Idwer Vollering (vidwer@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6387
commit d6ffa962da0dfa6aaef106c3a0fc591d489b7f4c Author: Idwer Vollering vidwer@gmail.com Date: Sat Aug 2 00:03:20 2014 +0200
payloads/external/SeaBIOS: retain the built binary
build/ is wiped during 'make clean': move SeaBIOS' build directory out of build/
Change-Id: I561b209798396d995984c244890e54f31671b5b1 Signed-off-by: Idwer Vollering vidwer@gmail.com --- payloads/external/SeaBIOS/Makefile.inc | 33 +++++++++++++++++---------------- src/Kconfig | 2 +- 2 files changed, 18 insertions(+), 17 deletions(-)
diff --git a/payloads/external/SeaBIOS/Makefile.inc b/payloads/external/SeaBIOS/Makefile.inc index 21f933a..8f4be2b 100644 --- a/payloads/external/SeaBIOS/Makefile.inc +++ b/payloads/external/SeaBIOS/Makefile.inc @@ -1,3 +1,4 @@ + TAG-$(CONFIG_SEABIOS_MASTER)=origin/master TAG-$(CONFIG_SEABIOS_STABLE)=96917a8ed761f017fc8c72ba3b9181fbac03ac59
@@ -10,42 +11,42 @@ unexport KCONFIG_NEGATIVES
all: build
-$(OUT)/seabios: +clone: echo " Cloning SeaBIOS from Git" - git clone http://review.coreboot.org/p/seabios.git $(OUT)/seabios + git clone http://review.coreboot.org/p/seabios.git seabios
-fetch: $(OUT)/seabios - cd $(OUT)/seabios; git show $(TAG-y) >/dev/null 2>&1 ; if [ $$? -ne 0 ]; \ +fetch: clone + cd seabios; git show $(TAG-y) >/dev/null 2>&1 ; if [ $$? -ne 0 ]; \ then echo " Fetching new commits from the SeaBIOS git repo"; git fetch; fi
checkout: fetch echo " Checking out SeaBIOS revision $(TAG-y)" - cd $(OUT)/seabios; git checkout master; git branch -D coreboot 2>/dev/null; git checkout -b coreboot $(TAG-y) + cd seabios; git checkout master; git branch -D coreboot 2>/dev/null; git checkout -b coreboot $(TAG-y)
config: checkout echo " CONFIG SeaBIOS $(TAG-y)" - echo "CONFIG_COREBOOT=y" > $(OUT)/seabios/.config + echo "CONFIG_COREBOOT=y" > seabios/.config ifeq ($(CONFIG_CONSOLE_SERIAL),y) - echo "CONFIG_DEBUG_SERIAL=y" >> $(OUT)/seabios/.config - echo "CONFIG_DEBUG_SERIAL_PORT=$(CONFIG_TTYS0_BASE)" >> $(OUT)/seabios/.config + echo "CONFIG_DEBUG_SERIAL=y" >> seabios/.config + echo "CONFIG_DEBUG_SERIAL_PORT=$(CONFIG_TTYS0_BASE)" >> seabios/.config else - echo "# CONFIG_DEBUG_SERIAL is not set" >> $(OUT)/seabios/.config + echo "# CONFIG_DEBUG_SERIAL is not set" >> seabios/.config endif ifneq ($(CONFIG_SEABIOS_THREAD_OPTIONROMS),y) - echo "# CONFIG_THREAD_OPTIONROMS is not set" >> $(OUT)/seabios/.config + echo "# CONFIG_THREAD_OPTIONROMS is not set" >> seabios/.config endif # This shows how to force a previously set .config option *off* - #echo "# CONFIG_SMBIOS is not set" >> $(OUT)/seabios/.config - $(MAKE) -C $(OUT)/seabios olddefconfig OUT=$(OUT)/seabios/out/ + #echo "# CONFIG_SMBIOS is not set" >> seabios/.config + $(MAKE) -C seabios olddefconfig OUT=out/
build: config echo " MAKE SeaBIOS $(TAG-y)" - $(MAKE) -C $(OUT)/seabios OUT=$(OUT)/seabios/out/ + $(MAKE) -C seabios OUT=out/
clean: - test -d $(OUT)/seabios && $(MAKE) -C $(OUT)/seabios clean OUT=$(OUT)/seabios/out/ || exit 0 + test -d seabios && $(MAKE) -C seabios OUT=out/ || exit 0
distclean: - rm -rf $(OUT)/seabios + rm -rf seabios
-.PHONY: checkout config build clean distclean clone fetch +.PHONY: checkout config build clean distclean fetch diff --git a/src/Kconfig b/src/Kconfig index af82353..8127315 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -671,7 +671,7 @@ config PAYLOAD_FILE
config PAYLOAD_FILE depends on PAYLOAD_SEABIOS - default "$(obj)/seabios/out/bios.bin.elf" + default "payloads/external/SeaBIOS/seabios/out/bios.bin.elf"
config PAYLOAD_FILE depends on PAYLOAD_FILO
