David Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/56940 )
Change subject: mb/google/brya/variants/kano: Configure GPIOs according to schematics ......................................................................
Update initial gpio configuration for kano
BUG=b:192370253 TEST=FW_NAME=kano emerge-brya coreboot
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I4d6099fa8d17bebf798ddf236a68886087e2a95e --- A src/mainboard/google/brya/variants/kano/Makefile.inc A src/mainboard/google/brya/variants/kano/gpio.c 2 files changed, 136 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/40/56940/1
diff --git a/src/mainboard/google/brya/variants/kano/Makefile.inc b/src/mainboard/google/brya/variants/kano/Makefile.inc new file mode 100644 index 0000000..03fa5d5 --- /dev/null +++ b/src/mainboard/google/brya/variants/kano/Makefile.inc @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-only +bootblock-y += gpio.c + +ramstage-y += gpio.c + diff --git a/src/mainboard/google/brya/variants/kano/gpio.c b/src/mainboard/google/brya/variants/kano/gpio.c new file mode 100644 index 0000000..cc6a870 --- /dev/null +++ b/src/mainboard/google/brya/variants/kano/gpio.c @@ -0,0 +1,131 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/gpio.h> +#include <baseboard/variants.h> +#include <commonlib/helpers.h> +#include <soc/gpio.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* Pad configuration in ramstage */ +static const struct pad_config override_gpio_table[] = { + /* A6 : ESPI_ALERT1# ==> NC */ + PAD_NC(GPP_A6, NONE), + /* A7 : SRCCLK_OE7# ==> NC */ + PAD_NC(GPP_A7, NONE), + /* A8 : SRCCLKREQ7# ==> NC */ + PAD_NC(GPP_A8, NONE), + /* A12 : SATAXPCIE1 ==> NC */ + PAD_NC(GPP_A12, NONE), + /* A15 : USB_OC2# ==> NC */ + PAD_NC(GPP_A15, NONE), + /* A19 : DDSP_HPD1 ==> NC */ + PAD_NC(GPP_A19, NONE), + /* A20 : DDSP_HPD2 ==> NC */ + PAD_NC(GPP_A20, NONE), + /* A21 : DDPC_CTRCLK ==> NC */ + PAD_NC(GPP_A21, NONE), + /* A22 : DDPC_CTRLDATA ==> NC */ + PAD_NC(GPP_A22, NONE), + + /* D3 : ISH_GP3 ==> NC */ + PAD_NC(GPP_D3, NONE), + /* D5 : SRCCLKREQ0# ==> NC */ + PAD_NC(GPP_D5, NONE), + /* D7 : SRCCLKREQ2# ==> NC */ + PAD_NC(GPP_D7, NONE), + /* D8 : SRCCLKREQ3# ==> NC */ + PAD_NC(GPP_D8, NONE), + /* D9 : ISH_SPI_CS# ==> NC */ + PAD_NC(GPP_D9, NONE), + /* D18 : UART1_TXD ==> NC */ + PAD_NC(GPP_D18, NONE), + + /* E0 : SATAXPCIE0 ==> NC */ + PAD_NC(GPP_E0, NONE), + /* E3 : PROC_GP0 ==> SAR1_INT_L */ + PAD_CFG_GPI_APIC(GPP_E3, NONE, PLTRST, LEVEL, NONE), + /* E7 : PROC_GP1 ==> NC */ + PAD_NC(GPP_E7, NONE), + /* E10 : THC0_SPI1_CS# ==> NC */ + PAD_NC(GPP_E10, NONE), + /* E17 : THC0_SPI1_INT# ==> NC */ + PAD_NC(GPP_E17, NONE), + /* E22 : DDPA_CTRLCLK ==> NC */ + PAD_NC(GPP_E22, NONE), + /* E23 : DDPA_CTRLDATA ==> NC */ + PAD_NC(GPP_E23, NONE), + + /* F6 : CNV_PA_BLANKING ==> NC */ + PAD_NC(GPP_F6, NONE), + /* F20 : EXT_PWR_GATE# ==> NC */ + PAD_NC(GPP_F20, NONE), + /* F21 : EXT_PWR_GATE2# ==> NC */ + PAD_NC(GPP_F21, NONE), + + /* H8 : I2C4_SDA ==> NC */ + PAD_NC(GPP_H8, NONE), + /* H9 : I2C4_SCL ==> NC */ + PAD_NC(GPP_H9, NONE), + /* H12 : I2C7_SDA ==> NC */ + PAD_NC(GPP_H12, NONE), + /* H13 : I2C7_SCL ==> NC */ + PAD_NC(GPP_H13, NONE), + /* H15 : DDPB_CTRLCLK ==> NC */ + PAD_NC(GPP_H15, NONE), + /* H19 : SRCCLKREQ4# ==> NC */ + PAD_NC(GPP_H19, NONE), + /* H20 : IMGCLKOUT1 ==> NC */ + PAD_NC(GPP_H20, NONE), + /* H21 : IMGCLKOUT2 ==> NC */ + PAD_NC(GPP_H21, NONE), + /* H22 : IMGCLKOUT3 ==> NC */ + PAD_NC(GPP_H22, NONE), + /* H23 : SRCCLKREQ5# ==> NC */ + PAD_NC(GPP_H23, NONE), + + /* GPD11: LANPHYC ==> NC */ + PAD_NC(GPD11, NONE), +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { + /* A13 : PMC_I2C_SCL ==> GSC_PCH_INT_ODL */ + PAD_CFG_GPI_APIC(GPP_A13, NONE, PLTRST, LEVEL, INVERT), + /* B7 : ISH_12C1_SDA ==> PCH_I2C_TPM_SDA */ + PAD_CFG_NF(GPP_B7, NONE, DEEP, NF2), + /* B8 : ISH_12C1_SCL ==> PCH_I2C_TPM_SCL */ + PAD_CFG_NF(GPP_B8, NONE, DEEP, NF2), + /* + * D1 : ISH_GP1 ==> FP_RST_ODL + * FP_RST_ODL comes out of reset as hi-z and does not have an external pull-down. + * To ensure proper power sequencing for the FPMCU device, reset signal is driven low + * early on in bootblock, followed by enabling of power. Reset signal is deasserted + * later on in ramstage. Since reset signal is asserted in bootblock, it results in + * FPMCU not working after a S3 resume. This is a known issue. + */ + PAD_CFG_GPO(GPP_D1, 0, DEEP), + /* D2 : ISH_GP2 ==> EN_FP_PWR */ + PAD_CFG_GPO(GPP_D2, 1, DEEP), + /* E0 : SATAXPCIE0 ==> NC */ + PAD_NC(GPP_E0, NONE), + /* E13 : THC0_SPI1_IO2 ==> MEM_CH_SEL */ + PAD_CFG_GPI(GPP_E13, NONE, DEEP), + /* E15 : RSVD_TP ==> PCH_WP_OD */ + PAD_CFG_GPI_GPIO_DRIVER(GPP_E15, NONE, DEEP), + /* H10 : UART0_RXD ==> UART_PCH_RX_DBG_TX */ + PAD_CFG_NF(GPP_H10, NONE, DEEP, NF2), + /* H11 : UART0_TXD ==> UART_PCH_TX_DBG_RX */ + PAD_CFG_NF(GPP_H11, NONE, DEEP, NF2), +}; + +const struct pad_config *variant_gpio_override_table(size_t *num) +{ + *num = ARRAY_SIZE(override_gpio_table); + return override_gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +}
