vbendeb@chromium.org Date: Sun Nov 30 16:10:46 2014 -0800
ipq8064: use the new utility to build bootblock
The first blob in the Storm bootimage is a concatenation of the Uber-sbl produced by the qca-firmware ebuild and the coreboot bootblock.
The new tool is used to add the bootblock to uber-sbl and update the size values in the combined header.
BRANCH=storm BUG=chrome-os-partner:34161 TEST=no execution tests yet, the build succeeds.
Change-Id: I4f1fe8a97ffab04eee4f82bc43e6f5406dd9bb42 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: a126a62f65a568d62fe35bdcf27eaec38fd1a997 Original-Change-Id: Iec3c1e943f1f9ee5ca20320a6365fc4aa5516e38 Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/232310 Original-Reviewed-by: Manoj Juneja mjuneja@qti.qualcomm.com Original-Reviewed-by: Trevor Bourget tbourget@codeaurora.org Original-Reviewed-by: David Hendricks dhendrix@chromium.org --- src/soc/qualcomm/ipq806x/Kconfig | 2 +- src/soc/qualcomm/ipq806x/Makefile.inc | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/src/soc/qualcomm/ipq806x/Kconfig b/src/soc/qualcomm/ipq806x/Kconfig index 8cc7233..0136a18 100644 --- a/src/soc/qualcomm/ipq806x/Kconfig +++ b/src/soc/qualcomm/ipq806x/Kconfig @@ -41,7 +41,7 @@ config MBN_ENCAPSULATION config SBL_BLOB depends on USE_BLOBS string "file name of the Qualcomm SBL blob" - default "3rdparty/cpu/qualcomm/ipq8064/sbls.bin" + default "3rdparty/cpu/qualcomm/ipq806x/uber-sbl.mbn" help The path and filename of the binary blob containing ipq806x early initialization code, as supplied by the diff --git a/src/soc/qualcomm/ipq806x/Makefile.inc b/src/soc/qualcomm/ipq806x/Makefile.inc index 5dfca4d..27967dc 100644 --- a/src/soc/qualcomm/ipq806x/Makefile.inc +++ b/src/soc/qualcomm/ipq806x/Makefile.inc @@ -57,8 +57,8 @@ $(objcbfs)/bootblock.mbn: $(objcbfs)/bootblock.raw # Create a complete bootblock which will start up the system $(objcbfs)/bootblock.bin: $(call strip_quotes,$(CONFIG_SBL_BLOB)) \ $(objcbfs)/bootblock.mbn - @printf " CAT $(subst $(obj)/,,$(@))\n" - @cat $^ > $@.tmp + @printf " MBNCAT $(subst $(obj)/,,$(@))\n" + @util/ipqheader/mbncat.py -o $@.tmp $^ @mv $@.tmp $@
endif
