Attention is currently required from: CoolStar, Matt DeVillier, Nick Vaccaro, Subrata Banik.
Hello Matt DeVillier, Nick Vaccaro, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/80719?usp=email
Change subject: soc/intel/tigerlake: Remove IOM Mctp command from TCSS ASL ......................................................................
Port fix from Alder Lake to not set/reset IOM MCTP during D3 cold entry or exit.
Ports 5008d340033d9289dade91569e356f9317f9b3a9 (soc/intel/adl: Remove IOM Mctp command from TCSS ASL):
` Recently as part of s0ix hang issue, it was found that sending IOM MCTP command as part of TCSS D3 Cold enter-exit sequence created an issue.
We discovered that due to change in hardware sequence, ADL should not set/reset IOM MCTP during D3 cold entry or exit. This patch removes the bit setting from ASL file to prevent hang in the system.
This patch also removes obsolete Pcode mailbox communication which is no longer required for ADL.
BUG=b:220796339 BRANCH=firmware-brya-14505.B TEST=Check if hang issue is resolved with the CL and no other regression observed
https://review.coreboot.org/c/coreboot/+/62861 `
Test: build/boot drobit to Win11. Verify TCSS XHCI power management working and USB Root Hub doesn't Code 43 in device manager
Change-Id: I40a537fd2b0c821caf282f52aaff1874f54325f1 Signed-off-by: CoolStar coolstarorganization@gmail.com --- M src/soc/intel/tigerlake/acpi/tcss.asl 1 file changed, 1 insertion(+), 142 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/80719/3
