Yu-Ping Wu has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83111?usp=email )
Change subject: arch/arm64: Add Kconfig option ARM64_BL31_OPTEE_WITH_SMC ......................................................................
Add a new Kconfig option ARM64_BL31_OPTEE_WITH_SMC to control whether to build the OP-TEE dispatcher for BL31. This config also enables the BL31 build option OPTEE_ALLOW_SMC_LOAD, which allows loading the OP-TEE image after boot via a Secure Monitor Call (SMC). For ChromeOS devices, CROS_WIDEVINE_SMC is also enabled to allow passing secrets from firmware to OP-TEE.
BUG=b:347851571 TEST=emerge-geralt coreboot BRANCH=geralt
Change-Id: I4dcf82d47b537146d71ce3cd2050ec597ed0734f Signed-off-by: Yu-Ping Wu yupingso@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/83111 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Julius Werner jwerner@chromium.org --- M src/arch/arm64/Kconfig M src/arch/arm64/Makefile.mk 2 files changed, 18 insertions(+), 0 deletions(-)
Approvals: Julius Werner: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/arch/arm64/Kconfig b/src/arch/arm64/Kconfig index 2d71067..af5050b 100644 --- a/src/arch/arm64/Kconfig +++ b/src/arch/arm64/Kconfig @@ -46,6 +46,15 @@ default n depends on ARCH_RAMSTAGE_ARM64 && ARM64_CURRENT_EL = 3
+config ARM64_BL31_OPTEE_WITH_SMC + bool "Build OP-TEE dispatcher for BL31 and allow loading via an SMC" + default n + depends on ARM64_USE_ARM_TRUSTED_FIRMWARE + help + This option adds support for building the OP-TEE Secure Payload Dispatcher + (SPD) for BL31, and allows loading the OP-TEE image via a Secure Monitor Call + (SMC). + config ARM64_BL31_EXTERNAL_FILE string "Path to external BL31.ELF (leave empty to build from source)" depends on ARM64_USE_ARM_TRUSTED_FIRMWARE diff --git a/src/arch/arm64/Makefile.mk b/src/arch/arm64/Makefile.mk index 6499283..cb43897 100644 --- a/src/arch/arm64/Makefile.mk +++ b/src/arch/arm64/Makefile.mk @@ -185,6 +185,15 @@ # Set a consistent build timestamp: the same coreboot has BL31_MAKEARGS += BUILD_MESSAGE_TIMESTAMP='"$(shell sed -n 's/^.define COREBOOT_BUILD>.*"(.*)".*/\1/p' $(obj)/build.h)"'
+ifeq ($(CONFIG_ARM64_BL31_OPTEE_WITH_SMC),y) +BL31_MAKEARGS += SPD=opteed +BL31_MAKEARGS += OPTEE_ALLOW_SMC_LOAD=1 +BL31_MAKEARGS += PLAT_XLAT_TABLES_DYNAMIC=1 +ifeq ($(CONFIG_CHROMEOS),y) +BL31_MAKEARGS += CROS_WIDEVINE_SMC=1 +endif +endif # CONFIG_ARM64_BL31_OPTEE_WITH_SMC + BL31_CFLAGS := -fno-pic -fno-stack-protector -Wno-deprecated-declarations -Wno-unused-function BL31_LDFLAGS := -Wl,--emit-relocs
